Die Information habe ich jetzt auslesen lassen:
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name AMD A8-3870
Codename Llano
Specification AMD A8-3870 APU with Radeon(tm) HD Graphics
Package Socket FM1 (905)
CPUID F.1.0
Extended CPUID 12.1
Brand ID 22
Core Stepping LN1-B0
Technology 32 nm
TDP Limit 117 Watts
Core Speed 2994.7 MHz
Multiplier x FSB 30.0 x 99.8 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
L1 Data cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 4 x 1024 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Min FID 8.0x
Min VID 0.450 V
# of P-States 8
P-State FID 0xE - VID 0x0B - IDD 20 (30.00x - 1.412 V)
P-State FID 0xB - VID 0x0E - IDD 18 (27.00x - 1.375 V)
P-State FID 0x8 - VID 0x12 - IDD 15 (24.00x - 1.325 V)
P-State FID 0x5 - VID 0x16 - IDD 13 (21.00x - 1.275 V)
P-State FID 0x3 - VID 0x1A - IDD 12 (19.00x - 1.225 V)
P-State FID 0x20E - VID 0x1F - IDD 9 (15.00x - 1.162 V)
P-State FID 0x208 - VID 0x24 - IDD 8 (12.00x - 1.100 V)
P-State FID 0x308 - VID 0x2A - IDD 6 (8.00x - 1.025 V)
Package Type 0x2
Model 71
String 1 0x5
String 2 0x1
Page 0x0
TDC Limit 80 Amps
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
Chipset
Northbridge AMD ID1705 rev. 00
Southbridge AMD A75 rev. 11
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 8172 MBytes
Memory Frequency 532.4 MHz (3:16)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Bank Cycle Time (tRC) 27
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Team Group Inc. (7F7F7F7FEF000000)
Size 4096 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number Team-Elite-1333
Manufacturing date Week 19/Year 13
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 5.0-5-5-14-19 @ 380 MHz
JEDEC #2 6.0-6-6-17-23 @ 457 MHz
JEDEC #3 7.0-7-7-20-27 @ 533 MHz
JEDEC #4 8.0-8-8-22-30 @ 609 MHz
JEDEC #5 9.0-9-9-25-34 @ 685 MHz
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 10 0B 02 04 22 00 01 03 52 01 08 0C 00 3E 00
10 69 78 69 30 69 11 20 89 20 08 3C 3C 00 F0 83 05
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 04 EF 00 13 19 00 00 00 00 FC 37
80 54 65 61 6D 2D 45 6C 69 74 65 2D 31 33 33 33 20
90 20 20 00 00 04 EF 00 00 00 00 00 00 00 00 00 00
A0 10 13 05 08 00 1F 00 00 00 00 11 13 05 08 00 2F
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Monitoring
Mainboard Model A55M-DGS (0x00000203 - 0x009AE634)
raphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTX 750
Revision A2
Memory size 1024 MB
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x196E)
Model ID 0x1381 (0x1381)
Performance Level 2D Desktop
Core clock 405.0 MHz
Memory clock 405.0 MHz
Performance Level 3D Applications
Core clock 540.0 MHz
Memory clock 2505.0 MHz
Falls das hilft....
