Ach menno! Blaue Sapphire GTO2 erwischt!
grisu63
Die Überschrift sagt es schon:
Ich habe eine blaue GTO2 erwischt, ohne Stromanschluss und mit 430 Chipsatz!
Gibt es hier ne Change auf 16 Pipes zu flashen, und wenn ja, welches BIOS soll ich nehmen.
Auf der Karte steht GTO2 drauf und hat auch den GTO2 Kühler installiert.
Hier die Daten der Karte:
Display adapter RADEON X800 GTO (0x554F)
Core Name R430
SubVendor Sapphire (P.C. Partner) (174B)
SubDevice 1600
BUS 1
Device 0
Function 0
Base Address 0 D000000C
Base Address 1 00000000
Base Address 2 D9000004
Base Address 3 00000000
Bus Type PCI Express
SMARTGART Installed No
Driver Version 06.4
Release Version 8.241-060321a1-031959C-ATI
QuadBuffer Stereo Support No
Catalyst Registry Path
System\CurrentControlSet\Control\Video\{02E719C3-36DE-4239-8E91-C0B0944F9930}\0000
______________________________
Clock Information
BIOS VPU 400,00
Current VPU 399,21
BIOS MEM 490,00
Current MEM 489,85
Radeon PCI configuration space
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 02 10 4F 55 07 00 10 00 00 00 00 03 08 00 80 00
10 0C 00 00 D0 00 00 00 00 04 00 00 D9 00 00 00 00
20 01 90 00 00 00 00 00 00 00 00 00 00 4B 17 00 16
30 00 00 00 00 50 00 00 00 00 00 00 00 12 01 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 4B 17 00 16
50 01 58 02 06 00 00 00 00 10 80 01 00 A0 04 2C 01
60 10 09 00 00 01 AD 00 00 00 00 01 11 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Hardware Information
Installed memory 256 Mb
Memory Type GDDR3
Memory Width 256 bit
Active Rendering Pipelines 12
ASIC details
Family 56
Emulated Revision 21
Gfx Engine ID 3
Radeon Registers
RADEON_BIOS_0_SCRATCH 02000002
RADEON_BIOS_1_SCRATCH 0100C000
RADEON_X_MPLL_REF_FB_DIV 00CFFE0E
RADEON_XCLK_CNTL 00007FFA
RADEON_MCLK_CNTL 00031212
GB_TILE_CONFIG 0001001D
MC_TIMING_CNTL 69668234
MC_SDRAM_MODE_REG 10430000
Video BIOS Information
Version 009.007.001.004
Part Number 11X-CC600ASA-001
Date 2005/01/03 14:11
Vram Type DDR3
Controller Configurations
Controller 0
Active Connections:
-Monitor (CRT1) (0) 1280x1024x60
Controller 1
Active Connections:
No Active Connections
Displays supported by adapter
0 (1) Monitor (CRT1)
1 (2) Second Monitor (CRT2)
2 (4) Component Video Output
3 (8) TV
4 (16) Digital Flat Panel
EnumDisplays
Display Type 0, Extended Type 1 , Max Resolution 1920x1080
Display Type 0, Extended Type 2 , Max Resolution 1600x1200
Display Type 4, Extended Type 0 , Max Resolution 720x480
Display Type 1, Extended Type 7 , Max Resolution 1024x768
Display Type 3, Extended Type 1 , Max Resolution 1920x1080
soviel ich weis kann man die auch freischalten, aber die sind dann eben nur X800XL Karten und mit OC ist dann nich soviel...
Aber das sollte gehen. Kannst dir ja bei Techpowerup das Bios mit den freigeschalteten Pipes ziehen.
Ich finde das passende BIOS nicht :-(
Kann man auch mit dem ATI Winflash arbeiten??
