[Übersicht] AM3 CPU Ready Motherboards
Vincy
Urgestein
OWL
hier eine vorläufige Übersicht ASUS AM3 CPU Ready Motherboards
Wird fortlaufend aktualisiert.
http://event.asus.com/mb/AM3_CPU_Support/
Asus Supportseite http://support.asus.com/download/download.aspx?SLanguage=en-us&model=
M3A Series
M3A79-T Deluxe Biosversion 0504
M3A78-T v0502
M3A78 v0703
M3A78 Pro v0702
M3A78-EM v1103
M3A78-VM v0802
M3A78-CM v0902
M3A78-H/HDMI v1102
M3N Series
M3N78 v0504
M3N78-EM v0418
M3N78-VM v0804
M3N78-CM v0607
M3N78-AM v0708
M3N78 SE v0305
M3N78 Pro v0504
M3N H/HDMI v1301
M3N HD/HDMI v1402
M3N HT Deluxe/HDMI (Mempipe) v1602
M3N72-D v0502
Crosshair II Formula v1210
M2N Series
M2N68 v0412
M2N68-AM v0317
M2N68-VM v0409
M2N68-CM v0322
The list below shows the ASUS motherboards that are currently AM3 CPU-ready. For users who have already purchased the M3 or M2 Series motherboards, a simple BIOS update is all that is needed to support future AM3 CPUs. The following list will be continuously updated and more AM3 CPU-ready ASUS motherboards are expected to be announced soon.
This new generation of AMD CPUs will encompass the 45nm infrastructure; and will be equipped with C1E halt states for advanced power savings. The most distinguishing feature of the AM3 CPUs is the fact that they will support DDR3 RAM. In order to meet user demands for top-of-the-line CPUs that deliver advanced performance, the ASUS M3/M2 Series motherboards will offer the most completed product lines to fully support the upcoming AM3 CPUs.
Hier eine Liste von MSI:
http://global.msi.com.tw/html/popup/MB/45nm/en/index.html
Update:
K9N2G Neo NVIDIA® GeForce 8200 Beta BIOS(A7511NMS.1T)
K9N2GM-F V2 NVIDIA® GeForce 8200 Beta BIOS(A7509NMS.1T)
K9N2GM-FD NVIDIA® GeForce 8200 Beta BIOS(A7508NMS.1T)
K9N2GM-FIH NVIDIA® GeForce 8200 Beta BIOS(A7508NMS.3T)
Danke, wenn du das ASUS aus dem Thread-Titel nimmst, schauen vermutlich mehr Leute herein. ;)
Edit: Ich hoffe MSI liefert noch GF8200 Bretter nach
Das M3A32-MVP Deluxe ist auch nicht in der Asus Liste... wäre echt traurig wenn Asus da pennen würde.
Asrock bietet 45nm Support auf seinen 8200-Brettern :)
ASRock http://www.asrock.com/support/Phenom2.asp
AMD Series
AM2+ AMD 790GX AOD790GX/128M P1.30
AM2+ AMD 780G A780GXE/128M P1.30
AM2+ AMD 780G A780FullHD P1.30
AM2+ AMD 780G A780GM-LE All
AM2+ AMD 770 A770CrossFire P1.20
AM2+ AMD 770 A770DE P1.10
NVIDIA Series
AM2+ NVIDIA nForce 780a SLI K10N780SLIX3-WiFi P1.40
AM2+ NVIDIA GeForce 8200 K10N78-1394 P1.10
AM2+ NVIDIA GeForce 8200 K10N78 P1.10
AM2 NVIDIA GeForce 7050 / nForce 630A MCP N68PV-GS P1.20
AM2 NVIDIA GeForce 6150SE / nForce 430 N61P-S P1.30
AM2 NVIDIA GeForce 6150SE / nForce 430 NF6-GLAN P1.30
AM2 NVIDIA nForce 520 ALiveNF5-VSTA R2.0 P2.40
AM2 NVIDIA nForce 520 ALiveNF5-VSTA P2.40
AM2 NVIDIA M1695 ALiveDual-eSATA2 P1.50
AM2 NVIDIA nForce3 250 AM2NF3-VSTA P2.80
AM2 AMD 480X CrossFire ALiveXFire-eSATA2 R3.0 P2.90
AM2 AMD 480X CrossFire ALiveXFire-eSATA2 P2.90
AMD Phenom II X4 „Deneb“ kommt zur CES (8.1.09)!
Ich hoffe bei Asus gehts auch mit den M3A/N Pro Versionen - sonst miese. Da kauft man sich mal die teureren Teile und dann so ein Absturz!
Von Jetway gibt es auch einige AM3 Ready Boards.
Hab keine Liste gefunden, es steht aber bei den einzelnen Borads dabei
AMD-Chipsatz:
HA07-GT
HA07
HA07-Ultra
BA-240
HA04
HA03-Ultra
HA06
HA06-GT
XBLUE-78GA2
HA03-GT2
BA-120
XBLUE-77A2
PA74M5
XBLUE-78VA2
PA78VM5
Nvidia-Chipsatz:
XBLUE-N78V
PN78VM2
HA05-GT
Ich hoffe dass Gigabyte da noch nachbessert. Wollte mir gerade das GA-MA790GP-DS4H kaufen und im Frühjahr dann mit einem schönen Deneb versüßen, aber so bin ich erstmal irritiert.
ECS Elitegroup
http://www.ecs.com.tw/extra/2008/AM3/index.html
A790GXM-A (V1.0) AMD® 790GX & AMD® SB750
A780GM-A Ultra (V1.0) AMD® 780G & AMD® SB750
A780VM-M2 (V1.0) AMD®780V & AMD® SB700
A780VM-M3 (V1.0) AMD®780V & AMD® SB700
A780GM-A (V1.0) AMD® 780G & AMD® SB700
A780GM-A (V1.1) AMD® 780G & AMD® SB700
A780GM-M (V1.0) AMD® 780G & AMD® SB700
A780GM-M3 (V1.0) AMD® 780G & AMD® SB700
GF8100VM-M3 (V1.0) NVIDIA GeForce8100 Series
GF8100VM-M5 (V1.0) NVIDIA GeForce8100 Series
NFORCE9M-A (V1.0) NVIDIA GeForce8100 Series
GF8200A (V1.0) NVIDIA GeForce8200 Series
Die MSI Liste wurde erweiter um GeF8200 Boards: http://global.msi.com.tw/html/popup/MB/45nm/en/index.html
neu sind:
auf dem bild was ich hier sehe ist es doch aufgeführt.
wie schätzt ihr die chancen ein, dass noch ätere chipsätze unterstützt werden?
also abgesehen vom nforce3 250 würd ich sagen, dass alle ati/nvidia am2(+) chipsätze unterstüzt werden können. es liegt nur am support des boardherstellers und wenn das board zum realese teuer war, dann wird der hersteller auch noch eher gewillt sein ein neues bios zu bringen mit der unterstützung
bei asus bin ich da zuversichtlich, da die eigentlich immer noch ziemlich lange weitere (beta)versionen rausbringen - bei meinem A7V133 Deluxe is nach 4 jahren oder so das letzte beta bios erschienen :-)
tja, dann mal daumen drücken, dass mein board auch noch gnade findet ;)
Cool wäre, wenn man diese Infos im ersten Post Zusammenstellt und immer weiter aktualisiert. :wink:
Mal sehen, theoretisch sollte der nForce 590 damit ja kein Problem haben. Bis jetzt hat das Board (erschienen 23.05.06) einen erstklassigen Bios Support. Bei Kompatibilität glaube ich fest daran, dass Asus auch eine passende Version bringt.
alter wenn da nicht das M3A32MVP deluxe bald gelistet ist wars das aller letzte asus was ich dnan hatte..... holt man sich nen 170 uro board damals und kein 45nm support ?
alter schwede wenn asus das verpennt dreh ich am rad habe grad das dfi zurückgeschickt....
Es muss ja nicht an Asus liegen. Bis jetzt ist noch kein Board mit 600SB AM3 ready. Zumindest habe ich noch keines gesehen.
DFI hat ja schon mit dem extrem teuren nForce 590 SLI gezeigt, dass DFI Verlierer sind, da kein Phenom Support.
aber man braucht doch eigentlich nur den cpu code damit das bios bzw das board darauf klar kommt, name der cpu spannungen und sowas, unicode oderso hies das doch oder?
Dann hast du aber diesen Thread nicht gelesen.
Vor über 2 Wochen hatte Gigabyte ihre SB600 Vertreter schon Deneb ready, zu sehen in Post 8.
:wink:
:wink:
Oh danke für den Hinweis.
Dann wird bestimmt das Asus von neowkewl auch eine passende Version bekommen.
neowkewl
Schreib doch mal den Asus Support an.
Da ich auch nen M3A32 nutze, hoffe ich dies doch sehr. Nur leider traue ich diesem ****laden von ASUS seit geraumer Zeit alles zu. ;)
Kurze OT Frage: Hat Gigabyte die CPU-NB(VDDNB) Spannung im BIOS eigentlich mal nachgerüstet? :)
