Bluescreen unter Win7
GreenStorm
Ja, es gibt sie immernoch :fresse:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7100.2.0.0.256.1
Locale ID: 1031
Additional information about the problem:
BCCode: 124
BCP1: 0000000000000000
BCP2: FFFFFA800618E028
BCP3: 00000000B2000040
BCP4: 0000000000000800
OS Version: 6_1_7100
Service Pack: 0_0
Product: 256_1
Kann mir da wer weiterhelfen ?
edit: Mithilfe von so nem Debugging-Tool für Vista kam ich hierbei raus:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\060209-27440-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
WARNING: Whitespace at start of path element
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is: c:\windows\System32; c:\windows\system\System32; http://www.alexander.com/SymServe
Windows 7 Kernel Version 7100 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7100.0.amd64fre.winmain_win7rc.090421-1700
Machine Name:
Kernel base = 0xfffff800`02a4b000 PsLoadedModuleList = 0xfffff800`02c84e90
Debug session time: Tue Jun 2 01:47:51.338 2009 (GMT+2)
System Uptime: 1 days 9:30:12.257
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
.Missing image name, possible paged-out or corrupt data.
...Missing image name, possible paged-out or corrupt data.
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa800618e028, b2000040, 800}
Probably caused by : hardware
Followup: MachineOwner
2: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800618e028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b2000040, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000800, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_GenuineIntel
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: f
STACK_TEXT:
fffff880`02f6ba58 fffff800`02a146d3 : 00000000`00000124 00000000`00000000 fffffa80`0618e028 00000000`b2000040 : nt!KeBugCheckEx
fffff880`02f6ba60 fffff800`02bccc53 : 00000000`00000001 fffffa80`0618fd30 00000000`00000000 fffffa80`0618fd80 : hal!HalBugCheckSystem+0x1e3
fffff880`02f6baa0 fffff800`02a14398 : 00000000`00000728 fffffa80`0618fd30 fffff880`02f6be30 fffff880`02f6be00 : nt!WheaReportHwError+0x263
fffff880`02f6bb00 fffff800`02a13cea : fffffa80`0618fd30 fffff880`02f6be30 fffffa80`0618fd30 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`02f6bc50 fffff800`02a13ba5 : 00000000`00000004 00000000`00000001 fffff880`02f6beb0 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`02f6bc90 fffff800`02a07ea8 : 00000000`23e9530c 00000000`00000001 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55
fffff880`02f6bcc0 fffff800`02ac882c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff880`02f6bcf0 fffff800`02ac8693 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`02f6be30 fffff800`02ad3ce6 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
fffff880`03316860 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeFlushMultipleRangeTb+0x266
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel__UNKNOWN
2: kd> lmvm hardware
start end module name
Es war zu betreffendem Moment relativ warm im Zimmer (evtl 30°C) - ich hab die These aufgestellt, dass es die Northbridge oder sowas sein könnte ?
Schönes Tool - hab ich auch schon genutzt - aber in deinem Fall leider nicht sehr aussagekräftig.
Lässt imho einfach nur auf einen Hardwarefehler schließen und kann genaugenommen alles sein.
Wenn du die NB oder sonstiges auf Grund der Temperaturen in deinem Zimmer in Verdacht hast, wäre es sehr hilfreich die Temps deines Systems zu kennen.
Hast du das Gefühl, dass die NB zu heiß wird könntest du im Sammelthread zu deinem MB nachschauen welche Werte die anderen User haben.
Außerdem entnehme ich deiner Signatur, dass du OC anliegen hast, was es nicht einfacher macht den Fehler zu finden.
Läuft das Sys schon länger stabil mit diesen Werten?
Ja, das System läuft eigentlich komplett stabil mit diesen Werten, schon seit.. Mitte 2008 oder sowas
Ich bin in letzter Zeit des öfteren über Aussagen gestolpert, dass unter Win 7 bei OC der CPU die Vcore erhöht werden musste.
Nicht unbedingt viel, aber immerhin - denn sonst lief das Sys nicht mehr stabil.
Pass dein OC mit Win 7 mal an (die üblichen Stabilitätstests etc.) und schau ob dein Problem dann verschwindet ;)
Machine Check Exception deutet doch schon darauf hin :fresse:
Dabei wird es sich mit hoher Wahrscheinlichkeit nicht um ein Problem am Systembus oder dem RAM handeln, vielmehr Cache vom Prozzi. Mögliche Ursachen wären: (wie schon weiter oben genannt, zu hohe Temps, OC und zu wenig VCore) ein überlastetes NT
zu hohe Temps sind mit dem Mugen sehr unwahrscheinlich :fresse:
Der Rechner ist abgeschmiert als wir nen Film geschaut haben, da war die CPU quasi idle und die wird auch unter Last nicht wärmer als ~50°C
Atm sind die Temps auf
Core1: 40°C
Core2: 37°C
Core3: 35°C
Core4: 35°C
Aber ich hab jetzt mal die Vcore um zwei "Stufen" nach oben gestellt, bin nu auf 1.152 Vcore, und bisher noch kein Absturz.. aber ich hab Win7 schon seit gut 1.5 Monaten laufen, und hatte mir der alten Config auch keinen Absturz..
edit: das waren die Temps von Everest, CoreTemp gibt mir sogar noch niedrigere Daten :fresse:
Core0: 36°C
Core1: 33°C
Core2: 30°C
Core3: 30°C
wie gesagt, bios auf standard und schauen ob es was bringt.
wenn nicht ist es irgend ein treiber der schlecht programmiert ist.
wenn nicht ist hardware defekt oder inkompatible
