DoctorBest
wie is dieses NT?
Model No. EG365AX-VE
Voltage rating: 110V~240V AC
Iin=115/230Vac
10A / 6A
12A / 7A
Frequency
47Hz~63Hz
Inrush current
40A max. / 115V; 80A max. / 230V
(at cold start)
Hold up time
17ms min. at 230V AC full load
Over Power Protection
105%~160% of max load
Over Voltage Protection
+5V: 5.6V~6.9V
+3.3V: 3.7V~4.5V
+5Vsb: 5.6V~6.9V
Efficiency
70% min. at full load
Cooling
Air convection by +12V DC fan
Operation Temperature
0oC ~25oC for full rating of load,
decrease to zero Watts O/P at 70oC
Storage Temperature
-20oC ~80oC
Humidity
Operating: to 85% relative humidity ,
non-condensing At 25oC
Storage : to 95% relative humidity ,
non-condensing At 50oC
MTBF
100K hours at 25oC ,70% full rated load
EMC
EN55022 ,Class B
FCC Part 15
CNS 13438 Class B
EN 55024
Safety
UL CUL VDE DEMKO NEMKO SEMKO FIMKO SABS
Dimension
W150 x H86 x D140 (mm)
wie is dieses NT?
Iin=115/230Vac
10A / 6A
12A / 7A
Frequency
47Hz~63Hz
Inrush current
(at cold start)
Hold up time
+5V: 5.6V~6.9V
+3.3V: 3.7V~4.5V
+5Vsb: 5.6V~6.9V
Efficiency
Cooling
Storage Temperature
-20oC ~80oC
Humidity
MTBF
EMC
EN55022 ,Class B
FCC Part 15
CNS 13438 Class B
EN 55024
Safety
Dimension
