nb xm2:
Dimensions: 40x40x10 mm
Weight: 15 g
Rated voltage: 12V DC
Starting Voltage: 9 V DC
Input Power: 0.7 W
Rated speed: 3800 ±10%
Airflow: 3.9 CFM
6.7 m^3/h
Noise Level: 14 dB/A
MTBF (25°C): 20,000 hr.
Connection: Standard 3 Pin
Warranty: 3 Years
mini kaze:
RPM at 12V : 3800 (+/- 10%)
Airflow max. m /h : 6,7 m³/h
Acoustical Noise (dB/A) : 14 dB/A
Air Flow: 3,9 CFM
MTBF (25°C) : 20 000 Std.
Connector : 3 Pin Molex incl. RPM signal
Operating Voltage : 10-12,0 V
Start Voltage : 9 Volt
Input Power : 0,48 Watt
nb xm1:
Specifications:
Weight: 15 g
Starting Voltage: 10 V DC
Input Power: 0.7 W
Rated speed: 2800 ±10%
Airflow: 2.9 CFM
4.9 m^3/h
Noise Level: 11 dB/A
Warranty: 3 Years
