Finde keine Dokumentation zu einer Sandy Bridge Celeron bei Intel
bogi32b
Experte
Moin,
ich habe eine Netzwerk-Appliance, ausgestattet mit einer Intel Celeron CPU, die ich leider nirgendwo finde:
root@pve1:~# lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 36 bits physical, 48 bits virtual
CPU(s): 2
On-line CPU(s) list: 0,1
Thread(s) per core: 2
Core(s) per socket: 1
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 42
Model name: Intel(R) Celeron(R) CPU @ 1.30GHz
Stepping: 7
CPU MHz: 1299.976
CPU max MHz: 1300.0000
CPU min MHz: 800.0000
BogoMIPS: 2599.95
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 1536K
NUMA node0 CPU(s): 0,1
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx lahf_lm epb pti tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm arat pln pts
root@pve1:~#
*-cpu
description: CPU
product: Intel(R) Celeron(R) CPU @ 1.30GHz
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: Intel(R) Celeron(R) CPU @ 1.30GHz
slot: SOCKET 0
capacity: 1300MHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp x86-64 constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx lahf_lm epb pti tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm arat pln pts cpufreq
configuration: cores=1 enabledcores=1 threads=2
*-cache:0
description: L1 cache
physical id: 5
slot: CPU Internal L1
capacity: 64KiB
capabilities: internal write-back
configuration: level=1
*-cache:1
description: L2 cache
physical id: 6
slot: CPU Internal L2
capacity: 256KiB
capabilities: internal write-back unified
configuration: level=2
*-cache:2
description: L3 cache
physical id: 7
slot: CPU Internal L3
capacity: 1536KiB
configuration: level=3
Mit Family, Stepping und Model finde ich an die 100 verschiedene CPU's... als ob Intel die alle gleich backen würde, danach prüft wieviel cache auf dem DIE lebt und wie schnell die läuft, und erst danach entscheidet als was die verkauft wird.
(y), aber wie findet man das raus? Gibt es eine Seite wo man das filtern kann?
Intels ARK-Datenbank hat auch ne Filterfunktion:
Wenn du da noch ne Maximalfrequenz von 1,3 Ghz auswählst, bleiben nur noch zwei Modelle übrig.
