X.Org X Server 1.7.7
Release Date: 2010-05-04
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.32.29-dsa-ia32 i686 Debian
Current Operating System: Linux Melina 2.6.32-5-686 #1 SMP Mon Jun 13 04:13:06 UTC 2011 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-686 root=UUID=c7fef04c-b3a0-427d-9a50-2bb65594b7aa ro quiet
Build Date: 19 February 2011 02:37:36PM
xorg-server 2:1.7.7-13 (Cyril Brulebois <kibi@debian.org>)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Jul 11 20:18:51 2011
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "FujitsuTE770B"
(**) | |-->Device "Intel865G"
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
(II) Loader magic: 0x81ecca0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(++) using VT number 7
(--) PCI:*(0:0:2:0) 8086:2572:1849:2572 Intel Corporation 82865G Integrated Graphics Controller rev 2, Mem @ 0xf0000000/134217728, 0xff280000/524288, I/O @ 0x0000ec00/8
(II) Open ACPI successful (/var/run/acpid.socket)
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "record" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri2" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "intel"
(II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.13.0
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 6.0
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge, Sandybridge, Sandybridge, Sandybridge, Sandybridge,
(II) Primary Device is: PCI 00@00:02:0
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenByBusid: drmOpenMinor returns 9
drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
(==) intel(0): Depth 24, (--) framebuffer bpp 32
(==) intel(0): RGB weight 888
(==) intel(0): Default visual is TrueColor
(II) intel(0): Integrated Graphics Chipset: Intel(R) 865G
(--) intel(0): Chipset: "865G"
(==) intel(0): Shadow buffer enabled, GPU acceleration disabled.
(**) intel(0): Tiling enabled
(**) intel(0): SwapBuffers wait enabled
(==) intel(0): video overlay key set to 0x101fe
(II) intel(0): Output VGA1 using monitor section FujitsuTE770B
(II) intel(0): EDID for output VGA1
(II) intel(0): Not using default mode "640x350" (vrefresh out of range)
(II) intel(0): Not using default mode "320x175" (doublescan mode not supported)
(II) intel(0): Not using default mode "640x400" (vrefresh out of range)
(II) intel(0): Not using default mode "320x200" (doublescan mode not supported)
(II) intel(0): Not using default mode "720x400" (vrefresh out of range)
(II) intel(0): Not using default mode "360x200" (doublescan mode not supported)
(II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
(II) intel(0): Not using default mode "640x480" (vrefresh out of range)
(II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
(II) intel(0): Not using default mode "800x600" (vrefresh out of range)
(II) intel(0): Not using default mode "1024x768" (vrefresh out of range)
(II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
(II) intel(0): Not using default mode "1152x864" (vrefresh out of range)
(II) intel(0): Not using default mode "576x432" (doublescan mode not supported)
(II) intel(0): Not using default mode "1280x960" (hsync out of range)
(II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
(II) intel(0): Not using default mode "1280x960" (vrefresh out of range)
(II) intel(0): Not using default mode "1280x1024" (hsync out of range)
(II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
(II) intel(0): Not using default mode "1280x1024" (vrefresh out of range)
(II) intel(0): Not using default mode "1600x1200" (hsync out of range)
(II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
(II) intel(0): Not using default mode "1600x1200" (vrefresh out of range)
(II) intel(0): Not using default mode "1792x1344" (hsync out of range)
(II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
(II) intel(0): Not using default mode "1792x1344" (vrefresh out of range)
(II) intel(0): Not using default mode "1856x1392" (hsync out of range)
(II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
(II) intel(0): Not using default mode "1856x1392" (vrefresh out of range)
(II) intel(0): Not using default mode "1920x1440" (hsync out of range)
(II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
(II) intel(0): Not using default mode "1920x1440" (vrefresh out of range)
(II) intel(0): Not using default mode "832x624" (vrefresh out of range)
(II) intel(0): Not using default mode "416x312" (doublescan mode not supported)
(II) intel(0): Not using default mode "1152x864" (hsync out of range)
(II) intel(0): Not using default mode "1360x768" (monitor doesn't support reduced blanking)
(II) intel(0): Not using default mode "680x384" (doublescan mode not supported)
(II) intel(0): Not using default mode "1400x1050" (hsync out of range)
(II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
(II) intel(0): Not using default mode "1400x1050" (vrefresh out of range)
(II) intel(0): Not using default mode "1440x900" (hsync out of range)
(II) intel(0): Not using default mode "720x450" (doublescan mode not supported)
(II) intel(0): Not using default mode "1600x1024" (hsync out of range)
(II) intel(0): Not using default mode "800x512" (doublescan mode not supported)
(II) intel(0): Not using default mode "1680x1050" (hsync out of range)
(II) intel(0): Not using default mode "840x525" (doublescan mode not supported)
(II) intel(0): Not using default mode "1680x1050" (vrefresh out of range)
(II) intel(0): Not using default mode "1920x1080" (hsync out of range)
(II) intel(0): Not using default mode "960x540" (doublescan mode not supported)
(II) intel(0): Not using default mode "1920x1200" (hsync out of range)
(II) intel(0): Not using default mode "960x600" (doublescan mode not supported)
(II) intel(0): Not using default mode "2048x1536" (hsync out of range)
(II) intel(0): Not using default mode "1024x768" (doublescan mode not supported)
(II) intel(0): Not using default mode "2048x1536" (vrefresh out of range)
(II) intel(0): Printing probed modes for output VGA1
(II) intel(0): Modeline "1024x768_85.00"x84.9 94.50 1024 1096 1200 1376 768 771 775 809 -hsync +vsync (68.7 kHz)
(II) intel(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz)
(II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) intel(0): Modeline "848x480"x60.0 33.75 848 864 976 1088 480 486 494 517 +hsync +vsync (31.0 kHz)
(II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 489 492 525 -hsync -vsync (31.5 kHz)
(II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) intel(0): Output VGA1 connected
(II) intel(0): Using user preference for initial modes
(II) intel(0): Output VGA1 using initial mode 1024x768_85.00
(II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
(II) intel(0): Kernel page flipping support detected, enabling
(==) intel(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(==) Depth 24 pixmap format is 32 bpp
(==) intel(0): VideoRam: 131072 KB
(WW) intel(0): cannot enable DRI2 whilst forcing software fallbacks
(II) intel(0): Allocated new frame buffer 1024x768 stride 4096, tiled
(II) UXA(0): Driver registered support for the following operations:
(II) solid
(II) copy
(II) composite (RENDER acceleration)
(II) put_image
(II) get_image
(==) intel(0): Backing store disabled
(==) intel(0): Silken mouse enabled
(II) intel(0): Initializing HW Cursor
(II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(==) intel(0): DPMS enabled
(==) intel(0): Intel XvMC decoder disabled
(II) intel(0): Set up overlay video
(II) intel(0): direct rendering: Failed
(--) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
SELinux: Disabled on system, not enabling in X server
(II) AIGLX: Screen 0 is not DRI2 capable
(II) AIGLX: Screen 0 is not DRI capable
(II) AIGLX: Loaded and initialized /usr/lib/dri/swrast_dri.so
(II) GLX: Initialized DRISWRAST GL provider for screen 0
(II) intel(0): Setting screen physical size to 270 x 203
(II) config/udev: Adding input device Power Button (/dev/input/event1)
(**) Power Button: Applying InputClass "evdev keyboard catchall"
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 2.3.2
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 7.0
(**) Power Button: always reports core events
(**) Power Button: Device: "/dev/input/event1"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "pc105"
(**) Option "xkb_layout" "de"
(II) config/udev: Adding input device Power Button (/dev/input/event0)
(**) Power Button: Device: "/dev/input/event0"
(II) config/udev: Adding input device Logitech HID compliant keyboard (/dev/input/event3)
(**) Logitech HID compliant keyboard: Applying InputClass "evdev keyboard catchall"
(**) Logitech HID compliant keyboard: always reports core events
(**) Logitech HID compliant keyboard: Device: "/dev/input/event3"
(II) Logitech HID compliant keyboard: Found keys
(II) Logitech HID compliant keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "Logitech HID compliant keyboard" (type: KEYBOARD)
(II) config/udev: Adding input device Logitech HID compliant keyboard (/dev/input/event5)
(**) Logitech HID compliant keyboard: Device: "/dev/input/event5"
(II) Logitech HID compliant keyboard: Found 20 mouse buttons
(II) Logitech HID compliant keyboard: Configuring as mouse
(**) Logitech HID compliant keyboard: YAxisMapping: buttons 4 and 5
(**) Logitech HID compliant keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) config/udev: Adding input device ImPS/2 Generic Wheel Mouse (/dev/input/event4)
(**) ImPS/2 Generic Wheel Mouse: Applying InputClass "evdev pointer catchall"
(**) ImPS/2 Generic Wheel Mouse: always reports core events
(**) ImPS/2 Generic Wheel Mouse: Device: "/dev/input/event4"
(II) ImPS/2 Generic Wheel Mouse: Found 3 mouse buttons
(II) ImPS/2 Generic Wheel Mouse: Found scroll wheel(s)
(II) ImPS/2 Generic Wheel Mouse: Found relative axes
(II) ImPS/2 Generic Wheel Mouse: Found x and y relative axes
(II) ImPS/2 Generic Wheel Mouse: Configuring as mouse
(**) ImPS/2 Generic Wheel Mouse: YAxisMapping: buttons 4 and 5
(**) ImPS/2 Generic Wheel Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "ImPS/2 Generic Wheel Mouse" (type: MOUSE)
(II) ImPS/2 Generic Wheel Mouse: initialized for relative axes.
(II) config/udev: Adding input device ImPS/2 Generic Wheel Mouse (/dev/input/mouse0)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device PC Speaker (/dev/input/event2)
