Call of Duty 1+UO Graka-Treiber Problem?
Robby
..ja..ehm?
Plettenberg (NRW)
Hallo bekomme folgende Fehlermeldung:
CODUO MP 1.41 build win-x86 Aug 23 2004
----- FS_Startup -----
Current language: english
Current search path:
C:\Program Files (x86)\Call of Duty\uo\pakuo06.pk3 (12 files)
C:\Program Files (x86)\Call of Duty\uo\pakuo05.pk3 (3 files)
C:\Program Files (x86)\Call of Duty\uo\pakuo04.pk3 (7646 files)
C:\Program Files (x86)\Call of Duty\uo\pakuo03.pk3 (2275 files)
C:\Program Files (x86)\Call of Duty\uo\pakuo02.pk3 (790 files)
C:\Program Files (x86)\Call of Duty\uo\pakuo01.pk3 (1652 files)
C:\Program Files (x86)\Call of Duty\uo\pakuo00.pk3 (6231 files)
C:\Program Files (x86)\Call of Duty/uo
C:\Program Files (x86)\Call of Duty\main\pakb.pk3 (60 files)
C:\Program Files (x86)\Call of Duty\main\paka.pk3 (41 files)
C:\Program Files (x86)\Call of Duty\main\pak9.pk3 (149 files)
C:\Program Files (x86)\Call of Duty\main\pak8.pk3 (235 files)
C:\Program Files (x86)\Call of Duty\main\pak6.pk3 (3 files)
C:\Program Files (x86)\Call of Duty\main\pak5.pk3 (4858 files)
C:\Program Files (x86)\Call of Duty\main\pak4.pk3 (1668 files)
C:\Program Files (x86)\Call of Duty\main\pak3.pk3 (1992 files)
C:\Program Files (x86)\Call of Duty\main\pak2.pk3 (694 files)
C:\Program Files (x86)\Call of Duty\main\pak1.pk3 (2642 files)
C:\Program Files (x86)\Call of Duty\main\pak0.pk3 (12816 files)
C:\Program Files (x86)\Call of Duty/main
C:\Program Files (x86)\Call of Duty\uo\localized_english_pakuo00.pk3 (2578 files)
localized assets pak file for english
File Handles:
51370 files in pk3 files
execing default_mp.cfg
couldn't exec language.cfg
couldn't exec uoconfig_mp.cfg
couldn't exec autoexec_mp.cfg
========= autoconfigure
configure_mp.csv: using configuration 2200 cpu MHz 256 sys MB 256 vid MB
execing configure_mp.cfg
fs_basegame is write protected.
fs_basepath is write protected.
fs_homepath is write protected.
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Measured CPU speed is 2.80 GHz
System memory is 1024 MB (capped at 1 GB)
Video card memory is 1024 MB
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
Hostname: Robby-PC
IP: 192.168.1.102
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\Windows\system32\opengl32.dll' ): succeeded
...setting mode 6: 1024 768 FS
...using colorbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (1024x768)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...113 PFDs found
...hardware acceleration found
...PIXELFORMAT 9 selected
...creating GL context: succeeded
...making context current: succeeded
NVIDIA detectedInitializing OpenGL extensions
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce 8800 GTS/PCI/SSE2
GL_VERSION: 2.1.1
GL_EXTENSIONS: GL_EXT_bgra GL_WIN_swap_hint
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
EXE_ERR_VIDEOCARD_MISSING_FEATURE
EXE_ERR_GET_NEWEST_DRIVERS
System:
Core 2 Duo E6300@ 2x2,8Ghz
2GB Ram 800er
8800GTS 640MB
Vista HP 64bit
Wär nett wenn mir jemand helfen könnte! :bigok:
Hast du überhaupt Treiber für deine Graka installiert? Die bei Windows dabei sind, sind nicht ausreichend.
MfG
Fragman
Sry for Doppelpost:
Aber keiner ne Idee?
Hab mittlerweile auch andere Treiber ausprobiert, aber geht immer nocht nicht!
Hast du schonmal geschaut, ob Call of Duty Probleme mit Vista 64 macht? Da sind ja noch nicht alle Anwendungen zu kompatibel.
MfG
Fragman
Hab über Google eine Kompatibilitätsliste hier im Board gefunden, und da scheint es keine Probleme zu geben :hmm:
