I have bought an new System and now i am going crazy
DFI Lanparty UT nF4 SLI-DR Expert
AMD 64 Sandjego 3700+ (runs @ 2.800 Ghz)
OCZ DIMM 1GB DDR-600 Kit TCCD Platin
2 x Samsung HD160JJ SATA2 8,9/7200/8MB (Raid 0)
evga 7800gt co (20 piplines)
Enermax EG565AX-VE(W)FMA / 535Watt
Now my Problem....
The correct facts of the card are 470 / 1100
I overclocked it to 480 / 1200 (runs stable)
but i got very poor 3D Marks
3D Mark 2003 = 15673 Points
3D Mark 2005 = 7023 Points
Think it should be extrem more.
Habe installed the 81.98_forceware_winxp2k_english_whql.exe
and
nForce4_amd_6.70_winxp2k_english.exe
aa = off
af = off
image settings = high performance
vsync = off
I tried another Card (Aopen 7800 GT). It runs with another CPU on the same board (same bios) and brings 7650 points (430/1100) and 8300 Points (480/1180)
But on my System also 6980 Points (470/1100)..... So i think my Card is ok...
3D Mark05
http://www.freakdesigns.de/gewusel/blt/evga.jpg
Have made some tests with Sandra...
Sandra_Arithmetik
http://www.freakdesigns.de/gewusel/blt/Sandra_Arithmetik.jpg
http://www.freakdesigns.de/gewusel/blt/Sandra_Speicherbandbreiten.jpg
Sandra_CPU_multimedia
http://www.freakdesigns.de/gewusel/blt/Sandra_CPU_multimedia.jpg
SandraSystem
http://www.freakdesigns.de/gewusel/blt/Sandra_System.jpg
cpuz
http://www.freakdesigns.de/gewusel/blt/cpuz.jpg
superpi
http://www.freakdesigns.de/gewusel/blt/superpi.jpg
everest
http://www.freakdesigns.de/gewusel/blt/everest.jpg
So i think the Ram is ok, The Harddrives are ok, the Card is ok and the CPU too........
WHY I GET SUCH BAD POINTS???????????????????????
Could the board be bad?
PS : Ihr koennt in deutsch antworten, hatte das nur in einem andern Forum gepostet.
DANKE IM VORRAUS
Now my Problem....
and
aa = off
af = off
vsync = off
3D Mark05
Sandra_Arithmetik
SandraSystem
cpuz
superpi
everest
DANKE IM VORRAUS
