Morpheus2200
Semiprofi
Ich kenne den Test.
Trotzdem sind die Spannungswandler die gleichen.
Nein Gainward und Palit haben 4 Phasen, Referenz 3 Phasen.
Ich kenne den Test.
Wie geil 160 c bei den spannungswandlern.Das ist definitiv zuviel.Ich kriege bei meiner baugleichen Club3d oc beim Furmark höchstens 125 C bei den Vdcc werten.Dann kriege ich ein vpurecover.Komisch das du keine warnung bekommst.Hast du schonmall bei ein Spiel die temps mitgelogt=?160 C sind einfach insane..Bei 125 c solltest du normalerweise ein vpu recover bekommen.Bei Spielen sollten die vdcc werte immer unter 110 C bleiben (egal bei welchem takt).
Powercolor HD4870 PSC+ stands for “Professional Cooling System”. we are looking forward ZEROtherm cooler can surprise us in cooling, but things trun out to be unexpected: When we ran Furmark stability test, the card just couldn’t run for more than 30 seconds.
But even we changed cooler to T-Tad2, 4870 PCS+ still can not ran Furmark stable with factory clock. Before it hangs we are able to record that core temperature is only at 60℃. In response, Powercolor representative stats it is “software compatibility issues”.
Finally we can get three platform stabilized through 15 minutes in Furmark, all three 4870 PCS+ frequency is around 680-690MHz (core), 880 MHz-890MHz (memory), core temperature 76 ℃. If we replace ZEROThrem with T-RAD2 radiator, then the frequency can be further improved a bit, elevated to 730/950 MHz, core temperature 56 ℃.
In another words, all three HD 4870 PCS+ can pass Furmark in a lowered clock can fully passed is a good proof that “software issue” is not exist.
What’s more, we just tried with the new Catalyst 8.8, the driver lower Furmark frame rate a lot, also bring down temperature and PCB temperature, we don’t know if AMD making some trick in their driver. But anyway, we are managing to get more sample of Powercolor 4870 PCS+, will continue tracking issues of this product.
Dann hau Vista drauf
