Es Hat Geklappt mit 172 FSB*11=1893 MHZ bei 1,80 Volt er läuft jetzt seit 2 Stunden Stabil mal sehen wie lange......Wenn er einen 24 Stunden Stress Test übersteht dann werde ich meine Werte bei nethands ändern......Danke für die Tipps......
General
Program Name
SiSoftware Sandra Standard [Web]
Program Version
2002.1.8.59
Registered User
Deno
Registered Company
Unknown
Licence Status
Unregistered Shareware Evaluation Copy. FREE for personal use.
Licence Extra
See Ordering Document for information on the Professional version.
Report Done By
DENO
Host Name
DENO-7YMVUIFHE6
System ID
33565DF0-C390-4693-B692-D59987217C7F
Run ID
366881F3-740F-4b14-B658-DE1865443127
Report Done On
Samstag, 18. Mai 2002
Report Done At
00:05:25
CPU & BIOS Information
System BIOS
System BIOS
Manufacturer
Award Software International, Inc.
Version
6.00 PG
Date
03/26/2002
Plug & Play Version
1.00
SMBIOS/DMI Version
2.20
(EE)PROM Size
256kB (2Mbit)
Features
Can be Updated (flashed)
Yes
Can be Shadowed
Yes
Is Socketed
Yes
Supports APM
Yes
Supports ACPI
Yes
Supports Plug & Play
Yes
Supports ESCD
Yes
Supports Enhanced Disk Drive
Yes
Supports Selective Booting
Yes
Supports LS-120 Boot
Yes
Supports ZIP Boot
Yes
NEC PC-98 Spec Compatible
No
Performance Tips
Notice N224
SMBIOS/DMI information may be inaccurate.
Tip T207
A SMBIOS/DMI 2.3 or later compliant BIOS is recommended. Check for a BIOS update.
Tip T212
BIOS can be shadowed so check whether it is.
Tip T211
BIOS is flash-able and socketed so it can be upgraded when needed.
Tip T2
For more information about tips, press F1 and scroll to the Tips section.
Processor 1
Processor(s)
Model
AMD Athlon(tm)
Co-Processor (FPU)
Built-in
Speed
1.89GHz
Model Number
2319 (estimated)
Performance Rating
PR2765 (estimated)
Type
Standard
Multiplier
11x
Generation
7th (7x86)
Model Information
Duron M6/MP & Athlon 4/MP/XP (Palomino) 1G+ 1.7V
Revision/Stepping
6 / 2 (0)
Stepping Mask
A5
Caches
Internal Data Cache
64kB synchronous write-back (2-way, 64 byte line size)
Internal Code Cache
L2 On-board Cache
256kB ECC synchronous write-back (16-way, 64 byte line size)
L2 Cache Multiplier
1/1x (equiv. 1890MHz)
Host Interface
Front Side Bus Speed
2x 172MHz (344MHz data rate)
Mainboard Upgradeability
Socket/Slot
Socket A
Upgrade Interface
ZIF Socket
Supported Speed(s)
1.89GHz (or more)
Supported Voltage(s)
1.8V
Environment Monitor 1
Model
Winbond W83697HF ISA
Version
6.00
Mainboard Specific Support
No
Processor Sensors
CPU Temperature
41.5°C / 106.7°F td
CPU Core Voltage
1.81V
CPU Arithmetic Benchmark
Benchmark Results
Dhrystone ALU
5217MIPS
Whetstone FPU
2609MFLOPS
Test Status
SMP Test
No
Total Test Threads
1
SMT Test
No
Dynamic MP/MT Load Balance
No
Processor Affinity
No
Processor(s)
Model
AMD Athlon(tm)
Speed
1.89GHz
Model Number
2319 (estimated)
Performance Rating
PR2765 (estimated)
L2 On-board Cache
Technology Support
SSE2 Technology
No
Hyper-Threading Technology
No
Performance Tips
Notice N5008
To change benchmarks, click Options.
Notice N5004
Synthetic benchmark. May not tally with 'real-life' performance.
Notice N5006
Only compare the results with ones obtained using the same version!
Tip T2
CPU Multi-Media Benchmark
Benchmark Results
Integer aEMMX/aSSE
10346it/s
Floating-Point aSSE
11965it/s
Test Status
SMP Test
No
Total Test Threads
1
SMT Test
No
No
Processor Affinity
No
Processor(s)
Model
AMD Athlon(tm)
Speed
1.89GHz
Model Number
2319 (estimated)
Performance Rating
PR2765 (estimated)
L2 On-board Cache
Technology Support
MMX Technology
Yes
SSE Technology
Yes
SSE2 Technology
No
No
Extended AMD MMX Technology
Yes
3DNow! Technology
Yes
Extended 3DNow! Technology
Yes
Performance Tips
Notice N5008
Notice N5004
Notice N5006
Tip T2
Memory Bandwidth Benchmark
Benchmark Results
RAM Bandwidth Int Buffered aEMMX/aSSE
2484MB/s
RAM Bandwidth Float Buffered aEMMX/aSSE
2328MB/s
Int Buffered aEMMX/aSSE (Integer STREAM) Results Breakdown
Assignment
2481MB/s
Scaling
2476MB/s
Addition
2490MB/s
Triad
2492MB/s
Data Item Size
4-bytes / 32-bits
Buffering Used
Yes
Bandwidth Efficiency
90% (estimated)
Float Buffered aEMMX/aSSE (Float STREAM) Results Breakdown
Assignment
2480MB/s
Scaling
2323MB/s
Addition
2266MB/s
Triad
2245MB/s
Data Item Size
8-bytes / 64-bits
Buffering Used
Yes
85% (estimated)
Test Statistics
Array Memory Used
256MB
SMP Test
No
Total Test Threads
1
SMT Test
No
No
Processor Affinity
No
System Chipset
Model
VIA Technologies Inc VT8366 Apollo KT333 CPU to PCI Bridge
Max. Bus Bandwidth
2752MB/s (estimated)
Logical/Chipset Memory Banks
Bank 0 Setting
256MB DDR-SDRAM 2.0-2-2CL 1CMD
Bank 1 Setting
Bank Interleave
4-way
Memory Bus Speed
Max. Memory Bandwidth
Hmm,kann mir jemand sagen wie ich die benchmark ergebnisse von sandra 2002 mit bild posten kann ?
http://www.nethands.de/pys/show.php3?user=DenoK2509 <IMG SRC="smilies/biggrin.gif" border="0">
