Bluescreen mögliche Probleme
doctorultra
Experte
Mein PC ist übertaktet, liegt es vielleicht am Speicher?
Code:
Microsoft (R) Windows Debugger Version 10.0.17674.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\070718-7390-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 17134 MP (16 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 17134.1.amd64fre.rs4_release.180410-1804
Machine Name:
Kernel base = 0xfffff803`a4a0c000 PsLoadedModuleList = 0xfffff803`a4dc61f0
Debug session time: Sat Jul  7 11:52:45.976 2018 (UTC + 2:00)
System Uptime: 0 days 14:45:51.721
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 139, {0, 0, 0, bb0cba10}
Probably caused by : ntkrnlmp.exe ( nt!guard_icall_bugcheck+1b )
Followup:     MachineOwner
nt!KeBugCheckEx:
fffff803`a4ba4330 48894c2408      mov     qword ptr [rsp+8],rcx ss:0018:fffff803`a705c8e0=0000000000000139
0: kd> !analyze -v
KERNEL_SECURITY_CHECK_FAILURE (139)
A kernel component has corrupted a critical data structure.  The corruption
could potentially allow a malicious user to gain control of this machine.
Arguments:
Arg1: 0000000000000000, A stack-based buffer has been overrun.
Arg2: 0000000000000000, Address of the trap frame for the exception that caused the bugcheck
Arg3: 0000000000000000, Address of the exception record for the exception that caused the bugcheck
Arg4: 00000000bb0cba10, Reserved
Debugging Details:
KEY_VALUES_STRING: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING:  17134.1.amd64fre.rs4_release.180410-1804
SYSTEM_MANUFACTURER:  System manufacturer
SYSTEM_PRODUCT_NAME:  System Product Name
SYSTEM_SKU:  SKU
SYSTEM_VERSION:  System Version
BIOS_VENDOR:  American Megatrends Inc.
BIOS_VERSION:  4011
BIOS_DATE:  04/19/2018
BASEBOARD_MANUFACTURER:  ASUSTeK COMPUTER INC.
BASEBOARD_PRODUCT:  PRIME X370-PRO
BASEBOARD_VERSION:  Rev X.0x
DUMP_TYPE:  2
BUGCHECK_P1: 0
BUGCHECK_P2: 0
BUGCHECK_P3: 0
BUGCHECK_P4: bb0cba10
TRAP_FRAME:  0000000000000000 -- (.trap 0x0)
EXCEPTION_RECORD:  0000000000000000 -- (.exr 0x0)
Cannot read Exception record @ 0000000000000000
CPU_COUNT: 10
CPU_MHZ: e6d
CPU_VENDOR:  AuthenticAMD
CPU_FAMILY: 17
CPU_MODEL: 1
CPU_STEPPING: 1
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
BUGCHECK_STR:  0x139
PROCESS_NAME:  System
CURRENT_IRQL:  2
ANALYSIS_SESSION_HOST:  PC-GROESER
ANALYSIS_SESSION_TIME:  07-07-2018 12:12:08.0868
ANALYSIS_VERSION: 10.0.17674.1000 amd64fre
LAST_CONTROL_TRANSFER:  from fffff803a4bac90b to fffff803a4ba4330
STACK_TEXT:
fffff803`a705c8d8 fffff803`a4bac90b : 00000000`00000139 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
fffff803`a705c8e0 fffff803`a4aa5ff7 : ffffffff`ffffffff fffff803`a705ca10 00000000`0002625a 00000000`00000000 : nt!guard_icall_bugcheck+0x1b
fffff803`a705c910 fffff803`a4aa564b : 00000000`00000018 00000000`00000000 00000000`003707e6 00000000`00000019 : nt!KiExecuteAllDpcs+0x2e7
fffff803`a705ca50 fffff803`a4ba7a8a : 00000000`00000000 fffff803`a3532180 00000000`001a6560 fffff803`a4e83400 : nt!KiRetireDpcList+0x1db
fffff803`a705cc60 00000000`00000000 : fffff803`a705d000 fffff803`a7057000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
THREAD_SHA1_HASH_MOD_FUNC:  1768079eea2f1f670377627e597f76dcc286def9
THREAD_SHA1_HASH_MOD_FUNC_OFFSET:  f8d2a0f9135e0b64acdc61708343d3fdbdea700d
THREAD_SHA1_HASH_MOD:  f08ac56120cad14894587db086f77ce277bfae84
FOLLOWUP_IP:
fffff803`a4bac90b 90              nop
FAULT_INSTR_CODE:  ccccc390
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!guard_icall_bugcheck+1b
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  5b1a4590
IMAGE_VERSION:  10.0.17134.112
STACK_COMMAND:  .thread ; .cxr ; kb
BUCKET_ID_FUNC_OFFSET:  1b
FAILURE_BUCKET_ID:  0x139_0_LEGACY_GS_VIOLATION_nt!guard_icall_bugcheck
PRIMARY_PROBLEM_CLASS:  0x139_0_LEGACY_GS_VIOLATION_nt!guard_icall_bugcheck
TARGET_TIME:  2018-07-07T09:52:45.000Z
OSBUILD:  17134
OSSERVICEPACK:  112
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK:  272
PRODUCT_TYPE:  1
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
OSEDITION:  Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID:  0
OSBUILD_TIMESTAMP:  2018-06-08 11:00:00
BUILDDATESTAMP_STR:  180410-1804
BUILDLAB_STR:  rs4_release
BUILDOSVER_STR:  10.0.17134.1.amd64fre.rs4_release.180410-1804
ANALYSIS_SESSION_ELAPSED_TIME:  8b84
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:0x139_0_legacy_gs_violation_nt!guard_icall_bugcheck
FAILURE_ID_HASH:  {9bee41a7-2ef9-07ca-7e59-7d5a0c6e2d05}
Was hast du den für ein System genau, bitte mal auflisten...
Windows 10 Asus X370 Prime Mainboard/ GSKill Flare X 3200 RAM/ Samsung SSD 840, Grafikkarte 1050Ti braucht Ihr noch mehr Info?
Es kann am Speicher liegen, wie hoch ist den CPU und Speicher übertaktet, hast du mal alles auf stock probiert, treten dann auch Fehler auf?
den Speicher habe ich auf 3200 im Bios eingestellt, weil es auch ein 3200 ist. DOCP Profil. Den Prozessor habe ich von 3000 auf 3700 hochgetaktet?
Wann treten die Bluescreens denn auf unter Belastung, dann könnte die CPU Spannung zu gering sein …
Ich würde die raten die CPU erstmal stock zu betreiben, um zu schauen, ob der Ram stabil läuft.
Nehme an du hast einen 1700, 3700mhz könnten schon mehr Spannung brauchen.
Füll doch mal die Systeminfo komplett aus, so ist es anderen einfacher die zu helfen ...
Ja klick mal oben rechts auf deinen nick dann kannst du alles eintragen ...
