emissary42
Kapitän zur See
- Ort
- Nehr'esham
- Desktop System
- Endlos-Baustelle
- AMD & Intel
- alle Hersteller
- Luft
- G.SKILL, Corsair & Co
- 8K, 5K, 4K
- 80plus Platinum
ADATA XPG V3 DDR3 Performance Memory
( Produktseite | HARDWARELUXX News )
Press Release (Quelle)
ADATA Launches XPG V3 DDR3 Overclocking Memory
Ready to Fire With XPG!
Taipei, Taiwan – July 22, 2014 – ADATA® Technology, a leading manufacturer of high-performance DRAM modules and NAND Flash application products, today launches the latest XPG V3 series overclocking memory, running at a stellar 3100 megahertz. Its dual channel is designed to bring gamers and PC enthusiasts ultimate performance by Intel® Core™ fourth and fifth-generation processors and the latest Z97 platform.
The Thermal Conductive Technology for Great Heat Dissipation
With speed up to 3100MHz and transfer bandwidth reaching 24.8GB/s, the XPG V3 series once again pushes gaming to the next level. It supports Extreme Memory Profile (XMP) version 1.3 and utilizes the Thermal Conductive Technology (TCT), which reduces the system temperature effectively. It enables every chip have contact with the heat sinks directly, ensuring IC and PCB operate in an environment of equal temperature for the best stability, even in full-speed operation.
No Crash with Great Stability
Thanks to the detachable fins extended upwards and 8-layer PCBs with 2oz copper, the XPG V3 series provides superior cooling performance and stable data transfer. The 2oz copper can greatly decrease electric resistance and consumes less power for higher efficiency. It also helps to improve the integrity of signal transfer by the lower EMI (ElectroMagnetic Interference), enabling overclockers to get excellent benchmarks in the circumstance of great stability and stable signal.
Beautiful and Durable - Inside and Out
The detachable fin heat sinks can be replaced and fastened by screws, making the XPG V3 series more durable for long-term use. In addition, there's one more pair of fins included in the package for the 1st lot of shipment, allowing users to exchange the fins and create the coolest rig! For safety and excellent service, all XPG gaming modules are RoHS compliant and come with a lifetime warranty.
Product Features
- Detachable fins
- Speed up to 3100MHz
- Transfer bandwidth up to 24.8GB/s
- Supports Intel XMP 1.3 (Extreme Memory Profile)
- Supports dual channel mode
- RoHS compliant
- Complies with JEDEC standards
- High-quality 8-layer PCB with 2oz copper for improved cooling performance and higher efficiency
- Thermal Conductive Technology (TCT) for heat dissipation
- Supports the latest Intel Z97 platform
ADATA Technology, one of the world’s largest vendors of DRAM Modules and USB Flash Drives, provides complete memory solutions, including memory cards, solid state drives, and portable hard drives. ADATA products are internationally recognized by Germany’s iF Design Award, red dot Award, CES Best of Innovations Award, Japan’s Good Design Award, Best Choice of Computex Award, and Taiwan Excellence Gold Award. The company’s slogan of Love, Life, Dreams, embodies the ADATA brand and the role of innovative memory products in the human pursuit of universally cherished ideas.
Spezifikationen
[table="class:grid"]
[tr][td]Model name[/td][td]Speed[/td][td]Bandwidth[/td][td]Size[/td][td]Latency[/td][td]Voltage[/td][td]Color[/td][td]Preis[/td][/tr]
[tr][td]AX3U3100W8G12-DBV-RG[/td][td]DDR3-3100[/td][td]PC3-24800[/td][td]8GB x 2[/td][td]CL12-14-14-36[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U3100W4G12-DBV-RG[/td][td]DDR3-3100[/td][td]PC3-24800[/td][td]4GB x 2[/td][td]CL12-14-14-36[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U3000W8G12-DBV-RG[/td][td]DDR3-3000[/td][td]PC3-24000[/td][td]8GB x 2[/td][td]CL12-14-14-36[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U3000W4G12-DBV-RG[/td][td]DDR3-3000[/td][td]PC3-24000[/td][td]4GB x 2[/td][td]CL12-14-14-36[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U2933W8G12-DBV-RG[/td][td]DDR3-2933[/td][td]PC3-23400[/td][td]8GB x 2[/td][td]CL12-14-14-36[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U2933W4G12-DBV-RG[/td][td]DDR3-2933[/td][td]PC3-23400[/td][td]4GB x 2[/td][td]CL12-14-14-36[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U2800W8G12-DBV-RG[/td][td]DDR3-2800[/td][td]PC3-22400[/td][td]8GB x 2[/td][td]CL12-14-14-36[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U2800W4G12-DBV-RG[/td][td]DDR3-2800[/td][td]PC3-22400[/td][td]4GB x 2[/td][td]CL12-14-14-36[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U2600W8G11-DBV-RG[/td][td]DDR3-2600[/td][td]PC3-20800[/td][td]8GB x 2[/td][td]CL11-13-13-35[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U2600W4G11-DBV-RG[/td][td]DDR3-2600[/td][td]PC3-20800[/td][td]4GB x 2[/td][td]CL11-13-13-35[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U2400W8G11-DBV-RG[/td][td]DDR3-2400[/td][td]PC3-19200[/td][td]8GB x 2[/td][td]CL11-13-13-35[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U2400W4G11-DBV-RG [/td][td]DDR3-2400[/td][td]PC3-19200[/td][td]4GB x 2[/td][td]CL11-13-13-35[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U2133W8G10-DBV-RG[/td][td]DDR3-2133[/td][td]PC3-17000[/td][td]8GB x 2[/td][td]CL10-11-11-30[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U2133W4G10-DBV-RG[/td][td]DDR3-2133[/td][td]PC3-17000[/td][td]4GB x 2[/td][td]CL10-11-11-30[/td][td]1.65V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U1866W8G10-DBV-RG[/td][td]DDR3-1866[/td][td]PC3-14900[/td][td]8GB x 2[/td][td]CL10-11-11-30[/td][td]1.5V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U1866W4G10-DBV-RG[/td][td]DDR3-1866[/td][td]PC3-14900[/td][td]4GB x 2[/td][td]CL10-11-11-30[/td][td]1.5V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U1600W8G9-DBV-RG[/td][td]DDR3-1600[/td][td]PC3-12800[/td][td]8GB x 2[/td][td]CL9-9-9-24[/td][td]1.5V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[tr][td]AX3U1600W4G9-DBV-RG[/td][td]DDR3-1600[/td][td]PC3-12800[/td][td]4GB x 2[/td][td]CL9-9-9-24[/td][td]1.5V[/td][td]Black (Red+Gold)[/td][td]Preisvergleich[/td][/tr]
[/table]
Die farbigen Kühlfinnen können abgenommen und ausgetauscht werden. Dazu müssen nur zwei Schrauben gelöst werden, siehe:
Bilder
Reviews
- ADATA XPG V3 2x4GB DDR3-3100 (AX3U3100W4G12-DBV-RG) @ Legit Reviews
- ADATA XPG V3 2x4GB DDR3-2933 (AX3U2933W4G12-DBV-RG) @ Tweak.dk (DK)
- ADATA XPG V3 2x4GB DDR3-2933 (AX3U2933W4G12-DBV-RG) @ PCGH
- ADATA XPG V3 2x4GB DDR3-2933 (AX3U2933W4G12-DBV-RG) @ Guru3d
- ADATA XPG V3 2x4GB DDR3-2933 (AX3U2933W4G12-DBV-RG) @ HispaZone (ES)
Achtung: Laut ADATA Homepage wird nur die erste Charge ein zweites paar gelber Kühlfinnen beinhalten. Vermutlich wird es diese zu einem späteren Zeitpunkt auch einzeln und in anderen Farben zu kaufen geben.
Quelle: Computex 2014 - ADATA shows 2TB PCI-E SSD and DDR4 memory - LAB501
