Crucial SSD gebraucht gekauft; SMART-werte -> Zurückschicken oder nicht?
jcc
Hallo.
Ich habe die amazon warehousedeals genutzt um für knapp 77e eine Crucial M4 128 GB zu kaufen.
Nun habe ich dei SMART-Werte ausgelesen und etwas gegooglt und werde daraus nicht wirklich schlau.
Hier erstmal die werte:
Code:
=== START OF INFORMATION SECTION ===
Device Model:     M4-CT128M4SSD2
Serial Number:    000000001XXXXXXXXXXXX
Firmware Version: 0002
User Capacity:    128.034.594.304 bytes
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   9
ATA Standard is:  Not recognized. Minor revision code: 0x28
Local Time is:    Sun Jun 23 12:09:34 2013 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x80) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                 ( 595) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (   9) minutes.
Conveyance self-test routine
recommended polling time:        (   3) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   100   100   050    Pre-fail  Always       -       0
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   100   100   001    Old_age   Always       -       5573
 12 Power_Cycle_Count       0x0032   100   100   001    Old_age   Always       -       925
170 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       0
171 Unknown_Attribute       0x0032   100   100   001    Old_age   Always       -       0
172 Unknown_Attribute       0x0032   100   100   001    Old_age   Always       -       80
173 Unknown_Attribute       0x0033   099   099   010    Pre-fail  Always       -       36
174 Unknown_Attribute       0x0032   100   100   001    Old_age   Always       -       0
181 Unknown_Attribute       0x0022   100   100   001    Old_age   Always       -       4234854007521
183 Unknown_Attribute       0x0032   100   100   001    Old_age   Always       -       0
184 Unknown_Attribute       0x0033   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   001    Old_age   Always       -       0
188 Unknown_Attribute       0x0032   100   100   001    Old_age   Always       -       0
189 High_Fly_Writes         0x000e   100   100   001    Old_age   Always       -       96
195 Hardware_ECC_Recovered  0x003c   100   100   001    Old_age   Offline      -       0
196 Reallocated_Event_Count 0x0032   100   100   001    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   001    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   001    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   100   100   001    Old_age   Always       -       0
202 TA_Increase_Count       0x0018   099   099   001    Old_age   Offline      -       1
206 Flying_Height           0x000e   100   100   001    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
a)
Was mich natürlich stutzig macht sind die >5000h Laufzeit.
Sind das wirklich Stunden? Ich habe auch von einem 5000h-Bug gelesen bei alten Firmwares.
b)
Die Firmwareversion ist 002. kann es sein das crucial schon be 007 ist und kann ich die Firmware selber updaten?
Und werden dann die Stunden korrigiert?
c)
Was ist das für ein Riesenwert 7 Zeilen unterhalb der Laufzeit?
d)
Sollte/kann ich weitere Test durchführen?
Kann mir jemand weiterhelfenß
Ich würde Crystaldiskinfo verwenden um die Smart Werte anzeigen zu lassen. Das ist wesentlich übersichtlicher und zeigt auch den Zustand der SSD in Prozent an.
a) naja, da steht zumindest der Wert so drin!
b) Ja kannst Du und falsch! Wir sind bei der M4 inzwischen bei 070h, das ist was anderes als 0007! SSD Support
c) können wir so nicht sagen, muss aber nichts zu bedeuten haben, mach mal Crystal disk info!
d) können wir erst sagen wenn wir Crystal disk info mal sehen, aber m.E. WAS willst Du denn noch testen? Entweder Sie geht oder nicht, allerdings sind >5000Std schon recht viel für den Preis! Das ist auf jeden Fall eine deutlich gebrauchte! SSD. Sofern 24 Std an ist die SSD 232,2 Tage alt!
e) Sie wurde "auch" 925 an und aus gemacht!
Ok, hab die M4 jetzt an einen Windows-PC angeschlossen und Crystaldiskinfo liefert entsprechende Werte.
926 mal angeschaltet und 5574h.
Der dritte extrem hohe Wert ist der "non-physical page-alligned access count". Was immer das sei mag.
Ich hatte gehofft, dass es vielleicht Sekunden sind, aber alleine die knapp 1000 Einschaltvorgänge sind mir deutlich zu viel.
Dann lieber eine neue. Ist für einen Freund, der hauptsächlich zockt.
Muss nicht die beste sein, aber man sollte schon den Wow-Effekt einer SSD beim Booten & Programme starten spüren.
Reicht dafür auch eine Sandisk oder "muss" es eine Samsung sein?
Nein, grundsätzlich reicht im Vergleich zu einer HDD auch eine "einfache" SSD. Wie gesagt, die Crucial ist ja noch okay, allerdings für 77 Oiros m.E. etwas zu teuer! Frag doch mal Amazon wie die das sehen! Ich würde die mal anchatten! Meist kann man mit Amazon reden!
Die geht definitiv zurück. Hab mal die Laufzeiten auf meinen anderen PC angeschaut und 5000h ist ne ganze Menge!
Die Plextor könnte es werden. Hatte kurz mit der Sandsik 256GB geliebäugelt, aber eigentlich reichen 128GB. Daten sollen eh auf eine seperate HDD.
Danke.
5000 h is ordentlich ;)
Ich habe hier eine 64GB Crucial m4 im Rechner, die schon fast 7000 Betriebsstunden hat und der Zustand ist immer noch bei 96%.
Es lohnt sich aber natürlich nicht eine gebrauchte SSD für 77 Euro zu kaufen, wenn man für ein paar Euro mehr schon eine Neue bekommt.
darum geht es nicht. Wenn er sie für 77 Euro gekauft hat und das Ding hat 5000Std dann wäre mir das auch zu viel....
Ich habe hier eine Uralt ST die immer noch im Server als OS SSD läuft... Frag nicht wieviel Stunden die hat.
wäre mir auch deutlich zuviel Nutzung für das Geld. lieber 10 Euro ca drauf legen und eine neue kaufen.
Gesendet von meinem XT890 mit der Hardwareluxx App
