[Guide] 4850/4870 Lüftersteuerung - einfach + komfortabel
<Profile>
<Caste name="Graphics">
<Groups>
<Group name="Overdrive5">
<Feature name="TimeUnlocked" />
<Feature name="OverclockEnabled">
<Property name="OverclockEnabledProperty" value="False" />
</Feature>
<Feature name="CoreClockTarget_0">
<Property name="Want_0" value="50000" />
<Property name="Want_1" value="50000" />
<Property name="Want_2" value="75000" />
</Feature>
<Feature name="MemoryClockTarget_0">
<Property name="Want_0" value="90000" />
<Property name="Want_1" value="90000" />
<Property name="Want_2" value="90000" />
</Feature>
<Feature name="CoreVoltageTarget_0">
<Property name="Want_0" value="1263" />
<Property name="Want_1" value="1263" />
<Property name="Want_2" value="1263" />
</Feature>
<Feature name="MemoryVoltageTarget_0">
<Property name="Want_0" value="0" />
<Property name="Want_1" value="0" />
<Property name="Want_2" value="0" />
</Feature>
<Feature name="CoreClockTarget_1">
</Feature>
<Feature name="MemoryClockTarget_1">
</Feature>
<Feature name="CoreVoltageTarget_1">
</Feature>
<Feature name="MemoryVoltageTarget_1">
</Feature>
<Feature name="FanSpeedProtocol_0">
<Property name="FanSpeedProtocolProperty" value="Percent" />
<Feature name="FanSpeedProtocol_1">
</Feature>
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Manual" />
<Feature name="FanSpeedAlgorithm_1">
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
<Feature name="FanSpeedRPMTarget_1">
</Feature>
<Feature name="FanSpeedPercentTarget_0">
<Property name="Want" value="30" />
<Feature name="FanSpeedPercentTarget_1">
</Feature>
</Group>
</Groups>
<Adapter name="PCI_VEN_1002&DEV_9440&SUBSYS_05021002&REV_00_4&1C207C4&0&0008A">
<Aspect name="Overdrive5" />
</Adapter>
</Caste>
</Profile>
Das habe ich alles da drin stehen. Was stimmt daran nicht?
@ DKH mit der 3850 die temps oder mit 4850er?!
@RoughNeck
hm.. sollten beide auf 30% laufen mit dem text.... sind bei dir die fans speed percent zeilen der beiden karten so na aneinander??
grüße
@RoughNeck
grüße
Nein
habe ich so eingetragen.
Kannst eventuell ein Profil hochladen wo das richtig ist?
jop ich schau gleich mal, habe aber 2 4850er daher vorsicht, aber kannst dir ja mal anschaun,
<Profile>
<Groups>
<Property name="OverclockEnabledProperty" value="True" />
</Feature>
<Property name="Want_2" value="62500" />
</Feature>
<Property name="Want_0" value="75000" />
<Property name="Want_1" value="75000" />
<Property name="Want_2" value="99300" />
</Feature>
<Property name="Want_0" value="1046" />
<Property name="Want_1" value="1046" />
<Property name="Want_2" value="1123" />
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
weiter drunter hab ich nix umgestellt, lediglich die farbigen "lettern" ^^
hi bei mir gehts unter xp aber unter vista64 gehts nicht kommisch???
Funkt wunderbar, die 50% sind zwar schlimm aber wenn man zockt sicher nicht sehr störend und unter IDLE sollte man zwischen 25-30% einstellen, dies reicht für ca. 63-67 Grad Celsius.
Hoffe dies bessert ATI in dem Cat noch selber nach,- bzw. mit der Powerplay+ Stromsparfunktion kann man somit auf die guten 40-45 Grad dann ja schon im Idle kommen,- denke unter Last können es auch um die 8-12 Grad WENIGER werden mit der Powerplay+ Funktion und gutem Lüftertiming, vor Allem LETZTEREM !!
Danke allseits, vor allem aber dem Threadersteller...
Weder noch, habe ne Sapphire HD3870. (gibt es in meiner Version nicht mehr zu kaufen)
Ich höre meinen Lüfter trotz ohne Seitenteil erst ab 60%.
Jetzt gerade läuft er mit 40 oder 50% bei 47° weil es gerade zimmlich Warm im raum ist.
@RoughNeck: gerne geschehen
@oxaoxa: die zeilen die ich gepostet habe sind aus vista64 bit, ansonsten nochmal auf der ersten seite lesen vllt haste was übersehen...
grüße
Sry für die vl dumme Frage,
aber womit lest ihr die aktuelle Drehzahl des Lüfter aus? Edit: Mit GPU-Z
Schmor hier gerade bei 79 Grad Idle rum.
Edit: Huh auf 100% rauschts aber wie ein Fön ^^
Aber ok die Temp sinkt hier grade bei 0% Auslastung der GPU auf 45 Grad.
Schon nett.
angeblich solls mit CPU-Z geht, nur bei mir gehts net und ich denke
auch eher ist unwarscheinlich.
Daher lese ich sie auch eig. net aus, sondern achte auf die Temps
im CCC.
Ein Tool wie man die Drehzahl auslesen kann, ist gerne willkommen ^^
Danke!!
bei 70% ist das schon sehr laut, aber beim gamen mit dem kopfhörer eh egal!
und ich hab das nur 5mins so an, und was passiertß temp bei 30°C :hail:!
Vielen Vielen Dank!
super sache!
idle 81°C bei 23% standardgeschwindigkeit, jetzt mit 30% (unhörbar) 55°C im idle. profile werden beim start ordentlich mitgeladen, alles perfekt.
os: vista x64 business
jop ist schon ok ^^
also ich habe 0.2.5 und ich sehe von beiden karten die drehzahl bei sensors und dann bei fan speed...
Danke
hat einwandfrei geklappt endlich kann man den lüfter beim zocken bissel höher drehen lassen :d
eine 4870! Muss ich den nachfolgend angelegten auch Manual eingeben? Ich finde 50% aber sehr laut muss ich sagen!
Stellt er die 30 dann sofort ein, beim Systemstart? Weil das schone echt viel gebracht hat,64 statt 81°c im idle! Und wie stelle ich ein das er gleich beim windowsstart die profile ladet inh diesen fall die 30%?
du musst einfach mal weiter oben kucken, und auf den anderen seiten,
dort steht ne menge.
Aber hier nochmal:
<Profile>
<Groups>
</Feature>
<Property name="Want_0" value="30000" />
<Property name="Want_1" value="30000" />
<Property name="Want_2" value="77700" />
</Feature>
<Property name="Want_0" value="112600" />
<Property name="Want_1" value="112600" />
<Property name="Want_2" value="112600" />
</Feature>
<Property name="Want_0" value="1241" />
<Property name="Want_1" value="1241" />
<Property name="Want_2" value="1327" />
</Feature>
</Feature>
</Feature>
</Feature>
</Feature>
<Property name="Want" value="60" />
</Feature>
</Group>
</Groups>
<Adapter name="PCI_VEN_1002&DEV_9501&SUBSYS_25421002&REV_00_4&154B9167&0&0078A">
</Adapter>
</Caste>
</Profile>
So muss das aussehen (rot beachten). Er lädt das Profil dann beim Rechner start Automatisch des zuletzt benutzen Profils.
Kurze Frage: Warum muss man beim Erstellen der Lüfterprofile "Alle Einstellungen" wählen? Das ist imho nicht nötig, es reicht ein Haken bei "Overdrive".
Das hat zwei Vorteile: Beim Ändern der Lüfterdrehzahl wird der Desktop nicht jedesmal kurz neu geladen bzw. der Bildschirm flackert nicht. Die passiert immer, wenn man etwas an den 3D-Einstellungen verändert.
Weiterhin werden Einstellungen im Treiber, z.B. 4xAA, immer wieder durch das Lüfterprofil geändert, wenn man "Alle Einstellungen" gewählt hat.
Ich würde also empfehlen, die Anleitung vorne zu ändern. Es reicht doch vollkommen, wenn die Profile die Lüfterdrehzahl beeinflussen. Zu mehr sind sie ja auch garnicht gedacht, oder? ;)
Also, wenn ich den Lüfter einstelle funzt es zwar, aber sobald ich das AMD GPU Tool verwende. dann regelt der Lüfter wieder automatisch!
Juhu bei mir funzt es nun auch super sache :)
Muss aber sagen das bei meiner powercolor 4870 die 50% auch schon recht störend sind aber liegt wohl daran das ich das restliche system unter wasser hab und so lüftergeräusche nichtmehr gewöhnt bin ^^
Schade das man das timing der automatischen lüftersteuerung nicht ändern kann, da könnte man noch viel nettere dinge machen als das automatische ati ding das die ganze zeit bei 20% rumgurkt und dann auf staubsauger lautstärke hochdreht für kurze zeit.
40% müssten doch eigentlich für alles (außer Furmark) reichen, oder nicht? Ich meine...mein System ist schlecht belüftet und die HD 4870 deshalb deutlich heißer als bei anderen hier, aber schlechter geht's eher nicht....dachte ich. :d
Ist einfacher zu verstehen (sind ja nicht alle Spezialisten).
Ich kann's ja dazuschreiben.
Es wurde schon erwähnt, daß die Profile beim Benutzen des Amd Gpu Tool nicht funktionieren.
Naja, nur um mal ein Beispiel zu beschreiben: Ich stelle Adaptive AA ein um es zu testen. Im Spiel stelle ich keinen Unterschied fest, was ist geschehen? Ganz einfach, vorher hatte ich das 40%-Profil aktiviert und das hat das Adaptive AA wieder abgeschaltet.
Ob Profi oder nicht, das ist sehr störend. Das sollte doch jeder kapieren, dass man für die Lüfterprofile den Haken eben NUR bei "Ati Overdrive" setzen sollte. ;)
So jezt funktioniert es, habe von 25-60 Profile eingerichtet, in jedem einzelnen "Manual" eingetragen statt "Automatic" und die 25-60 auch eingetragen!
Klappt also! Aber Manuell das immer einzustellen....kann mann das nicht automatisch einstellen, wie sagen wir mal mit ner 1950xt in Atitool?
Meines wissens musst du deine Gewünschte %-Zahl immer Manuel auswählen,
da es wohl noch keine Lösung gibt.
Es empfiehlt es wie schon oben beschrieben "nur" das ATI CCC zu benutzen
und keine anderen Tools in sachen GPU ausser GPU-Z zb.
Ähnliche Themen
