Apple TV reboot Schleife
denniswisnia
ich habe ein Apple TV 2 und nutze das ganze als Media Zentrale mit XBMC. Das ist ziemlich großartig bisher und ich kann mich nicht beschweren.
Jetzt mache ich gestern ein Update also via SSH. Folgende Pakete wurden geupdated:
Code:
Log started: 2012-04-18  14:03:04
Selecting previously deselected package com.firecore.freemem-watcher.
(Reading database ... 4350 files and directories currently installed.)
Unpacking com.firecore.freemem-watcher (from .../com.firecore.freemem-watcher_1.0-2_iphoneos-arm.deb) ...
Selecting previously deselected package com.nito.tssagent.
Unpacking com.nito.tssagent (from .../com.nito.tssagent_1.0-30_iphoneos-arm.deb) ...
install
launch_msg(): Socket is not connected
Preparing to replace com.nito.nitotv 0.8.1-3 (using .../com.nito.nitotv_0.8.3-8_iphoneos-arm.deb) ...
Unpacking replacement com.nito.nitotv ...
Setting up com.firecore.freemem-watcher (1.0-2) ...
Setting up com.nito.tssagent (1.0-30) ...
Setting up com.nito.nitotv (0.8.3-8) ...
File /var/mobile/Media/Photos/spicon.png exists. removing...
no need to edit hosts!
Log ended: 2012-04-18  14:03:06
Log started: 2012-04-18  14:06:02
(Reading database ... 4357 files and directories currently installed.)
Preparing to replace cydia 1.1.3 (using .../cydia_1.1.6_iphoneos-arm.deb) ...
Unpacking replacement cydia ...
Setting up cydia (1.1.6) ...
Preparing to replace mobilesubstrate 0.9.3995 (using .../mobilesubstrate_0.9.3997_iphoneos-arm.deb) ...
Unpacking replacement mobilesubstrate ...
Preparing to replace beigelist 2.2.1-1 (using .../beigelist_2.2.2-3_iphoneos-arm.deb) ...
Unpacking replacement beigelist ...
Preparing to replace org.xbmc.xbmc-atv2 11.0-0~rc2 (using .../org.xbmc.xbmc-atv2_11.0-0_iphoneos-arm.deb) ...
Unpacking replacement org.xbmc.xbmc-atv2 ...
Setting up mobilesubstrate (0.9.3997) ...
Setting up beigelist (2.2.2-3) ...
Setting up org.xbmc.xbmc-atv2 (11.0-0) ...
Log ended: 2012-04-18  14:06:40
soweit nichts ungewöhnliches. Leider hängt das gute Gerät nun in der Reboot schleife. Man sieht schon immer das Menü, es hängt kurz - zack, reboot. Hier dann noch aus dmesg:
Code:
irtual void AppleRGBOUT::do_power_state_change(): fSoft: 0 fHard: 1 swapBusy: 0  fController: 1 -> 0
bool AppleRGBOUT::power_down_hardware()
bool AppleRGBOUT::power_down_hardware(), stop the link
bool AppleRGBOUT::power_down_hardware(), clock down RGBOUT
AppleRGBOUT, Completed Link
bool AppleRGBOUT::power_down_hardware(), close the DP
IOReturn AppleRGBOUT::set_display_device_gated(uint32_t), 1
void AppleRGBOUT::verify_swap_gated(IOMFBSwapIORequest*, bool*) failed there is a live DP connection but client did not put the driver in digital mode
AppleRGBOUT verify_swap failed
virtual void AppleRGBOUT::do_power_state_change(): fSoft: 0 fHard: 1 swapBusy: 0  fController: 0 -> 0
IOReturn IOMobileFramebufferUserClient::set_hotplug_notify(void*, void*) 0x317dcc31 0xdbf0400
IOReturn IOMobileFramebufferUserClient::set_hotplug_notify(void*, void*) 0x878de200 0x84a3715c 0x317dcc31 0xdbf0400
 AppleRGBOUT, capabilities:supportsMirroring=0
virtual void AppleRGBOUT::do_power_state_change(): fSoft: 1 fHard: 1 swapBusy: 0  fController: 0 -> 1
bool AppleRGBOUT::power_up_hardware()
set_crc_notification_state 0
bool AppleRGBOUT::power_up_hardware(), start DP Mode
[000016.554642]: IODPAudioDriver::message:(0x872d4c00) Video Link started
bool AppleRGBOUT::power_up_hardware(), link started
IOReturn AppleRGBOUT::set_display_device_gated(uint32_t), 2
Redundant call to IOReturn AppleRGBOUT::set_digital_out_mode_gated(uint32_t, uint32_t) 77 9
[000000.192161]: IODPAudioDriver::message:(0x872d4c00) Audio Link started
AppleBCMWLANCore::setPOWER(): state(1) stateFlags(4221)
AppleBCMWLANCore::setPOWER() [wifid]: Setting power state to 1
AppleBCMWLANCore::powerOn(): stateFlags(5221)
AppleBCMWLANBusInterfaceSdio::powerOn()
en1: setting diversity to: -1
en1: Error configuring antenna diversity (index = -1).
en1: setting tx antenna: -1
en1: Error configuring transmit antenna (index = -1).
AppleBCMWLANCore::setPOWER(): state(0) stateFlags(4223)
AppleBCMWLANCore::setPOWER() [wifid]: Setting power state to 0
AppleBCMWLANCore::powerOff(): fStateFlags(5223)
AppleBCMWLANCore::scanComplete(): Scan failure: operation was aborted
AppleBCMWLANCore::getSCAN_RESULT(): scan manager has aborted
AppleBCMWLANScanManager::reset(): scan manager is busy, state(2)
AppleBCMWLANCore::powerOff(): Not ready to power off, waiting....
AppleBCMWLANCore::powerOff Ready to power off
AppleBCMWLANBusInterfaceSdio::powerOff(): fStateFlags(00000021)
Das passiert in der Dauerschleife.
Hoffentlich kann mir jemand helfen. Ich habe wenig Lust alles neu aufzusetzen und würde es gerne einfach fixen und dann wieder mein Apple TV den ganzen Abend lieben.
