[Sammelthread] foobar2000 v2.24 Final wurde veröffentlicht
Update!
foobar2000 1.4 beta 12 wurde veröffentlicht.
Support for reading music files from FTP servers has been greatly improved and now covers FTPES/FTPS.
Various reported bugs have been addressed.
Changelog v1.4:
  • Added preferences page to adjust priority order of installed decoders.
  • Greatly improved DSP manager dialog.
  • Added output mode switcher toolbar item to Default User Interface.
  • Converter improvements:
    - Keeping incomplete/problematic output files is now optional; they're deleted by default.
    - New and improved overwrite prompt dialog.
    - FDK AAC is now among the default presets (beta 2).
  • ReplayGain scanner improvements:
    - Greatly improved “Apply Gain to File Content” feature, with multi threading and more supported formats.
    - Added command to manually manipulate Opus header gain field for both .opus and Matroska.
    - New Preferences pages (beta 4).
  • Playlist & Media Library search use a new text-matching algorithm similar to Unicode Asymmetric Search.
  • Reworked Default User Interface Preferences pages; improved options for minimize & close behaviors.
  • Cosmetic tweaks; prettier buttons attached to editboxes in various dialogs.
  • Cleaned up Opus header gain manipulation, reported value no longer offseted by 5 dB, made header gain respected when embedded in Matroska container.
  • Matroska support improvements, improved seeking performance on files without seektables.
  • Made possible to choose between alternate audio streams in MP4 and Matroska files.
  • Implemented WebM internet stream playback.
  • Compiled using dynamic VC runtime, raising the limit of how many component DLLs can be loaded.
  • Made Album List remember expanded nodes (beta 2).
  • Raised track count limit for cue sheets from 99 to 999 (beta 2).
  • Fixed a bug causing incorrect tags being read from certain multi-chapter MP4 files (beta 3).
  • Integration with Windows 10 Universal Volume Control (beta 4).
  • Playback controls in taskbar on Windows 7 and newer (beta 4).
  • Configuration saving now uses transacted NTFS if available (beta 7).
    - … but only in standard (not portable) installs by default. (changed in beta 12).
  • New, different scheme of storing user's playlists in app data (beta 7):
    - Playlists now reside under playlists-v1.4, you can delete the playlists-v1.3 folder if you no longer need it.
    - Unchanged playlists are no longer rewritten on each app shutdown.
  • Merged networking features from foobar2000 mobile (beta 7):
    - FTP reader!
    - - FTPES/FTPS now also supported (beta 12).
    - Refreshed HTTP/HTTPS reader; added the ability to read remote folder listings.
  • Improved handling of various file formats over HTTP, AIFF and Musepack in particular (beta 7).
  • New Default UI toolbar items for DSP presets and ReplayGain modes (beta 7).
  • More robust M3U/M3U8/PLS playlist handling (beta 7):
    - iTunes-created M3U8 playlists now load correctly.
    - Big fat warning when trying to save a M3U/PLS file that may not be readable correctly due to international characters.
  • New file format icons (beta 7, beta 9).
  • Improved media library search performance (beta 9).
  • Made various playlist and search result sorting operations use multiple CPU cores (beta 9).
  • All communication with foobar2000 website (troubleshooter, crash reporting, update checks) is now encrypted (beta 11).
  • Amended Matroska tagging, certain rare files that would fail to update before are now taggable (beta 11).
  • Improved recovery from removable audio output device unplug (beta 11).
    - Volume control now works if the device wasn't available during foobar2000 startup but got attached later.
  • Media Library now handles very long filenames correctly (beta 11).
  • Fixed a bug in CD drive configuration dialog - automatic drive offset lookup works again (beta 12).
Download foobar2000 1.4 beta 12
Update!
foobar2000 1.4 beta 13 wurde veröffentlicht.
Various minor bugs and regressions reported on the forum have been corrected.
Changelog v1.4:
    - FTP reader!
Download foobar2000 1.4 beta 13
Update!
foobar2000 1.4 beta 15 wurde veröffentlicht.
Recent regressions have been fixed.
New field has been added to the Default User Interface status bar.
Features for version 1.4 have been frozen, there will be no further 1.4 changes other than bug fixes.
foobar2000 1.4 beta 14 wurde veröffentlicht.
Various bugs reported on the forum have been fixed.
The File Operations component has been updated; the presets are now stored in a plain text files that can be edited by hand or backed up.
The beta version expiration timeout has been relaxed, the popup is now dismissable but will re-appear on next startup.
Changelog v1.4:
    - FTP reader!
    - Fixed a bug in HTTPS reader causing incompatibility with Google websites (beta 14).
  • Refreshed File Operations preset management, now stored in a plain text files instead and possible to import/export/edit (beta 14).
  • Relaxed beta version timeout, now possible to dismiss the message and launch without updating (beta 14).
  • Updated FFmpeg to version 3.4.2 (beta 14).
    - Reverted to old 3.2.4 due to reported crashes (beta 15).
  • Cleaned up Default User Interface status bar, added a new field for count of selected tracks (beta 15).
Download foobar2000 1.4 beta 15
Update!
foobar2000 1.3.18 beta 1 wurde veröffentlicht.
A maintenance update of the foobar2000 v1.3 series is being prepared. It will not add any functional changes, but address known bugs that have already been fixed in 1.4 series.
Version 1.3.18 beta 1 is now available alongside the 1.4 beta.
If you've found a bug in it, or you think something else can be improved for the most likely last update of the 1.3 series, please visit the forum thread.
Changelog v1.3.18:
This is a maintenance update, contains only bug fixes backported from 1.4 series.
  • Fixed a bug in HTTPS reader causing incompatibility with Google websites.
  • Relaxed beta version timeout, now possible to dismiss the message and launch without updating.
  • Fixed a bug in CD drive configuration dialog - automatic drive offset lookup works again.
  • Fixed various bugs related to audio device hotplugging.
  • Fixed wrong descriptions of certain context menu commands.
  • Fixed wrong handling of certain types of MP4 chapter tags.
  • Improved safeguards against Media Library configuration loss if foobar2000 dies while saving its settings.
Download foobar2000 1.3.18 beta 1
In other news, updated Microsoft Store version of foobar2000 now comes with long-awaited third party component support, if running on non-S version of Windows 10.
Get it from Microsoft
Update!
foobar2000 1.4 beta 17 wurde veröffentlicht.
Changelog v1.4:
  • Default User Interface improvements:
    - New toolbar items for switching output modes, ReplayGain modes and DSP presets.
    - Improved status bar: added optional display of selected track count.
    - Reworked Preferences pages; improved options for minimize & close behaviors.
    - FDK AAC is now among the default presets.
    - New Preferences pages.
  • Amended Matroska tagging, certain rare files that would fail to update before are now taggable.
  • Made Album List remember expanded nodes.
  • Raised track count limit for cue sheets from 99 to 999.
  • Integration with Windows 10 Universal Volume Control.
  • Playback controls in taskbar on Windows 7 and newer.
  • Configuration saving now uses transacted NTFS if available.
  • Changed the way playlists and media library data are stored to minimize the amount of rewriting on each app shutdown.
  • Merged networking features from foobar2000 mobile:
    - FTP/FTPES/FTPS reader!
  • Improved handling of various file formats over HTTP, AIFF and Musepack in particular.
  • More robust M3U/M3U8/PLS playlist handling; shows a warning when trying to save a M3U/PLS file that may not be readable correctly due to international characters.
  • New file format icons.
  • Improved media library search performance.
  • Made various playlist and search result sorting operations use multiple CPU cores.
  • All communication with foobar2000 website (troubleshooter, crash reporting, update checks) is now encrypted.
  • Refreshed File Operations preset management, now stored in a plain text files instead and possible to import/export/edit.
Download foobar2000 1.4 beta 17
Update!
foobar2000 1.3.18 Final wurde veröffentlicht.
This is a no-new-features bug-fixes-only update of the 1.3 series.
Changelog v1.3.18:
  • Media Library now handles very long filenames correctly.
  • Fixed inconsistent mapping of “Content Group” metadata field for: WMA, MP4/M4A, Vorbis Comments.
  • Fixed Skip Silence DSP bugs.
  • Made MP2 audio in MP4/Matroska container reported correctly. It was reported as MP3 in some cases before.
  • Made possible to load M3U8 files without UTF-8 BOM (iTunes).
Download foobar2000 1.3.18 Final
Update!
foobar2000 1.4 beta 20 wurde veröffentlicht.
Changelog v1.4:
  • Work around for DirectSound audio stutters with Windows 10 1803 (beta 19).
Download foobar2000 1.4 beta 20
Update!
foobar2000 1.4 beta 21 wurde veröffentlicht.
This is the last beta, and the last moment to report any outstanding issues. Version 1.4 stable will be out early next week.
foobar2000 v1.4 beta 21 release notes
Changelog v1.4:
Download foobar2000 1.4 beta 21
Update!
foobar2000 1.3.20 Final wurde veröffentlicht.
Changelog v1.3.20:
  • Reverted the much criticized CONTENT GROUP vs GROUPING remapping for FLAC/Vorbis.
  • GROUPING field name is now used for ID3v2 TIT1, M4A ©grp, etc.
Download foobar2000 1.3.20 Final
foobar2000 1.4 Final wurde veröffentlicht.
Changelog v1.4:
  • Fix implemented for splitter lock bug.
  • Workaround implemented for HTTPS issues on Windows XP.
Download foobar2000 1.4 Final
Update!
foobar2000 1.4.1 beta 1 wurde veröffentlicht.
Changelog v1.4.1:
  • Better error message when trying to open M4A file renamed to .aac.
  • Added %video_codec% info for Matroska and MP4 files.
  • Added support for PCM audio in MP4 container.
  • Made mouse wheel work in playlist view during a drag&drop operation.
  • Improved handling of classical music metadata for iTunes M4A files.
  • Added %bitspersample_extra% info to tell between int32/float32 PCM files.
  • Added support for ID3v2 iTunes Grouping field.
  • Converter: advanced-preferences option to encode to temp folder and move encoded-and-tagged files to the intended destination.
  • Made tag update operations not fail when another application has the file open for reading.
  • Corrected wrong bitrate shown for FLAC in Matroska container.
  • Corrected labels for F13-F24 keyboard shortcuts.
  • Fixed bugs with ReplayGain Scanner's automatic resampling of high sample rate content.
  • Bumped maximum allowed sample rate to deal with DSD1024 content.
  • Made Media Library respect 'include hidden files & folders' setting in Advanced Preferences.
  • Converter with “don't reset DSP between tracks” now respects DSP-reported latency for proper handling of gapless albums.
  • PPHS resampler bug fixes (inaccurate reported latency, crashing with extreme sample rates).
  • Fixed ReplayGain scan results showing zero peaks on near-silent 24-bit files.
  • New and improved buffering scheme for improved network streaming performance (ported from foobar2000 mobile).
  • Internet radio handling regressions from 1.4 fixed; added an Advanced Preferences setting for ShoutCast metadata codepage.
  • Fixed component auto update on Windows XP (1.4 regression).
  • Added an Advanced Preferences option to toggle asymmetric search, reverting search behaviors to 1.3 style.
  • Added title formatting fields for showing track/album peaks as decibel values.
  • Improved status feedback from batch attach album art tool.
  • Pressing “next” past the end of playlist now restarts the playlist even without “repeat” mode.
  • Made Converter “copy other files” feature respect parent folder (..\pattern) references.
  • Added EXTM3U info writing (enabled via advanced preferences).
  • Added 5.1 and 7.1 upmix DSPs.
Download foobar2000 1.4.1 beta 1
foobar2000 mobile for iOS beta testing program is now open for everyone.
You can sign up to become a beta tester here.
Update!
foobar2000 1.4.1 beta 2 wurde veröffentlicht.
Changelog v1.4.1:
  • (beta 2) Deleting the currently playing files no longer shows error popups (1.4 regression).
  • (beta 2) Fixed repaint glitches in media library search edit box.
Download foobar2000 1.4.2 beta 2
Update!
foobar2000 1.4.1 beta 3 wurde veröffentlicht.
Changelog v1.4.1:
  • (beta 3) Updated Opus decoder to latest libopus 1.3.
  • (beta 3) Fixed a bug causing poor Default UI playlist performance with tens of thousands of item.
  • (beta 3) Fixed incompatibility with certain HTTP servers causing music files to fail to play from those servers.
  • (beta 3) Internet radio regression fixes.
  • (beta 3) Made DSP presets in the toolbar sorted.
Download foobar2000 1.4.2 beta 3
Update!
foobar2000 1.4.1 beta 5 wurde veröffentlicht.
The infamous disappearing-window bug with Windows 10 1809 has been worked around. Sadly other Windows 10 1809 issues (font substitution) still persist.
foobar2000 v1.4.1 beta 5 release notes
Changelog v1.4.1:
  • (beta 5) Worked around the disappearing window bug of Windows 10 1809.
  • (beta 5) Made technical info properly shown for various Ogg based internet radios (Vorbis, Opus, FLAC).
Download foobar2000 1.4.2 beta 5
Update!
foobar2000 1.4.1 beta 6 wurde veröffentlicht.
Changelog v1.4.1:
  • (beta 6) Fixed 1.4 regression causing incorrect detection of Internet Explorer proxy server settings.
  • (beta 6) Fixed 1.4 regression causing some tag updates to fail with 'access denied' when another app is accessing the files.
  • (beta 6) Fixed various 175% text size rendering glitches.
  • (beta 6) Fixed odd behaviors while installing regular foobar2000 alongside MS Store foobar2000.
  • (beta 6) Fixed ReplayGain scanner preferences page glitches.
Download foobar2000 1.4.2 beta 6
Update!
foobar2000 1.4.1 Final wurde veröffentlicht.
Changelog v1.4.1:
  • Worked around the disappearing window bug of Windows 10 1809.
  • Converter updates:
    - Advanced-preferences option to encode to temp folder and move encoded-and-tagged files to the intended destination.
    - “Don't reset DSP between tracks” now respects DSP-reported latency for proper handling of gapless albums.
    - Made Converter “copy other files” feature respect parent folder (..\pattern) references.
  • Deleting the currently playing files no longer shows error popups (1.4 regression).
  • Fixed repaint glitches in media library search edit box.
  • Updated Opus decoder to latest libopus 1.3.
  • Fixed a bug causing poor Default UI playlist performance with tens of thousands of item.
  • Fixed incompatibility with certain HTTP servers causing music files to fail to play from those servers.
  • Internet radio regression fixes.
  • Made DSP presets in the toolbar sorted.
  • Made technical info properly shown for various Ogg based internet radios (Vorbis, Opus, FLAC).
  • Fixed 1.4 regression causing incorrect detection of Internet Explorer proxy server settings.
  • Fixed 1.4 regression causing some tag updates to fail with 'access denied' when another app is accessing the files.
  • Fixed various 175% text size rendering glitches.
  • Fixed odd behaviors while installing regular foobar2000 alongside MS Store foobar2000.
  • Fixed ReplayGain scanner preferences page glitches.
Download foobar2000 1.4.1 Final
Update!
foobar2000 1.4.2 beta 1 wurde veröffentlicht.
This is a maintenanace update focused on addressing known bugs.
A major update with new features is being worked on separately.
Changelog v1.4.2:
  • Added new iTunes ID3 classical fields.
  • Improved playlist behaviors when deleting the now playing file.
  • ReplayGain apply-gain-and-prevent-clipping no longer presumes 1.0 peak when peak is unknown.
  • Fixed occasional errors when saving configuration.
  • Converter: Improved behavior when output file names repeat.
  • Fixed HTTP client bugs (internet radio, network shares).
  • Made MP4 files with missing duration info playable.
  • Windows 10 Universal Volume Control integration disabled by default due to bugs. This should address “multimedia keys don't work” issues.
Download foobar2000 1.4.2 beta 1
Update!
foobar2000 1.4.2 beta 2 wurde veröffentlicht.
... with more incremental bug fixes.
Changelog v1.4.2:
  • Fixed a bug that would cause spurious rewrites of certain configuration files [beta 2].
  • Made default MP4 handler gracefully fail to decode files with no supported audio tracks - so another decoder lower on the list can handle them [beta 2].
foobar2000 for Mac 2.1.27 wurde veröffentlicht.
New version of foobar2000 for Mac has been released, with seekbar and bottom playback controls.
Changelog v2.1.27:
  • Playback controls pane (buttons, seekbar, playback order) at the bottom instead of toolbar
  • Now possible to toggle repeat/shuffle modes
  • Now-playing info and controls now accessible via Mac OS notifications
Download foobar2000 for Mac 2.1.27
Update!
foobar2000 1.4.2 Final wurde veröffentlicht.
Changelog v1.4.2:
  • Worked around an “Open…” dialog lockup with lots and lots of supported file formats provided by third party components [final].
Download foobar2000 1.4.2 Final
Update!
foobar2000 1.4.3 beta 1 wurde veröffentlicht.
This is a maintenanace update addressing known bugs.
Changelog v1.4.3:
  • Fixed disappearing metadata and playlist content corruption with certain internet radio playlists.
  • Fixed high CPU usage with read-ahead options active.
  • Converter: Fixed broken save-as dialog with | character in encoder names.
  • Made foo_ui_std.dll & foo_input_std.dll report version number of the foobar2000 release that they came with, as some people seem to mix binaries from different releases then run into issues.
  • Made possible to fall back to another decoder with WMA files that standard WMA decoder doesn't accept.
  • Fixed disappearing & appearing 'version' file in library configuration folder.
  • Updated FFmpeg to 3.4.5.
Download foobar2000 1.4.3 beta 1
Update!
foobar2000 1.4.3 beta 3 wurde veröffentlicht.
Changelog v1.4.3:
  • Fixed certain AIFF files not playing (beta 2).
  • Restored foobar2000 version number in HTTP user-agent string (beta 2).
  • Added an option to force HTTP CONNECT with proxy servers (beta 2).
  • Fixed 1.4 regression causing odd behaviors when the currently playing track is removed from playlist (beta 2).
  • Fixed 1.4 regression causing certain combinations of shuffle and playlist operations to crash (beta 2).
  • Fixed 1.4 regression with missing HTTP host field in proxy server requests (beta 3).
Download foobar2000 1.4.3 beta 3
Update!
foobar2000 1.4.3 beta 5 wurde veröffentlicht.
Crashing while decoding Vorbis files (possibly also MP3 and AAC) has been addressed.
Changelog v1.4.3:
  • Fixed 1.4 regression with missing HTTP host field in proxy server requests (beta 3, beta 5).
  • Fixed a bug causing random crashes when decoding Vorbis (possibly also MP3 and AAC) due to bad parameters fed to FFmpeg (beta 4).
  • Converter: Made malformed UTF-8 in source file tags no longer cause conversion to FLAC to fail (beta 5).
Download foobar2000 1.4.3 beta 5
foobar2000 for Mac 2.1.32 wurde veröffentlicht.
Changelog v2.1.32:
  • Longpressing pause button now stops playback
  • Bug fixes
Update!
foobar2000 1.4.3 Final wurde veröffentlicht.
Many known bugs have been addressed. All 1.4.x users should update.
Changelog v1.4.3:
  • Fixed ReplayGain alter file content crash (final).
Download foobar2000 1.4.3 Final
Update!
foobar2000 1.4.4 beta 1 wurde veröffentlicht.
Changelog v1.4.4:
  • Fixed drag&drop glitches on Windows 10 with multiple monitors having different pixel densities.
  • Fixed Default UI preferences groups & columns drag&drop glitches.
  • Fixed incorrect formatting of written EXTM3U playlists.
  • Fixed incorrect truncation of specific long filenames in File Operations.
  • Fixed unnecessary reopening of remote files being played.
  • Fixed playback marker in playlists not being correctly retained in some conditions.
  • Improved internal IMA ADPCM WAV decoder (fixed rounding errors, fixed incorrect output duration).
  • foobar2000 now refuses to open 24-bit WMA lossless files on Windows 10 - which would otherwise decode incorrectly.
    - You can work around it by feeding WMA files to foo_input_ffmpeg component.
Download foobar2000 1.4.4 beta 1
Zu der App unter Android kann ich leider nichts beitragen. Aber wenn das Problem weiterhin besteht, würde ich einfach mal im offiziellen foobar2000-Forum um Hilfe bitten. Peter (der Entwickler) liesst da regelmäßig mit. Ich habe ihm da auch schon mal einen Bug gemeldet, den er umgehend behoben hat. :)
LG
Wieso? Das war doch absolut kein OT - im Gegenteil. Nur mangels Smartphone (ja, die Leute gibt es noch :d), kann ich persönlich leider nicht helfen. :)
Update!
foobar2000 1.4.4 Final wurde veröffentlicht.
Changelog v1.4.4:
    - Regardless, this is still a bug in Windows 10, not in foobar2000.
Download foobar2000 1.4.4 Final
