Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
[Sammelthread]foobar2000 v2.24 Final wurde veröffentlicht
Fixed Album List multi-selection regression forum thread
Attempted fix for DirectSound lockups after PC hibernation forum thread
Made Album Art Viewer picture loading+resizing asynchronous.
Removed the much hated behavior of nulling current selection info (album art, selection properties) when nothing has focus.
Fixed M4A album art handling regression forum thread
Beta 8:
Fixed keyboard shortcuts for Yes/No buttons etc not working in some of MessageBox-type dialogs forum thread
Fixed album art crash on malformed picture data (beta 7 regression).
Fixed selection properties not following playback when nothing is focused (beta 7 regression) forum thread
Improved performance of updating tags on the now-playing track.
Made show_preferences() and various methods accept advanced preferences item GUIDs alongside preferences page GUIDs. This means that components can now have 'configure' links/buttons open Advanced Preferences locations.
New programming interfaces: input_info_filter (for foo_external_tags) and input_playback_shim (for foo_skip), new SDK will be published shortly.
Fixed bugs in lyrics3 tag reader introduced with beta 7.
Converter: Added Opus encoder selection for --music / --speech modes.
Beta 9:
Fixed beta 8 crash regression.
Beta 10:
Various issues related to reporting exact playback position have been fixed. Wave seekbar style components show exact position with skip silence DSP active and similar.
Fixed Default UI Playlist View last column layout glitch regression forum thread.
Fixes in new programming interfaces for foo_external_tags.
Removed lyrics3 tag support other than removal via 'Remove Tags' - as it was causing more trouble than it was worth.
Default UI Album Art view regression fixes.
Cuesheet handling regression fixes.
DirectSound output workarounds for stuck playback on disconnected/locked device.
Properties dialog album art manipulation fixes.
Properties dialog autocomplete behaviors changed.
Fixed a bug causing certain components built using old foobar2000 SDK to fail to decode audio if certain new components are installed.
Beta 11:
Fixed beta 10 regression causing File Integrity Verifier not to use multiple threads for scanning.
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Hey Bollerkopp, erstmal danke fuer dein Engagement hier
Ich nutze nun foobar seit ein paar Jahren und bin echt zufrieden mit dem Player. Seit ca 1 Jahr habe ich mir ein Raspberry ZeroW zugelegt und RuneAudio installiert und nutze diesen als Zuspieler fuer meine Anlage. Mit dem Streaming plugin von foobar konnte ich bisher ohne Probleme Musik zum Raspberry ZeroW streamen. Seit ein paar Tagen stoppt der Stream nach ein paar Sekunden einfach. Bis auf Win10 Updates wurde eigentlich nichts veraendert. Zusaetzlich zeigt mir foobar 2 Raspberries als Ziel an Egal welchen ich auswaehle der Stream bricht nach ein paar Sekunden ab.
Habe schon versucht eine Loesung zu finden, allerdings nicht erfolgreich. Hast du eine Idee voran es liegen koennte?
New and improved Properties dialog, with the ability to manipulate attached pictures as well as scan and modify ReplayGain values.
Greatly improved Selection Properties performance for large track lists.
Various prompts (such as delete/recycle) now come with a “do not show this again” checkbox.
Restored pre-1.4 behavior of main-window-hidden/notification-icon-only status being remembered after foobar2000 restart.
Added logging of Media Library scanning errors - “show errors” button in Media Library Preferences.
Added Advanced Preferences option for flushing playback queue on manual track change (default: on).
Made “Open containing folder” command work with tracks in archives - opens folder containing the archive.
Added an option to preserve last-modified timestamps of tracks when updating tags.
Additional safeguards against corrupted configuration in case of a system crash while saving (FlushFileBuffers).
File Operations updates:
- Delete/recycle prompt always says “Delete” rather than “Recycle”, since not every volume supports recycle action.
- Copy operations now preserve creation/modification time.
- Added pause.
- More consistent behaviors when cancelled while moving files.
- Fixed a bug preventing hard deleting (not recycling) of now playing audio track.
FFmpeg 3.4.6, now compiled with MS compiler, binary size reduced due to DLL runtime.
FLAC 1.3.3
Implemented reading of cue+bin audio CD images.
Implemented asynchronous drag&drop, for less stalls when dragging tracks from foobar2000 to another program.
Removed transacted filesystem support. There are no known benefits to it and even Microsoft documentation says not to use it.
Improved programming interfaces for External Tags and Skip Track components.
Made album art loading/resizing operations in Default User Interface asynchronous. Large pictures no longer make the app momentarily unresponsive.
Converter: Added Opus encoder selection for –music / –speech modes.
Converter: New list control in various dialogs. Column sizes are remembered.
Improved playback position reporting with Skip Silence and similar DSP effects.
Made possible to check for updates of components listed but not hosted on foobar2000.org.
Enabled embedded cuesheet support for MP3 files.
Made WavPack/DSD MD5 visible - using another field so Verifier doesn't try to verify it.
Made strange/malformed MP4 files not refuse to play entirely if the first audio frame can't be decoded.
Fixed a long-time bug with erratic behavior of audio output device selection.
Fixed unnecessary flashing / spurious updates of current item text box in generic progress dialogs.
Fixed resampler DSP crashing when asked to resample to 0 Hz.
Fixed a bug with could lead to stuck foobar2000 process after playing a network stream.
Worked around a problem with EsPlaylist and playback queue operations since version 1.5.
Changed playback information behavior after editing tags of a now playing track, causing some components to think the track was played twice since version 1.5.
Beta 3:
Amended playback queue changes from beta 2, fixing apparent infinite playback of one queued track.
Beta 3:
Beta 4:
Converter: No longer writes MP3 with embedded cuesheets.
Converter: Fixed missing select-newly-added-item with format list.
Converter: Improved feedback when trying to convert a multichannel source to MP3 or MPC.
Reworked integration with Windows 10 Universal Volume Control. Enabled by default once again.
Fixed a bug in upmix DSPs causing incorrect behavior when working with a mono source.
Improved reading of certain malformed ID3 tags written by other software.
Generic progress dialog now shows yellow pause status when paused.
Generic progress dialog no longer remembers its last position.
File Operations: improved removal of empty folders; should no longer leave empty folders behind when cancelled in mid-operation.
Installed component DLLs should now retain original file modification time, rather than time at which they were installed.
Addressed some of known incompatibilities between foobar2000 v1.5 and third party components.
Made Converter not write MP3 files with embedded cuesheets. This was an unintended effect of a v1.5 change. A proper setting for this will be added at a later time.
Improved Converter feedback when trying to convert a multichannel track to MP3 or MPC, which accept no more than two channels.
Fixed a bug causing wrong playback position to be shown after listening to an internet radio.
Dazu kann ich leider nicht allzu viel beitragen, da ich den MS-Store noch nie genutzt habe. Ich habe das Teil (wie viele andere überflüssige Dinge) sogar mittels WinReducer komplett aus meiner angepassten Win10-Installations-DVD verbannt.
Das kann ich natürlich nachvollziehen. Allerdings bevorzuge ich persönlich es generell bei Updates, dass ich sie manuell installiere, nachdem ich die Changelogs gelesen habe und abschätzen kann, was mich erwartet und ob es sich lohnt.
Ich habe noch nie (und werde es weiterhin nicht) einen Browser von MS benutzt. Für mich persönlich gibt es nur Vorteile ohne den "Store". Aber das ist ja Geschmacks- und Ansichtssache.
Ja und nicht jeder nutzt Edge damit dreht man sich im am Ende im Kreis was das Nutzerverhalten angeht, Handhabe es auch wie Bollerkopp, der Windows Store ist auch verbannt und Updates nur vor Kontrolle einspielen und wenn es Sicherheitstechnisch oder Feature-technisch Sinn macht versteht sich.
Pointed freedb metadata lookup at freedb.dbpoweramp.com, since original freedb is being shut down.
- Beta 2: more graceful import of custom server lists when upgrading from older version.
Corrected a 1.5.3 regression causing certain very short MP4/M4A files to decode incorrectly.
Internal changes to allow add-on components to correctly decode xHE-AAC format.
