00:00.0 Host bridge: ATI Technologies Inc RS690 Host Bridge
Subsystem: Giga-byte Technology Unknown device 5000
Flags: bus master, 66MHz, medium devsel, latency 64
00:01.0 PCI bridge: ATI Technologies Inc RS690 PCI to PCI Bridge (Internal gfx) (prog-if 00 [Normal decode])
Flags: bus master, 66MHz, medium devsel, latency 99
Bus: primary=00, secondary=01, subordinate=01, sec-latency=68
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: fde00000-fdffffff
Prefetchable memory behind bridge: 00000000d8000000-00000000dfffffff
Capabilities: [44] HyperTransport: MSI Mapping
Capabilities: [b0] Subsystem: ATI Technologies Inc RS690 PCI to PCI Bridge (Internal gfx)
00:12.0 SATA controller: ATI Technologies Inc SB600 Non-Raid-5 SATA (prog-if 01 [AHCI 1.0])
Subsystem: Giga-byte Technology Unknown device b005
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 22
I/O ports at ff00 [size=8]
I/O ports at fe00 [size=4]
I/O ports at fd00 [size=8]
I/O ports at fc00 [size=4]
I/O ports at fb00 [size=16]
Memory at fe02f000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [60] Power Management version 2
00:13.0 USB Controller: ATI Technologies Inc SB600 USB (OHCI0) (prog-if 10 [OHCI])
Subsystem: Giga-byte Technology Unknown device 5004
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 16
Memory at fe02e000 (32-bit, non-prefetchable) [size=4K]
00:13.1 USB Controller: ATI Technologies Inc SB600 USB (OHCI1) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 17
Memory at fe02d000 (32-bit, non-prefetchable) [size=4K]
00:13.2 USB Controller: ATI Technologies Inc SB600 USB (OHCI2) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 18
Memory at fe02c000 (32-bit, non-prefetchable) [size=4K]
00:13.3 USB Controller: ATI Technologies Inc SB600 USB (OHCI3) (prog-if 10 [OHCI])
Memory at fe02b000 (32-bit, non-prefetchable) [size=4K]
00:13.4 USB Controller: ATI Technologies Inc SB600 USB (OHCI4) (prog-if 10 [OHCI])
Memory at fe02a000 (32-bit, non-prefetchable) [size=4K]
00:13.5 USB Controller: ATI Technologies Inc SB600 USB Controller (EHCI) (prog-if 20 [EHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 19
Memory at fe029000 (32-bit, non-prefetchable) [size=256]
Capabilities: [c0] Power Management version 2
Capabilities: [e4] Debug port
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 14)
Subsystem: Giga-byte Technology Unknown device 4385
Flags: 66MHz, medium devsel
I/O ports at 0b00 [size=16]
Capabilities: [b0] HyperTransport: MSI Mapping
00:14.1 IDE interface: ATI Technologies Inc SB600 IDE (prog-if 8a [Master SecP PriP])
Subsystem: Giga-byte Technology Unknown device 5002
I/O ports at 01f0 [size=8]
I/O ports at 03f4 [size=1]
I/O ports at 0170 [size=8]
I/O ports at 0374 [size=1]
I/O ports at f900 [size=16]
00:14.3 ISA bridge: ATI Technologies Inc SB600 PCI to LPC Bridge
Subsystem: Giga-byte Technology Unknown device 5001
Flags: bus master, 66MHz, medium devsel, latency 0
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge (prog-if 01 [Subtractive decode])
Flags: bus master, VGA palette snoop, 66MHz, medium devsel, latency 64
Bus: primary=00, secondary=02, subordinate=02, sec-latency=64
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: fdd00000-fddfffff
Prefetchable memory behind bridge: fdc00000-fdcfffff
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configurat
ion
Flags: fast devsel
Capabilities: [80] HyperTransport: Host or Secondary Interface
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
Flags: fast devsel
Capabilities: [f0] #0f [0010]
01:05.0 VGA compatible controller: ATI Technologies Inc Radeon X1200 Series (prog-if 00 [VGA])
Subsystem: Giga-byte Technology Unknown device d001
Flags: bus master, fast devsel, latency 64, IRQ 5
Memory at d8000000 (64-bit, prefetchable) [size=128M]
Memory at fdfe0000 (64-bit, non-prefetchable) [size=64K]
I/O ports at ee00 [size=256]
Memory at fde00000 (32-bit, non-prefetchable) [size=1M]
Capabilities: [50] Power Management version 2
Capabilities: [80] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
01:05.2 Audio device: ATI Technologies Inc Radeon X1200 Series Audio Controller
Subsystem: Giga-byte Technology Unknown device 7919
Flags: bus master, fast devsel, latency 64, IRQ 19
Memory at fdffc000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [60] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
