BSOD >>> EXCEPTION_CODE: (NTSTATUS) 0xc0000005
snOwmaster
servus leude,
momentan plagen mich immer wider mal diverse bluescreens.
einer davon z.b. "EXCEPTION_CODE: (NTSTATUS) 0xc0000005"
speicher und platte hab ich schon gecheckt, war aber unauffälig.
hier mein sys:
http://www.sysprofile.de/id17948
p.s.: momentan läuft alles auf standard takt/spannung
wenn das helfen kann hab ich hier mal den output von "WinDbg":
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, 8060e457, 98876c3c, 0}
Probably caused by : ntoskrnl.exe ( nt!HvpEnlistFreeCell+d3 )
Followup: MachineOwner
0: kd> !analyze -v
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 8060e457, The address that the exception occurred at
Arg3: 98876c3c, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in "0x%08lx" verweist auf Speicher in "0x%08lx". Der Vorgang "%s" konnte nicht auf dem Speicher durchgef hrt werden.
FAULTING_IP:
8060e457 895004 mov dword ptr [eax+4],edx
TRAP_FRAME: 98876c3c -- (.trap 0xffffffff98876c3c)
ErrCode = 00000002
eax=00000000 ebx=e4589420 ecx=e4589420 edx=00000218 esi=e4289ee0 edi=00000210
eip=8060e457 esp=98876cb0 ebp=98876cb8 iopl=0 nv up ei pl zr na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
nt!HvpEnlistFreeCell+0xd3:
8060e457 895004 mov dword ptr [eax+4],edx ds:0023:00000004=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x8E
PROCESS_NAME: Setup.EXE
LAST_CONTROL_TRANSFER: from 8060e557 to 8060e457
STACK_TEXT:
98876cb8 8060e557 88e2f3c0 00000210 e4589420 nt!HvpEnlistFreeCell+0xd3
98876cd8 805bc30e e4289ee0 00000210 e4589420 nt!HvpEnlistFreeCell+0x24c
98876cfc 805bc3dd e4289ee0 e4622de0 00000210 nt!NtCreatePagingFile+0x6a3
98876d44 805bc515 00000210 00000001 00000000 nt!MiZeroPageFileFirstPage+0x59
98876d58 8054162c 00000210 026afd18 7c91e4f4 nt!IopCompleteDumpInitialization+0xe3
98876d64 7c91e4f4 badb0d00 026afd14 98fc4d98 nt!RtlIpv4StringToAddressExW+0xad
WARNING: Frame IP not in any known module. Following frames may be wrong.
98876d78 00000000 00000000 00000000 00000000 0x7c91e4f4
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt!HvpEnlistFreeCell+d3
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntoskrnl.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 48a3fbd9
FAILURE_BUCKET_ID: 0x8E_nt!HvpEnlistFreeCell+d3
greetz,
der sn0wmaster
ist aber auch ne andere Meldung:
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
hier ist meine:
Memtest 86+ ?
Windows CHKDSK oder Tool vom Platten Hersteller?
dann las mal prime95 laufen den Prozessor test 4 Stunden ob das auch durchläüft.
yop, Memtest 86+ und chkdsk ohne Fehler.
Prime werde ich mal versuchen.
So, hab heute während ich in der Arbeit war Prime95 (Blend Test) für ca. 11 Stunden laufen lassen.
Als ich nach hause gekommen bin war noch alles in Ordnung, also kein Absturz.
irgendwelche Ideen was ma noch machen könnte?
Ram ist OK,
Platten sind 0K
CPU ist auch OK
Bleibt noch die Graka.
Da würde ich aber auch eher auf ein Treiber Problem tippen.
Graka treiber usw.
Was steht denn direkt bei dem Bluescrenn bei? welcher Sys., dll. oder andere Datei den Fehler verursacht. und den Fehlercode
Also nicht von von "WinDbg" obwohl da ja auch schon was von Treibern steht.
