Brenner brennt nicht!!!
khebmxpepe
Hamberge / MV
mein Lite On will einfach keine CDs brennen!!! immer n Error:
hier mal die komplette LOG:
WinAspi: -
ahead WinASPI: File 'C:\Programme\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 25.06.2002 17:34:54
Nero Version: 5.5.9.14
Recorder: <LITE-ON LTR-52246S> Version: 6S0D - HA 1 TA 0 - 5.5.9.14
Adapter driver: <> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <TOSHIBA DVD-ROM SD-M1712>Version: 1004 - HA 0 TA 1 - 5.5.9.14
Adapter driver: <nvidesm> HA 0
=== Scsi-Device-Map ===
DiskPeripheral : IC35L120AVV207-1 V24O nvidesm Port 0 ID 0 DMA: ?
CdRomPeripheral : LITE-ON LTR-52246S 6S0D nvidesm Port 0 ID 0 DMA: ?
CdRomPeripheral : TOSHIBA DVD-ROM SD-M17121004 nvidesm Port 0 ID 1 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523764kB)
Free physical memory: 290MB (297012kB)
Memory in use : 43 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: On
21.6.2003
CD-ROM (ISO)
11:29:06 #1 Text 0 File Isodoc.cpp, Line 6887
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
11:29:06 #2 Phase 90 File dlgbrnst.cpp, Line 1571
Buffer Underrun Protection activated
11:29:06 #3 Text 0 File Reader.cpp, Line 118
Reader running
11:29:06 #4 Text 0 File Writer.cpp, Line 127
Writer LITE-ON LTR-52246S running
11:29:06 #5 ISO9660GEN -11 File geniso.cpp, Line 4484
First writeable address = 0 (0x00000000)
11:29:06 #6 Text 0 File Burncd.cpp, Line 3588
Turn on Track-At-Once, using CD-R/RW media
11:29:06 #7 Text 0 File ThreadedTransferInterface.cpp, Line 660
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 52969 (52969) = #52969/11:46.19
relocatable, CD pos for caching/writing not required/required, no patch infos
11:29:07 #8 Text 0 File DlgWaitCD.cpp, Line 203
Last possible write address on media: 359847 (79:59.72)
Last address to be written: 52968 (11:48.18)
11:29:07 #9 Text 0 File DlgWaitCD.cpp, Line 208
Write in overburning mode: FALSE
11:29:07 #10 Text 0 File DlgWaitCD.cpp, Line 1420
Recorder: LITE-ON LTR-52246S;
CDRW code: 00 97 26 26; OSJ entry from: SKC Co., Ltd.
ATIP Data:
Special Info [hex] 1: C0 00 80, 2: 61 1A 1A (LI 97:26.26), 3: 4F 3B 49 (LO 79:59.73)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
11:29:07 #11 Text 0 File ThreadedTransferInterface.cpp, Line 812
Prepare recorder LITE-ON LTR-52246S for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close Session
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 108787712
11:29:07 #12 Text 0 File ThreadedTransferInterface.cpp, Line 840
Removed 2 run-out blocks from end of track 1.
11:29:07 #13 Text 0 File ThreadedTransferInterface.cpp, Line 660
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 52967 blocks [LITE-ON LTR-52246S ]
11:29:07 #14 Phase 24 File dlgbrnst.cpp, Line 1571
Caching of files started
11:29:08 #15 Phase 25 File dlgbrnst.cpp, Line 1571
Caching of files completed
11:29:08 #16 Phase 36 File dlgbrnst.cpp, Line 1571
Burn process started at 52x (7.800 KB/s)
11:29:08 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1948
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
11:29:08 #18 Text 0 File Mmc.cpp, Line 17168
Set BUFE: supported -> ON , SMART-BURN : ON
11:29:15 #19 SCSI -500 File Cdrdrv.cpp, Line 1381
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02620000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
11:29:15 #20 CDR -500 File Writer.cpp, Line 335
SCSI/IDE Command aborted
11:29:15 #21 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
11:29:19 #22 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
11:29:19 #23 CDR -201 File WriterStatus.cpp, Line 188
Invalid write state
11:29:19 #24 TRANSFER -18 File WriterStatus.cpp, Line 188
Could not perform EndTrack
11:29:19 #25 Phase 38 File dlgbrnst.cpp, Line 1571
Burn process failed at 52x (7.800 KB/s)
11:29:19 #26 Text 0 File Scsicmd.cpp, Line 402
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\nvidesm.sys': Ver=5.10.2600.0307 built by: WinDDK, size=20224 bytes, created 13.11.2002 09:10:00 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
ach du sheiße! hast du Aspit Treiber geladen oder mal eine andere Software ausprobiert?
mal nen anderen Apsi Treiber?
ich weiß nicht ob das jetzt wirklich hilft aber, haste mal einen anderen ASPI Treiber ausprobiert!
hier gibst 4 verschiedene
wenn nicht einfach mal testen!
achso haste dir mal "Kill ASPI" besorgt! sollte man immer ausführen bevor man nen neuen ASPI Treiber drauf haut!
soll angeblich alle reste des alten entfernen und konflikte vermeiden!
das seltsame ist, dass ich vor n paar tagen noch von CD zu CD kopieren konnte, nur ich hab auch kein plan ob ich danach was neues reingehaun habe...
kann manchmal mein Board spinnen? (abit nf7)
und wieso wird die pladde als SCSI erkannt... ís se doch gar net..
es geht wieder!!!!
Lösung:
einfach die alten (standard) IDE Controller Treiber installieren und den NForce kack raushauen...!
ich hab ma ne frage zu den aspi treiber
und zwar ist es bei mir so das clony xxl immer sagt, das keine aspi treiber gefunden werden können ... welche muss mann denn dann installieren
hab auch n nforce hip satz nur bei mir is das so, das ich die nforce kacke ;) brauche da sonst mein brenner nicht im dma modus läuft
danke schon mal
musst du die aspi- treiber 4.* installieren. Erst setup ausführen und dann ein Update
