CS:S performance Probleme
Prinzen Rolle
Code:
Performance warning: Mark bone 'ValveBiped.weapon_bone' in model 'player/custom_plugin/ct_snake1_gizzmo/urban.mdl' as being used by bone merge in the .qc!
Performance warning: Mark bone 'ValveBiped.weapon_bone_Clip' in model 'player/custom_plugin/ct_snake1_gizzmo/urban.mdl' as being used by bone merge in the .qc!
*uMc* swat alchimist :  STATSME
Verbindung zu K.o.n /*KeRmIt La gReNoUiLlE steht.
Performance warning: Mark bone 'ValveBiped.Bip01_R_Hand' in model 'player/custom_plugin/t_cruza1_gizzmo/t_phoenix.mdl' as being used by bone merge in the .qc!
(Fr) Kev killed [BOT] Alfred with m4a1.
Performance warning: Mark bone 'ValveBiped.weapon_bone' in model 'player/lduke/urbancityv1/urban.mdl' as being used by bone merge in the .qc!
Performance warning: Mark bone 'ValveBiped.weapon_bone_Clip' in model 'player/lduke/urbancityv1/urban.mdl' as being used by bone merge in the .qc!
Performance warning: Mark bone 'ValveBiped.weapon_bone' in model 'player/custom_plugin/t_cruza1_gizzmo/t_phoenix.mdl' as being used by bone merge in the .qc!
Performance warning: Mark bone 'ValveBiped.weapon_bone_Clip' in model 'player/custom_plugin/t_cruza1_gizzmo/t_phoenix.mdl' as being used by bone merge in the .qc!
Verbindung zu [BOT] Ethan steht.
†  [T]hE PuNisHe[R] †chteam killed [BOT] Ethan with m4a1.
Performance warning: Mark bone 'ValveBiped.weapon_bone' in model 'player/lduke/warfacev1/terror.mdl' as being used by bone merge in the .qc!
Performance warning: Mark bone 'ValveBiped.weapon_bone_Clip' in model 'player/lduke/warfacev1/terror.mdl' as being used by bone merge in the .qc!
*uMc* swat alchimist suicided.
STAR | dgse* killed greaves@fr with m4a1.
2 nouveaux skins par semaine
D€® K©m²Î$²@® @lmaa killed [BOT] Ethan with m4a1.
:heul:
was ist das, wo kommt das her und wie gehts wieder weg...:fresse:
Ka was das sein soll, kam von einem auf den anderen tag und nervt tierisch! gurk dann da mit 2 oder 3 frames/sec rum...spitze...
hilfe :heul:
Grad alle paar Sekunden die slowdowns gehabt...mach kein Spaß...
