Atom Netbooks
manic
ich habe die Möglichkeit günstige Atom Netbooks zu bekommen, da ich aber bisher absolut keine Erfahrung mit diesen Teilen habe, stellt sich die Frage, ob bzw was man damit überhaupt machen kann.
Es gibt die folgenden Modelle:
MODELL 1
CPU: Intel Atom N270
Chipset: Intel 945GSE
Graphics: GMA 950
Display: 10.1”TFT LCM 1024x600 Pixel
Web Camera: 0.3 M pixel
Memory: 1GB (1 Slot, Max.2GB)
Storage: 160GB HDD /250GB (Option)
Battery: 3 Cell / 6 Cell 2200mAh
I/O Ports: 1*VGA
Port; 3*USB 2.0 Port;
1*RJ45 Port
1*Microphone Jack;
1*Headphone Jack
OS: Support Windows XP,
Vista, Windows 7 or Linux
MODELL 2
Chipset: nVIDIA MCP79-ION
Graphics: GF 9400M
Web Camera: 130 M pixel
Memory: 1GB (1 Slot, Max. 2GB)
Storage: 160GB HDD / 250GB (Option)
OS: Support Windows XP, Vista,
Connectivity:
I/O Ports:
1*HDMI Port;
2*USB 2.0 Port;
1*RJ45 Port
1*Microphone Jack;
1*Headphone Jack
1*MMC/SD
MODELL 3
Chipset: Intel NM10
Graphics: GMA 3150
Display: 10.2” TFT LCM 1024x600 Pixels
Web Camera: 130 MPixel
(Option)
Connectivity : Support WIFI
802.11 b/g, BT, 3G Modem
I/O Ports: 1*VGA Port; 3*USB 2.0
Port; 1*RJ45 Port1*Microphone
Jack; 1*Headphone Jack
Dimension:255mm(L)*190mm(W)*26.5mm(H)
Windows 7 or Linux
MODELL 4
CPU: Intel CULV 743 / Atom N450
Chipset: Intel GS45/GS40
Graphics: GMA 4500M
Display: 12.1” TFT LCM 1366x768 Pixels
Connectivity : Support WIFI 802.11
b/g, BT, 3G Modem
Port; 1*RJ45 Port1*Microphone Jack;
1*Headphone Jack
Dimension:
290mm(L)*205mm(W)*21~26mm(H)
Windows 7 or Linux
MODELL 5
CPU:Intel N450
Chipset:Intel NM10
Graphics:GMA 3150
13.3" TFT LCD 1366*768 Pixels
Memory:1G DDR2 SO-DIMM (Upgrade to 2G)
HDD:160G SATA-II HDD (Upgrade to 250G)
Built-in Wireless LAN, 2 Antennas, Support 802.11 B/G/N
Battery:Solid 3cell 2200mAh
1.3 Mega Pixels Camera
IO Ports:
1* 15-pin VGA Port
2*USB 2.0 port
1*Microphone jack
1*Headphone jack
1*RJ45
1*Adapter jack
MMC/SD/mini SD
MODELL 6
CPU: Intel CULV SU2300
Graphics: GMA 4500M
13.3”TFT LCM 1366x768 Pixel
Memory: 1 1GB (1 Slot, Max. 2GB)
2200mAh
Support WIFI 802.11 b/g, BT,3G Modem
Windows 7 or Linux
I/O Ports:
1*HDMI Port;
1*VGA Port;
3*USB 2.0 Port;
1*RJ45 Port
1*Microphone Jack;
1*Headphone Jack
MMC/SD/MiniSD
Sind die nur zum bissel surfen, mal einen Brief schreiben und Urlaubsfotos anschauen gut oder kann man die auch ein bisschen strapazieren?
Strapazieren im Sinne von Outlook per Exchangeserver, dabei Excel geöffnet haben und gleichzeitig im Inet surfen oder ist dafür die CPU bzw die gesamt Konfiguration überfordert?
Als Arbeits-PC nehme ich mal an sind die Teile nicht geeignet, mit Anschluss an einen externen Monitor oder?
Oder ginge das zb mit Modell 6, bei dem es sich ja um eine Celeron Dualcore CPU handelt.
THX
wie günstig ist denn "günstig" ?
Wie wäre es mit Modellnamen?
Notebooks sind mehr als die Summe ihrer Teile.
Modell würde keinen Sinn machen, da es sich um nicht um Standardmodelle handelt bzw sind "umgelabelt".
Na ja aufrund der Teile wie CPU, Ram und Graka lassen sich aber schon grundlegenede Aussagen treffen.
Was genau günstig bedeutet weiss ich selbst nicht, ich habe keinen genauen Preis.
ohne preis kann dir auch keiner sagen obs sich lohnt eines der geräte zu kaufen.
Hö?
Wo steht denn dass ich frage ob es sich lohnt zu kaufen?
Meine Frage ist die, was man damit machen kann und für welchen Einsatzzweck die Geräte ausreichen würden.
(Ob sich das dann lohnen würde kann ich dann selbst entscheiden)
Ich habe doch geschrieben dass ich noch keine Erfahrung mit Netbooks gemacht habe, sprich ich habe noch nie mit einem gearbeitet. Drum würde ich gerne so pi mal Daumen wissen, was man damit machen kann.
Modell 2 und 6 oder Modell 4 mit CULV sind interessant. Der ION hat natürlich die stärkste Grafik & der CULV die beste CPU-Leistung.
