[Sammelthread] foobar2000 v2.24 Final wurde veröffentlicht
Update!
A major update of the UPnP MediaRenderer Output component is ready for general use.
Compatibility with devices from various manufacturers has been greatly improved; a new system of device specific settings has been introduced.
Additionally, foobar2000 for mac has been updated with the latest UPnP playback code.
Download UPnP MediaRenderer Output 1.3
foobar2000 for Mac 2.1.42 wurde veröffentlicht.
Changelog v2.1.42:
  • Updated UPnP playback features, in sync with UPnP MediaRenderer output component v1.3 on Windows.
Download foobar2000 for Mac 2.1.42
Update!
foobar2000 1.4.5 beta 1 wurde veröffentlicht.
Changelog v1.4.5:
  • Workaround for WMA tag editing failing on long file paths.
  • Converter: Prefer user specified converter paths over %PATH%.
  • Fixed Resampler DSP crashing on very old PCs due to a VS2017 compiler bug.
  • Various obscure crash bugs have been addressed (Converter, ReplayGain Scanner, Default UI).
  • MS Store: Fixed .FTH file type association; made MS Store mode reported to console on startup.
Download foobar2000 1.4.5 beta 1
Update!
foobar2000 for Mac 2.1.46 wurde veröffentlicht.
Changelog v2.1.46:
  • Various playlist behavior fixes. Column sizes and playlist scroll positions are now remembered.
  • Added upmix DSPs.
  • Updated UPnP playback features, in sync with UPnP MediaRenderer output component v1.3.2 on Windows.
Download foobar2000 for Mac 2.1.46
Update!
foobar2000 1.4.5 beta 2 wurde veröffentlicht.
Changelog v1.4.5:
  • Fixed crashing when exiting foobar2000 while playing an internet radio stream (beta 2).
Download foobar2000 1.4.5 beta 2
Update!
foobar2000 1.4.5 Final wurde veröffentlicht.
Many known bugs have been addressed. All 1.4.x users should update.
Changelog v1.4.5:
Download foobar2000 1.4.5 Final
Update!
foobar2000 1.4.6 beta 1 wurde veröffentlicht.
Changelog v1.4.6:
  • Made Converter never overwrite the source files.
  • Fixed Properties autocomplete vs multiline edit box clash.
  • Fixed earlier 1.4 series regression with writing of ID3v2 COMMENT fields to TXXX frames instead of COMM.
Download foobar2000 1.4.6 beta 1
Update!
foobar2000 1.4.6 beta 2 wurde veröffentlicht.
Changelog v1.4.6:
  • Fixed incorrect Converter output with both “don't reset DSP between tracks” and “copy other files” features in use (beta 2).
Download foobar2000 1.4.6 beta 2
Update!
foobar2000 1.4.6 Final wurde veröffentlicht.
Changelog v1.4.6:
Download foobar2000 1.4.6 Final
foobar2000 for Mac 2.1.47 wurde veröffentlicht.
Changelog v2.1.47:
  • Playlist manipulation bug fixes.
  • Fixed tracks not being correctly added to playlist in some scenarios.
Download foobar2000 for Mac 2.1.47
Update!
foobar2000 1.5 beta 1 wurde veröffentlicht.
Changelog v1.5:
  • New and improved Properties dialog, with the ability to manipulate attached pictures as well as scan and modify ReplayGain values.
  • Greatly improved Selection Properties performance for large track lists.
  • Various prompts (such as delete/recycle) now come with a “do not show this again” checkbox.
  • Restored pre-1.4 behavior of main-window-hidden/notification-icon-only status being remembered after foobar2000 restart.
  • Added logging of Media Library scanning errors - “show errors” button in Media Library Preferences.
  • Added Advanced Preferences option for flushing playback queue on manual track change (default: on).
  • Made “Open containing folder” command work with tracks in archives - opens folder containing the archive.
  • Added an option to preserve last-modified timestamps of tracks when updating tags.
  • Additional safeguards against corrupted configuration in case of a system crash while saving (FlushFileBuffers).
  • File Operations: delete/recycle prompt always says “Delete” rather than “Recycle”, since not every volume supports recycle action.
  • FFmpeg 3.4.6, now compiled with MS compiler, binary size reduced due to DLL runtime.
  • Implemented reading of cue+bin audio CD images.
  • Implemented asynchronous drag&drop, for less stalls when dragging tracks foobar2000 to another program.
Download foobar2000 1.5 beta 1
foobar2000 for Mac 2.1.48 wurde veröffentlicht.
Changelog v2.1.48:
  • Fixed playback status not being restored after app restart.
Download foobar2000 for Mac 2.1.48
Update!
foobar2000 1.5 beta 3 wurde veröffentlicht.
Changelog v1.5:
  • Implemented asynchronous drag&drop, for less stalls when dragging tracks from foobar2000 to another program.
Download foobar2000 1.5 beta 3
Update!
foobar2000 1.5 beta 4 wurde veröffentlicht.
Changelog v1.5:
Download foobar2000 1.5 beta 4
Update!
foobar2000 1.5 beta 5 wurde veröffentlicht.
Version 1.5 beta change log (Thread im offiziellen Forum):
Beta 2:
  • Fixed Selection Properties panel showing blank content in some cases.
  • Properties dialog: made some column widths remembered.
  • Properties dialog: made album art import/export dialogs begin in the folder of the audio file.
  • Properties dialog: restored sanity of Details group order.
  • Properties dialog: other minor fixes.
  • Screen reader compatibility fixes for new list controls
  • File Operations: fixed disappearing windows on Windows 10 1809 and newer.
Beta 3:
  • Properties dialog: fixed crashing on single CPU core machines.
  • Properties dialog: tab order sanity fix.
  • Properties dialog: made '+ add new' field list autocomplete not exclude already-present fields.
  • File Operations: fixed crash bug related to delete command.
  • Made stack overflow crashes produce a crash report instead of just making foobar2000 die quietly.
  • Amended Enter key handling in various new list controls.
  • Screen reader compatibility fixes, made checkboxes in new list controls presented properly.
  • Experimental visual style changes on various new list controls.
Beta 4:
  • Fixed beta 3 regression with wrong rendering of selection in some of list controls, most notably Default UI playlist.
  • Updated enter key handling in DSP Manager.
Beta 5:
  • Properties dialog: better auto sizing of columns in Metadata & Details.
  • Properties dialog: less glitchy embedding of tab content in tabs.
  • Properties dialog: re-styled '+ add new' button.
  • Restored enter key to open decoder configuration in Preferences / Decoding.
  • Fixed embedded cuesheet handling regressions (since 1.5 beta).
  • Screen reader compatibility fixes, made list group headers presented correctly.
Changelog v1.5:
Download foobar2000 1.5 beta 5
Update!
foobar2000 1.5 beta 6 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
  • Fixed visual glitches when scrolling various lists (beta 5 regression).
  • Fixed incorrect automatic sizing of columns in Properties dialog.
Changelog v1.5:
Download foobar2000 1.5 beta 6
Update!
foobar2000 1.5 beta 7 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
  • Fixed incorrect shuffle behavior forum thread
  • Fixed Album List multi-selection regression forum thread
  • Attempted fix for DirectSound lockups after PC hibernation forum thread
  • Made Album Art Viewer picture loading+resizing asynchronous.
  • Removed the much hated behavior of nulling current selection info (album art, selection properties) when nothing has focus.
  • Fixed M4A album art handling regression forum thread
Changelog v1.5:
Download foobar2000 1.5 beta 7
foobar2000 for Mac 2.1.49 wurde veröffentlicht.
Changelog v2.1.49:
  • More graceful behavior of sliders in DSP and ReplayGain settings.
  • Cuesheet handling regressions fixed.
  • Fixed ReplayGain track/album mode by playback order.
Download foobar2000 for Mac 2.1.49
Update!
foobar2000 1.5 beta 9 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
  • Fixed keyboard shortcuts for Yes/No buttons etc not working in some of MessageBox-type dialogs forum thread
  • Fixed album art crash on malformed picture data (beta 7 regression).
  • Fixed selection properties not following playback when nothing is focused (beta 7 regression) forum thread
  • Improved performance of updating tags on the now-playing track.
  • Made show_preferences() and various methods accept advanced preferences item GUIDs alongside preferences page GUIDs. This means that components can now have 'configure' links/buttons open Advanced Preferences locations.
  • New programming interfaces: input_info_filter (for foo_external_tags) and input_playback_shim (for foo_skip), new SDK will be published shortly.
  • Fixed bugs in lyrics3 tag reader introduced with beta 7.
  • Converter: Added Opus encoder selection for --music / --speech modes.
Beta 9:
  • Fixed beta 8 crash regression.
Changelog v1.5:
Download foobar2000 1.5 beta 9
Update!
foobar2000 1.5 beta 10 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
  • Various issues related to reporting exact playback position have been fixed. Wave seekbar style components show exact position with skip silence DSP active and similar.
  • Fixed Default UI Playlist View last column layout glitch regression forum thread.
  • Fixes in new programming interfaces for foo_external_tags.
  • Removed lyrics3 tag support other than removal via 'Remove Tags' - as it was causing more trouble than it was worth.
  • Default UI Album Art view regression fixes.
  • Cuesheet handling regression fixes.
  • DirectSound output workarounds for stuck playback on disconnected/locked device.
  • Properties dialog album art manipulation fixes.
  • Properties dialog autocomplete behaviors changed.
  • Fixed a bug causing certain components built using old foobar2000 SDK to fail to decode audio if certain new components are installed.
Changelog v1.5:
Download foobar2000 1.5 beta 10
Update!
foobar2000 1.5 beta 11 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
  • Fixed beta 10 regression causing File Integrity Verifier not to use multiple threads for scanning.
  • File size optimizations.
  • Library Preferences: fixed missing double-click-on-folder.
  • Support for latest External Tags component.
Changelog v1.5:
Download foobar2000 1.5 beta 11
Update!
foobar2000 1.5 beta 12 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
  • Fixed preserve-file-timestamp bugs.
  • Fixed missing file-not-found error message. forum thread
  • Fixes for bad interaction between pre-1.4-SDK components and track info filters.
  • Fixed possible rare shutdown crash with certain components installed.
  • Playlist behavior fix. forum thread
  • Fixed metadb edit callbacks not being fired in some conditions.
  • Removed transacted filesystem support. There are no known benefits to it and even Microsoft documentation says not to use it.
  • Fixed track info filters (foo_external_tags) vs MP3 remove-tags.
  • Made track info filters (foo_external_tags) enabled by default once installed.
  • FLAC 1.3.3
  • Made WavPack/DSD MD5 visible - using another field so Verifier doesn't try to verify it.
  • Enabled embedded cuesheet support for MP3 files.
  • New list control in various Converter dialogs.
Changelog v1.5:
Download foobar2000 1.5 beta 12
Update!
foobar2000 1.5 beta 13 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
  • FLAC 1.3.3
Beta 13:
  • Prettier startup UI picker upon installation of a new UI component.
  • Made possible to check for updates of components listed but not hosted on foobar2000.org.
  • Changed Properties dialog autocomplete behaviors forum thread
  • Attempted workaround for reported shutdown lockup forum thread
  • Changed order of FLAC metadata block to mitigate bugs in Windows 10 forum thread
  • Fixed non-decoding of specific Ogg Vorbis files forum thread
  • Workaround for slow seeking in Matroska files.
Changelog v1.5:
Download foobar2000 1.5 beta 13
Update!
foobar2000 1.5 beta 14 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
  • FLAC 1.3.3
Beta 13:
Beta 14:
  • Fixed beta 13 regression causing Verifier to incorrectly flag MP3 files as problematic forum thread
Changelog v1.5:
Download foobar2000 1.5 beta 14
Update!
foobar2000 1.5 beta 15 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
  • FLAC 1.3.3
Beta 13:
Beta 14:
Beta 15:
  • Fixed regressions in components updater dialog, manifesting themselves when you close & reopen the dialog.
  • Fixed bad behavior of properties dialog when cancelling initial info load forum thread
Changelog v1.5:
Download foobar2000 1.5 beta 15
Update!
foobar2000 1.5 beta 16 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
  • FLAC 1.3.3
Beta 13:
Beta 14:
Beta 15:
Beta 16:
  • Fixed more regressions in components updater dialog.
  • Fixed missing keyboard shortcuts in new yes/no/ok/cancel type dialogs forum thread
Changelog v1.5:
Download foobar2000 1.5 beta 16
Update!
foobar2000 1.4.7 Final wurde veröffentlicht.
This version contains just bug fixes backported from the 1.5 series.
Changelog v1.4.7:
  • File Operations: Fixed window order bugs with Windows 10 1809 and newer
  • Fixed creation of crash reports from stack overflow crashes.
  • Fixed some Ogg files being unplayable since version 1.4.
  • Changed order of written FLAC metadata blocks to work around bugs in Windows Explorer.
  • Misc bug fixes.
Download foobar2000 1.4.7 Final
Moin Chris,
hehe... das musste jetzt einfach mal sein, nach 59 Jahren. :d
Update!
foobar2000 1.5 beta 18 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
  • FLAC 1.3.3
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
  • Reverted DirectSound changes that seem to cause trouble for some users.
  • Improved playback position reporting accuracy with complex DSP configurations, for better operation of Wave Seekbar type components.
  • Made strange/malformed MP4 files not refuse to play entirely if the first audio frame can't be decoded.
  • List control behavior and screen reader compatibility fixes.
Beta 18:
  • Fixed beta 17 DirectSound crash regression
  • Screen reader compatibility improvements
Changelog v1.5:
  • FLAC 1.3.3
  • Improved programming interfaces for External Tags and Skip Track components.
  • Made album art loading/resizing operations in Default User Interface asynchronous. Large pictures no longer make the app momentarily unresponsive.
  • Converter: Added Opus encoder selection for –music / –speech modes.
  • Converter: New list control in various dialogs. Column sizes are remembered.
  • Improved playback position reporting with Skip Silence and similar DSP effects.
Download foobar2000 1.5 beta 18
