Asus P5K WS+Dominator 1066 CL5 KIT C5D NO CHANGE!
Fire4Wire
Banned
hi
habe hier 2 p5k ws boards von asus
leider laufen beide boards mit neuesetm bios 0401 NICHT mit den domi riegeln
auch eine erhöhung der ram spannung brachte nix bild bleibt schwarz
inkompatibel????
greetz
Sie suchten nachAsus P5K WS
spacer
Modul Detailinformationen
Für Übertakter TWIN2X2048-8500C5D
Extreme TWIN2X2048-9136C5D
Weitere Module Eine komplette Liste mit allen kompatiblen Speicher-Modulen finden Sie hier
Daten über das TWIN2X2048-8500C5D
The Dominator Series Twin2X2048-8500C5D is a 2048 MByte matched pair of DDR2 SDRAM DIMMs built using Corsair’s latest high performance heat sink with Dual-Path Heat Xchange (DHX) technology. This part delivers outstanding performance in the latest generation of dual-channel DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1066MHz at latencies of 5-5-5-15. The Twin2X2048-8500C5D comes with Enhanced Performance Profiles (EPP), the open standard for performance module SPD’s jointly developed by Corsair and NVIDIA. EPP SPD’s on Corsair modules allow users to automatically configure EPP enabled motherboards with aggressive memory performance settings, for maximum memory and system performance. Performance of these modules incorporating DHX can be further enhanced by using the optional Dominator Airflow Fan, for even more cooling and protection.
Daten über das Intel P35 Chipsatz
The Intel® P35 Express Chipsets support the latest multi-core processors up to FSB 1333MHz, including the upcoming 45nm platform, with its record breaking performance and greater energy efficiency. Intel® P35 chipset, with optimized system memory capabilities, chipset over-speed protection removed for maximum overclocking and Intel® Turbo Memory technology, providing faster boot and application load times and additional power savings. Intel® P35 chipset also offer options for both DDR2 and DDR3 memory support, providing scalable options for users wanting to take advantage of higher memory performance with less power consumption to run next generation applications such as high-definition video and 3D visualization.
Daten über das Asus P5K WS Motherboard
The ASUS Workstation Series is the ideal foundation for a powerful PC. It delivers awesome power, dependable performance and unparallel I/O scalability for the most demanding tasks and future upgrades. With the incorporation of ASUS Intelligence (AI) Technology, the ASUS Workstation Series intelligently reduces operation noise and dissipates heat through advanced and environmentally friendly methods to accommodate user needs. Don´t change yourself for a computer. Instead, Let the ASUS Workstation Series improve the quality of your work and your life
spacer
Für Übertakter Details
NorskIT Artikelnummer » 110032788
Artikelnummer » TWIN2X2048-8500C5D
Modell » DDR2-1066 (XM2S-8500)
Größe » 2GB Kit (2 x 1GB)
Latenzzeit » 5-5-5-15-2T
Packungsinhalt » 240-pin DIMM
Kühlkörper » Dominator
Sin des die???????
Wo lag das Problem? Evlt. können andere User durch die Angaben profitieren ;)
ich musste die ram spannung manuell auf 2,25V anheben und 2 optionen deaktivieren dessen namen ich aber im mom nimmer weis
leider laufen die rams nur auf auto
5-5-5-18
normal hätten sie aber
5-5-5-15
hoffe ein bios update bringt abhilfe
Ob 5-5-5-15 oder 5-5-5-18 macht keinen Unterschied - zumindest keinen spürbaren. Selbst BEnchmarks reagieren hier afaik nicht drauf. Stelle doch von Hand auf 15 um und gut is ;)
wenn ich das von hand umstelle bleibt der monitor schwarz..........
warum auch immer
habe eben mit asus telefoniert die sind ja wohl keine freunde von corsair
der hotliner sagte eben kaufen sich sich bitte guten speicher und kein corsair die machen nur probleme und beschädigen unsere boards
daraus folgt das wir unzufriedene kunden haben wobei asus nix für kann
krass
Nach einer Kurzen Rücksprache mit Asus, die im Übrigen auch Kooperationspartner von uns sind, konnte man mir eigentlich zu 99% versichern, dass diese Aussage von Asus nicht so getätigt worden ist.
Mehr kann ich hier momentan leider nicht sagen da ich schlicht und einfach keine weiteren Infos dazu habe.
glaub mir er hat es gesagt
die wissen warum die keine namen nennen...........
Ich glaube dir gerne bin aber dennoch verwundert, da wir unter anderem alle unsere Module auf Asus Boards gegentesten und auch Asus all unsere Module checkt. Aus diesem Grund ist es sehr verwunderlich, dass einer der Asus Mitarbeiter sich derart äussern sollte... :rolleyes:
Noch verwunderlicher ist die Tatsache, dass es mit einer tRAS von 18 läuft - mit 15 jedoch nicht. Dieser Wert hat in der Regel keinen großen Einfluss. Wir werden dies demnach schnellstmöglich gegentesten - Asus hat die genannten Module zur Verfügung.
board siehe meine sig,spannung musste ich manuell auf 2,25v stellen damit sie auf 1066mhz laufen
bios version ist die 0401
laut asus gibts keine neuere
halte mich bitte aufm laufenden
Klar, gerne - wenn ich was Neues habe, werde ich hier berichten :bigok: ;)
Vermute aber stark, dass das ein neues Bios sicherlich beheben wird.
vielleicht geben sie dir ja ne neue bios version etc wo dann als fix drinne steht
enchanged memory combatibility..............
wäre cool
Zitat von Bluebeard
"Ich glaube dir gerne bin aber dennoch verwundert, da wir unter anderem alle unsere Module auf Asus Boards gegentesten und auch Asus all unsere Module checkt. Aus diesem Grund ist es sehr verwunderlich, dass einer der Asus Mitarbeiter sich derart äussern sollte... "
Also ich habe auch mal so eine ähnliche Aussage von der Asus Hotlinie bekommen bekommen
Die waren sehr negativ eingestellt gegenüber Corsair
Ich bin eigentlich zufrieden mit den Corsair Riegeln hatte nie Probleme mit ihnen
noch ein hotline geplagter habe nun das p5k deluxe da laufen meine domis 1A
asus hotline kannste vergessen die lügen einen zusammen das sich die balken biegen
