Hi
undzwar habe ich öfers schonam diesen error :
Debian:~# apt-get install -f
Reading package lists... 0%
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 279 not upgraded.
2 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
Setting up mediatomb-daemon (0.12.0~svn2018-3) ...
update-rc.d: /etc/init.d/mediatomb exists during rc.d purge (use -f to force)
dpkg: error processing mediatomb-daemon (--configure):
subprocess post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mediatomb:
mediatomb depends on mediatomb-daemon (>= 0.12.0~svn2018-3); however:
Package mediatomb-daemon is not configured yet.
dpkg: error processing mediatomb (--configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
mediatomb-daemon
mediatomb
E: Sub-process /usr/bin/dpkg returned an error code (1)
Debian:~#
Wie kann ich das lösen ?
mediatomb-daemon
mediatomb
Debian:~#
