!Wichtig! Frage zu INTEL SE7500WV2 Dual XEON Server Mainboard
ddchiller
Dresden
Hiho,
kann einer was zum INTEL SE7500WV2 Dual XEON Server Mainboard sagen? Also ob das Board gut ist oder schlecht und nur zusammenbricht oder sowas :) Einsatzgebiet ist erstmal egal..will nur wissen wie das Board so ist bzw. ob einer damit Erfahrungen hat.
hier ein paar infos dazu
Intel SE7500WV2 Dual XEON Server System Board Rack-optimized design - 1U & 2U, EATX form factor
Intel® E7500 Chipset
Dual Intel® Xeon™ CPU's with 512-KB cache & Hyper-Threading Technology
Dual-channel ATA/100 RAID Promise PDC20277 Controller
(6) 184-Pin DIM Slots (DDR-200/DDR-266 support, ECC, Registered)
256Mb Minimum Memory Config, 12Gb Maximum Config
Dual integrated Intel® Pro/1000 XT Server Ethernet controllers
(1) PS/2, (1) VGA, (2) Ethernet, (2)USB, (1) RJ-45 Serial Ports
Integrated graphics - ATI Rage XL Graphics with 8 MB memory
8Mb SDRAM Video Memory
Triple Peer PCI-X, up to six PCI-X slots on risers in a 2U system:
Bus A: 32-bit/33-MHz, Bus B: 64-bit/66 to 100-MHz, Bus C: 64-bit/66-MHz
Advanced Intel® Server Management
Daten vom Hersteller (ohne Gewähr)
The Intel® Server Board SE7500WV2 is rack-optimized with features making it uniquely suitable for 1U and 2U systems. For example, adapter-slot locations allow for one full-height and one low-profile PCI add-in card in a 1U system, or three full-height and three low-profile cards in a 2U system. For highly demanding server workloads, the Server Board SE7500WV2 accommodates up to two Intel® Xeon™ processors with 512KB L2 Advanced Transfer Cache and Hyper-Threading Technology. Multiple integrated components provide dual PCI-X buses, dual Intel® PRO/1000 XT Server Network Connections, and up to 12 GB of Error-Correcting Code (ECC) DDR memory support. All component locations and design are thermally optimized for high-density systems
Features Benefits
Support for one or two Intel® Xeon™ processors with 512KB L2 Advanced Transfer Cache and Hyper-Threading Technology Processing performance for demanding server applications
Support for up to 12 GB of registered ECC DDR200/266 (200 MHz) SDRAM with six DIMM sockets Memory flexibility and capacity to support a wide range of server solutions
Dual (two-way) interleaved memory High-performance memory subsystem with up to 3.2 GB/sec of data transfer
Triple-peer PCI/PCI-X buses Bandwidth for intensive I/O needs
1U system: one full-length and one low-profile 64-bit/100 MHz slot on two independent PCI-X buses capable of running at 66-100 MHz depending on system configuration Room for two high-throughput adapter cards operating on separate buses
2U system: up to three full-length and three low-profile slots on two independent PCI-X buses capable of running at 66-100 MHz depending on system configuration Room for six high-throughput adapter cards with I/O balanced across multiple buses
Two integrated Intel® PRO/1000 XT Server Network Connections (Intel® 82546EB controller) High bandwidth with widespread compatibility, teaming capability, and redundant links
Optional dual-channel Ultra160 SCSI supporting modular ROMB High-performance data transfer that can easily be augmented to deliver RAID functionality
Optional dual-channel ATA/100 RAID controller Enables the use of low-cost IDE drives without sacrificing data protection
Integrated ATI* Rage* XL video controller with 8 MB of video memory High-quality video without the need for a video-adapter card
Advanced Intel® Server Management software and hardware, including serial data/ console redirection over LAN, integrated remote management, event alerting, and proactive fault management High server availability and low maintenance costs
die aufgaben weiß ich noch net *g* bisher drängt mich mehr der "haben-wollen" wille *g* ..das board war günstig..das ging heute für 51 euro bei ebay raus.. und als ich die frage hier stellte stand es noch bei 25,50 und da dacht ich mir ich frag euch einfach mal was ihr davon haltet :)
zukünftige einsatzgebiete wären vielleicht mal Rendersachen oder sowas..will mal was neues lernen :d
was kannst du/ihr denn noch für boards empfehlen die mit dem Intel Board gleich sind!? :)
Ich würde erstmal überlgene, was ich damit überhaupt machen will.... vorher ist so etwas nur reine Geldverschwendung.. nachher hast du son Teil zu Hause stehen und kannst damit nix anfangen...
Rendersachen?
also wenn du das Board in einer Workstation zum modlieren also arbeiten mit 3D Tools nehmen willst ist das gänzlich ungeeignet.
Hast du aber schon eine GrafikWorkstation, und willst nur deine Renderjobs auf einen Server auslagern, weil du zB weiterarbeiten musst, dann könnte man das Board schon gebrauchen.
Allerdings ist das echt nicht grade besonders schnell, 100MHz Prestonias musste darauf einseten.
Also wenn vorhandene Hardware (Speicher CPU NT etc) schon alles da ist kann man das Board nehmen,
neu aufsetzen würd ich das aber sicher nicht ...
hm naja will ja nich unbedingt pausenlos und richtig professionel rendern sondern bloß nebenbei..meinen hauptpc will ich dafür net verwenden weil der mein zock PC ist.. also dacht ich mir eine günstige dualmachine und da fiel mir halt das board auf.. neue xeon cpus und dual mainboards dafür (oder für opterons) sind mir einfach zu teuer :-(
Ne , dann ist es ungeeignet... kannst ja aufgrund eines Fehlenden AGp-Ports/PCI-EX. Ports nicht mal ne ordentliche Grafikkarte einbauen.. un die Onboard ist zu lahm für arbeiten mit 3D-Tools....
am liebsten opteron (amd fanboy eben :d ) ..aber die sind mir wohl zu teuer also dann wohl ältere xeon modele.. sockel 603 Xeons sind glaube die älteren oder
Bei Rendering Apps kann man schlicht und ergreifend NICHT pauschal sagen Opteron oder Xeon. Jedes Tool hat unterschiedliche Vorlieben.
Da solltest du vorher mal ordentlich vergleichen ...
wie schon geschrieben will ich nicht der high end render profi werden sondern das nur nebenbei mal betreiben zum kennen lernen deswegen will ich auch keine high end machine und jeden kleinsten unterschied der cpus ausnutzen.. kost ausserdem viel zu viel geld für mich..deswegen hat ich euch ja um meinung zu dem "billig" intel board gefragt bzw gleichwertige boards zu dem ;)
Günstigster Einstieg für Xeon Mainboards ist das PC-DL, auf dem so ziemlich alles an P4 basierenden Xeons läuft was vor 2004 auf den Markt kam (also alles ausser 800 MHz FSB Xeons). Schau dir das Board mal bei www.asuscom.de an. Bekommst du neu für rund 160€.
Weiter gehts mit dem PCH-DL wenn du lieber 64 Bit PCI haben willst, alles was danach kommt kostet >200€, ist also zu teuer!
gruß
w@w
da werd ich mich mal diesen umschauen :)
ab welchen Preis gehen eigentlich opteron boards los?
