schiller.uwe
Brenner LG GSA 2164D USB FW 1.01 macht probleme mit DVDs
Benutze DVD+R von Platinum 4,7 GB 8xSpeed
Bekomme bei FAST AUSSCHLIEßLICH jeden DVD Brennvorgang eine Fehlermeldung zb
non Seek Complete oder beim Kopieren der DVD CRC Fehler, ich hab hier auch Log auszüge von Alcohol und Nero 6...
NERO 6
11:08:20 #14 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
11:08:20 #15 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 4x (5.520 KB/s)
11:08:20 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
11:08:20 #17 Text 0 File Cdrdrv.cpp, Line 7912
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 03 52 49 54 45 4B 00 - 00 00 52 30 33 02 38 23 ..RITEK...R03.8#
54 37 09 00 3C 65 00 A0 - 5F 14 14 0A 0A 0A 0A 01 T7..<e.._.......
19 1B 0B 0B 0E 0F 01 00 - 00 00 00 00 00 00 00 01 ................
11:08:20 #18 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 12:56,269 (776269ms) -> OK
11:08:20 #19 Text 0 File DVDPlusRW.cpp, Line 603
Start write address at LBA 0
DVD high compatibility mode: No
11:09:11 #20 SCSI -1119 File Cdrdrv.cpp, Line 1430
SCSI Exec, HA 5, TA 0, LUN 0, buffer 0x05420000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0xD3 0x40 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x09 0x03
11:09:11 #21 CDR -1119 File Writer.cpp, Line 301
Track following error
11:09:11 #22 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
11:09:11 #23 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
11:09:12 #24 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
11:09:12 #25 Text 0 File dlgbrnst.cpp, Line 1658
11:09:12 #26 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 4x (5.520 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 3.8.2004 21:59:44 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
20:10:12 #12 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
20:10:12 #13 Text 0 File Burncd.cpp, Line 4061
Cache writing successful.
20:10:12 #14 Phase 25 File dlgbrnst.cpp, Line 1800
20:10:12 #15 Phase 36 File dlgbrnst.cpp, Line 1800
20:10:12 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264
20:10:12 #17 Text 0 File Cdrdrv.cpp, Line 7912
Media Specific:
00 03 43 4D 43 20 4D 41 - 47 00 45 30 31 00 38 23 ..CMC.MAG.E01.8#
54 37 10 02 38 6A 02 88 - 67 15 15 0B 0B 08 08 01 T7..8j..g.......
19 1B 0C 0C 0C 0D 01 00 - 00 00 00 00 00 00 00 01 ................
20:10:12 #18 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 6:41,649 (401649ms) -> OK
20:10:12 #19 Text 0 File DVDPlusRW.cpp, Line 603
20:10:57 #20 SCSI -1093 File Cdrdrv.cpp, Line 1430
SCSI Exec, HA 5, TA 0, LUN 0, buffer 0x03A80000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x85 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x02 0x00
20:10:57 #21 CDR -1093 File Writer.cpp, Line 301
No seek complete
20:10:57 #22 Text 0 File ThreadedTransfer.cpp, Line 229
20:10:57 #23 Text 0 File ThreadedTransfer.cpp, Line 223
20:10:57 #24 Text 0 File dlgbrnst.cpp, Line 1658
20:10:57 #25 Text 0 File dlgbrnst.cpp, Line 1658
20:10:57 #26 Phase 38 File dlgbrnst.cpp, Line 1800
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.18a, size=20576 bytes, created 19.7.2005 10:37:12 (Prassi/Veritas driver for win 2K)
Registry Keys:
====== *** Nero-Burning Rom, History File *** ======
Jetz Alcohol
(L
HL-DT-ST DVDRRW GSA-2164D(5:0) detail information.
Vendor Identification: HL-DT-ST
Product Identification: DVDRRW GSA-2164D
Production Revision Level: 1.01
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), DVD DAO
BURN-Free Technology: Unknown
Auto-Select best write speed: Not Supported
*** NOT listed in Alcohol's database. Please report to development team
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: Yes/Yes
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: No
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: No
R-W De-interleaved and Corrected: No
C2 Pointers Support: No
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
###################### Source Disc/Image Information ######################
Type: Standard ISO Image file
Path: D:\Ba1\
Session: 1
Track: 1
Session 01:
Track 01: DVD, Length: 1721360(3.28 GB), Address: 000000
####################### Dumping/Recording Progress Log #######################
********* Time stamp of this log file: 24.1.2007 15:53:11 *********
15:53:11 Processor info: Intel(R) Pentium(R) 4 CPU 2.80GHz x 2 (3282MHz)
15:53:11 Memory Available to Windows: 1.048.044 KB
15:53:11 Memory Buffer size: 128 MB
15:53:11 Image file loading: D:\.iso
15:53:11 DVD Source Info: Session: 1, Track: 1, Length: 3.28 GB / 382:31:35
15:53:13 (L
HL-DT-ST DVDRRW GSA-2164D(5:0): Recording Method/Speed
15:53:13 Recording - DVD DAO - 4.0X (5540 KB/Sec)
(L
HL-DT-ST DVDRRW GSA-2164D(5:0) - Media format: DVD+R
15:53:58 (L
HL-DT-ST DVDRRW GSA-2164D(5:0) - [Write ERROR] LBA: 24736, Length: 16
S:KEY - 04/09/03 - "Spindle Servo Failure"
15:53:58 (L
HL-DT-ST DVDRRW GSA-2164D(5:0): Recording failed!
15:53:58 Error message: [04/09/03] - Spindle Servo Failure
15:53:58 (L
15:53:58 Image file loading aborted!
15:54:00 Something is wrong with the recording procedure! Please check the log file and report any errors to Technical Support.
Könnt ihr mir Helfen Liegt es an den DVDs ist ja ein Multiformatbrenner, CDs Funktionieren Ohne Probs
mfg Christian
PS Habe noch ein Problem
wenn ich eine CD in irgendein Laufwerk von meinen 3 einlege und Draufklicke
hängt sich mein PC auf das Passiert auch bei meinen Virtuellen LW.
habe schon SF cleaner Draufgemacht aber es hilft nichts
Bitte helft mir weiter.
NERO 6
Media Specific:
Sense Code: 0x09
Sense Qual: 0x03
Existing drivers:
Registry Keys:
Media Specific:
Sense Code: 0x02
Sense Qual: 0x00
No seek complete
Existing drivers:
Registry Keys:
Jetz Alcohol
(L
HL-DT-ST DVDRRW GSA-2164D(5:0) detail information.///////////////////////////////////////////////////////////////////////
Test Write: Yes
DVD-ROM Read: Yes
Audio Play: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
R-W Supported: No
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
Path: D:\Ba1\
Session: 1
Track: 1
Session 01:
15:53:13 (L
HL-DT-ST DVDRRW GSA-2164D(5:0): Recording Method/Speed15:53:13 Recording - DVD DAO - 4.0X (5540 KB/Sec)
(L
HL-DT-ST DVDRRW GSA-2164D(5:0) - Media format: DVD+R 15:53:58 (L
HL-DT-ST DVDRRW GSA-2164D(5:0) - [Write ERROR] LBA: 24736, Length: 16S:KEY - 04/09/03 - "Spindle Servo Failure"
15:53:58 (L
HL-DT-ST DVDRRW GSA-2164D(5:0): Recording failed!15:53:58 Error message: [04/09/03] - Spindle Servo Failure
15:53:58 (L
HL-DT-ST DVDRRW GSA-2164D(5:0): Recording failed!15:53:58 Image file loading aborted!
mfg Christian
