Bacula Problem
NiclasM
Dortmund
Hi Leute,
ich finde einfach das Problem bei der Bacula Config nicht :mad:
Im Grunde laufen die Jobs garnicht an, obwohl ich die Stornage Deamons so normal ansprechen kann. Warscheinlich wieder eine kleinigkeit die ich vergessen habe :hmm::sick:
Code:
Director {
  Name = Dir-Address_Server-dir
  DIRport = 9101                # where we listen for UA connections
  QueryFile = "/etc/bacula/scripts/query.sql"
  WorkingDirectory = "/var/lib/bacula"
  PidDirectory = "/var/run/bacula"
  Maximum Concurrent Jobs = 1
  Password = "geheim-:)"         # Console password
  Messages = Daemon
  DirAddress = Dir-Address_Server
JobDefs {
  Name = DefaultJob
  Type = Backup
  Client = Dir-Address_Server-fd
  Storage = Dir-Address_Server
  Messages = Standard
  Pool = Standart_Automatic_Pool
  Priority = 10
  Write Bootstrap = "/var/lib/bacula/%c.bsr"
#         Server-1
Job {
  Name = "Server-1 Documents Incremental HC-Cluster"
  Client = Server-1-fd
  JobDefs = "DefaultJob"
  Enabled = yes
  Level = Incremental
  FileSet = "Server-1 Dokumente"
  Schedule = "Jeden Tag um 22:00"
  Storage = HC
  Write Bootstrap = "/var/lib/bacula/LocalhostBackup.bsr"
Job {
  Name = "Server-1 Documents Full-Backup HC-Cluster"
  Enabled = yes
  Level = Full
  Schedule = "Jeden Sonntag"
  Storage = HC
Job {
  Name = "Server-1 Documents Incremental Dir-Server_Address"
  Enabled = yes
  Level = Incremental
Job {
  Name = "Server-1 Documents Full-Backup Dir-Server_Address"
  Enabled = yes
  Level = Full
FileSet {
  Name = "Server-1 Dokumente"
  Include {
    Options {
      signature = MD5
    File = /doc
Job {
  Name = "Server-1 Daten Incremental HC-Cluster"
  Enabled = yes
  Level = Incremental
  FileSet = "Server-1 Daten"
  Storage = HC
Job {
  Name = "Server-1 Daten Full-Backup HC-Cluster"
  Enabled = yes
  Level = Full
  Storage = HC
Job {
  Name = "Server-1 Daten Incremental Dir-Server_Address"
  Enabled = yes
  Level = Incremental
Job {
  Name = "Server-1 Daten Full-Backup Dir-Server_Address"
  Enabled = yes
  Level = Full
FileSet {
  Name = "Server-1 Daten"
  Include {
    Options {
      signature = MD5
    File = /daten
#         Server-2
Job {
  Name = "Server-2 Rechnungen Incremental HC-Cluster"
  Client = Server-2-fd
  Enabled = yes
  Level = Incremental
  FileSet = "Server-2 Rechnungen"
  Storage = HC
Job {
  Name = "Server-2 Rechnungen Full-Backup HC-Cluster"
  Enabled = yes
  Level = Full
  Storage = HC
Job {
  Name = "Server-2 Rechnungen Incremental Dir-Server_Address"
  Enabled = yes
  Level = Incremental
Job {
  Name = "Server-2 Rechnungen Full-Backup Dir-Server_Address"
  Enabled = yes
  Level = Full
FileSet {
  Name = "Server-2 Rechnungen"
  Include {
    Options {
      signature = MD5
    File = /Rechnungen
#         Zeitpläne
Schedule {
  Run  = Full daily at 22:00
  Name = "Jeden Tag um 22:00"
Schedule {
  Run  = Full daily at 06:00
  Name = "Jeden Tag um 06:00"
Schedule {
  Name = "Jeden Sonntag"
  Run = Full sat at 22:00
#         Systeme Allgemein
Client {
  Name = Dir-Address_Server-fd
  Address = localhost
  FDPort = 9102
  Catalog = MyCatalog
  Password = "geheim-:)"          # password for FileDaemon
  File Retention = 30 days            # 30 days
  Job Retention = 6 months            # six months
  AutoPrune = yes                     # Prune expired Jobs/Files
Client {
  Name = Server-2-fd
  Address = Server-2-system.dyndns.org
  FDPort = 9102
  Catalog = MyCatalog
Client {
  Name = Server-1-fd
  Address = Server-1
  FDPort = 9102
  Catalog = MyCatalog
#         Stornage
Storage {
  SDPort = 9103
  Device = FileStorage
  Media Type = File
Storage {
  Name = Secure-1
  Address = Server3
  SDPort = 9103
  Device = HDD-1
  Media Type = File
Storage {
  Name = HC
  Address = HC-Server-Address
  SDPort = 9103
  Device = FileStornage
  Media Type = File
#         Extra
FileSet {
  Name = "Catalog"
  Include {
    Options {
      signature = MD5
    File = "/var/lib/bacula/bacula.sql"
Catalog {
  Name = MyCatalog
  dbname = "bacula"; dbuser = ""; dbpassword = ""
Messages {
  Name = Standard
  append = "/var/lib/bacula/log" = all, !skipped
  catalog = all
# Message delivery for daemon messages (no job).
Messages {
  Name = Daemon
  mailcommand = "/usr/lib/bacula/bsmtp -h localhost -f \"\(Bacula\) \<%r\>\" -s \"Bacula daemon message\" %r"
  mail = root@localhost = all, !skipped
  console = all, !skipped, !saved
# Default pool definition
Pool {
  Name = Default
  Pool Type = Backup
  Recycle = yes                       # Bacula can automatically recycle Volumes
  AutoPrune = yes                     # Prune expired volumes
  Volume Retention = 365 days         # one year
Pool {
  Name = Standart_Automatic_Pool
  Pool Type = Backup
  Recycle = yes
  Volume Use Duration = 23h
  UseVolumeOnce = yes
  AutoPrune = yes
  LabelFormat = "Automatical-Pool"
  Maximum Volumes = 10000
# Scratch pool definition
Pool {
  Name = Scratch
  Pool Type = Backup
Console {
  Name = Dir-Address_Server-mon
  CommandACL = status, .status
Error Log von heute
13-Aug 00:33 DIR-dir JobId 36: Using Device "FileStorage"
13-Aug 01:05 Server-fd JobId 36: Fatal error: Failed to connect to Storage daemon: DIR:9103
13-Aug 01:03 DIR-dir JobId 36: Fatal error: Bad response to Storage command: wanted 2000 OK storage
, got 2902 Bad storage
