Chefkoch
Abit NF7 2.0 & NF7-S 2.0 BIOS 18 ist da.
Neues Bios ist erschienen, ich teste es mal.
http://www.abit.com.tw/abitweb/webjsp/english/index.jsp
BIOS ID: 18
-Fixed the problem that system hangs up with POST code 01 while resuming from STR mode with user defined DRAM timings. With default SPD setting, no problem at all and doesn't need this update.
-Fixed the problem that system hangs up at POST code FF with over clocking setting- change the multiplier factor from CPU default to 19.
-Fixed the problem that Barton 2500+ CPU is occasionally detected as Barton 3200+. If 400 FSB CPU is installed, users need to select correct CPU type in SoftMenuIII by themselves.
-BIOS Compile date: 7/24/2003.
