[Sammelthread] foobar2000 v2.24 Final wurde veröffentlicht
foobar2000 1.6 beta 14 wurde veröffentlicht.
Version 1.6 beta change log (Thread im offiziellen Forum):
Beta 2:
  • Standard DSP Array is no longer an optional component, as it's required for new WASAPI output to work correctly.
  • Converter: Added a toggle for encoding thru temp folder to custom command-line encoder setup, required for some encoders that don't support Unicode.
  • Fixed missing WM_ENABLE handler causing some list controls (component updater in particular) to be shown incorrectly.
  • Allowed weird channel counts in Opus decoder.
  • New Visual Studio runtime DLLs
Beta 3:
  • Added alternate menu commands for opening Properties dialog with specific tab open, for mapping keyboard shortcuts only.
  • Improved recovery from unplugged audio output device.
  • Properties: smoother ReplayGain scan progress.
Beta 4:
  • Fixed evil memory leak in album art viewer, regression since 1.6 beta 1.
Beta 5:
  • Fixed incorrect behavior when repeatedly hitting prev/next with fading enabled.
  • Fixed resetting Output Preferences page not unchecking the fading checkbox.
  • Fixed visualisations being jerky in some cases with fading enabled.
  • Prevented "device in use" error from appearing when toggling fading with WASAPI exclusive.
Beta 6:
  • Additional editable Properties ReplayGain tab summary fields.
  • Fixed crash when trying to alter gain on a Matroska file with no recognized audio track.
Beta 7:
  • Fixed stuck foobar2000 process after playing very short files with fading enabled.
Beta 8:
  • Fixed jerky visualisation regression from earlier 1.6 betas.
  • New portable install now puts all configuration data in 'profile' subfolder of install folder instead of saving in the installation folder directly. Doesn't affect upgraded installs or non-portable.
Beta 9:
  • WASAPI output bug fixes.
Beta 10:
  • More WASAPI output bug fixes, fixed incompatibility with Windows 7.
Beta 11:
  • Fixed crashing on old WebP format album art.
  • Smooth playback: lowest buffer length is now 200ms to prevent audio glitching with overkill settings.
Beta 12:
  • Removing tags from raw AAC files now works properly.
  • Changed automatic resampling behaviors. Choice of output method no longer affects the visualisations.
  • The default output now works properly if fed sample rate different from what it expects, resamples on its own if needed (otherwise ABX component would not work).
  • If not overridden by user, the default resampler for automatic conversions is SSRC.
  • File Operations, Converter: Fixed file name sanitizer removing additional dots before the file extension.
Beta 13:
  • Fixed ZIP reader memory leak bug. Thanks to djdron for reporting.
  • Improved behavior when audio output device is in exclusive use by another application.
Beta 14:
  • Improved handling of file modification timestamps in ZIP and RAR archives.
  • Fixed audio glitching when changing DSP settings - most apparent when dragging equalizer sliders.
  • Fixed a bug causing high CPU usage with some autoplaylists (force sorted with no sort pattern specified).
Changelog v1.6:
  • Changed system requirements: Windows 7 and a processor with SSE2 instruction set. Windows XP is no longer supported.
  • Default output mode is now WASAPI shared.
  • New fading capability that works with alternate output modes.
  • Default archive reader now supports 7-zip format.
  • Added support for WebP album covers (Default UI, Properties dialog). Settings need to be changed to look for folder.webp instead of folder.jpg.
  • Removed mixer volume sync feature due to bugs.
  • Cleaned up foo_rgscan alter-file-content & alter-opus-header methods.
  • Removed obsolete edit-replaygain-info menu command since Properties dialog does the same now.
  • Added an option to disregard mouse back/forward buttons (by default mapped to previous/next track).
  • Double clicking a line in Properties album art tab now opens a fullsize image viewer.
  • Fileops & Converter: Added alternate handling of invalid filename characters, toggled in Advanced Preferences.
  • Freedb component updated: now queries all configured servers and displays results grouped by server.
  • Updated File Operations & Converter file name pattern picker dialog, now auto selects current pattern on open if possible.
  • CDDA reading no longer requires admin privileges on Windows Server.
  • Updated autoplaylist editing dialogs, made resizable.
  • Standard DSP Array is no longer an optional component, as it's required for new WASAPI output to work correctly. (beta 2)
  • Converter: Added a toggle for encoding thru temp folder to custom command-line encoder setup, required for some encoders that don't support Unicode. (beta 2)
  • Added alternate menu commands for opening Properties dialog with specific tab open, for mapping keyboard shortcuts only. (beta 3)
  • Improved recovery from unplugged audio output device. (beta 3)
  • Additional editable Properties ReplayGain tab summary fields. (beta 6)
  • Fixed crash when trying to alter gain on a Matroska file with no recognized audio track. (beta 6)
  • Fixed incorrect handling of folder/file.ext relative paths in playlists served over HTTP/HTTPS/FTP. (beta 7)
  • New portable install puts all configuration data in 'profile' subfolder of install folder instead of saving in the installation folder directly. Doesn't affect upgraded installs or non-portable. (beta 8)
  • Fixed 'remove tags' not correctly stripping tags from raw AAC files. (beta 12)
  • Fixed ZIP reader memory leak. (beta 13)
  • Improved handling of last modification times in ZIP and RAR archives. (beta 14)
  • Fixed a bug causing high CPU usage with autoplaylists that are force-sorted but with no pattern specified. (beta 14)
Download foobar2000 1.6 beta 14
foobar v1.6 Beta 15
Changes in beta 15
  • Fixed stuck WASAPI playback at the end of playlist.
  • Worked around device-in-use error when cycling smooth playback toggle while playing.
:d
foobar2000 1.6 beta 17 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
  • Revised automatic resampling behaviors, addressing "unsupported stream format" playback errors.
  • Fixed a crash when trying to load album art from a cuesheet that references itself.
  • Fixed stuck playback when playing very short files with varying channel counts.
Beta 17:
  • Fixed more stuck playback bugs with very short files.
  • Fixed installer flagging Columns UI as not working, if manually installed.
Changelog v1.6:
Download foobar2000 1.6 beta 17
foobar2000 1.6 beta 18 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
  • Fixed a long time bug causing files with very long names inside ZIP archives to be unplayable.
  • Internal changes in resampler management.
Changelog v1.6:
Download foobar2000 1.6 beta 18
foobar2000 v1.6 Final / foobar2000 v1.6.1 Beta 1
foobar2000 change log
1.6.1
  • Added support for HLS: HTTP Live Streaming. To use, add internet M3U8 file through Add Location dialog.
  • Enabled icy-metadata support for Ogg FLAC internet radio streams.
  • Updated Properties / ReplayGain page layout if editing a single file.
  • Improved Properties dialog performance, list of autocomplete entries is populated asynchronously.
  • Enabled embedded album art loading from raw .AAC files with ID3 tags.
  • Updated FFmpeg to 4.3.1.
  • Added support for playing Matroska A_MS/ACM content.
  • Fixes for rare AAC codec configurations that FFmpeg doesn't fully support - an add-on decoder can override the built-in one for such special cases.
  • Decoders are now made aware of output sample rate (from Windows Mixer settings) and can decode certain formats directly to the intended sample rate, skipping potential resampling steps.
1.6
  • Fixed installer incorrectly labelling some components as incompatible, if they have been installed by copying DLLs manually.
  • Fixed incorrect handling of ID3 itunescompilation=0.
  • Fixed a bug causing files with very long names inside ZIP archives to be unplayable.
:d
foobar2000 1.5.6 Final (old) wurde veröffentlicht.
Bugfix update for Windows XP users.
Changelog v1.5.6:
  • Bug fix update with latest fixes from 1.6 series.
Download foobar2000 1.5.6 Final (old)
foobar2000 1.6.1 beta 2 wurde veröffentlicht.
Version 1.6.1 beta change log (Thread im offiziellen Forum):
Beta 2:
  • Updated M3U #EXTINF behaviors
  • Added console logging of audio device mix format to troubleshoot audio device compatibility issues.
Changelog v1.6.1:
Download foobar2000 1.6.1 beta 2
foobar2000 1.6.1 beta 3 wurde veröffentlicht.
Beta 2:
Beta 3:
  • Fixed crash bug related to meta autocomplete (affecting tagbox component and possibly others).
  • Fixed channel remapping bugs with default audio output.
Changelog v1.6.1:
Download foobar2000 1.6.1 beta 3
foobar2000 1.6.1 beta 5 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
  • Fixed Converter & File Operations possibly creating folders that Windows Explorer cannot delete.
  • Fixed multi channel playback regressions from v1.6.
Beta 5:
  • Reverted to old autocomplete code for existing component to prevent incorrect behaviors.
  • Improved handling of audio files with uncommon channel layout.
Changelog v1.6.1:
Download foobar2000 1.6.1 beta 5
Wow, Super Thread, danke @Bollerkopp für die Mühe, den nach Jahren noch aktuell zu halten :)
Weiß jemand, ob es aktuell eine Möglichkeit gibt, TIDAL oder einen anderen Streaming Anbieter in Foobar einzubinden?
naja... wirklich viel Aufwand ist das ja nicht. Von daher finde ich immer mal die Zeit dafür. :)
Für TIDAL scheint es nicht möglich zu sein. Auf die Schnelle habe ich eine Möglichkeit für Spotify gefunden: foo_input_spotify
LG
Eine kleine Anpassung im Start-Post, weil ich gerade Langeweile und Bock darauf hatte.
LG & Küsschen auf's Nüsschen. :wink:
foobar2000 1.6.1 beta 6 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
  • Fixed wrong fade used when changing tracks manually rather than seeking within a track.
Changelog v1.6.1:
Download foobar2000 1.6.1 beta 6
foobar2000 1.6.1 beta 7 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
  • Changing volume no longer affects Windows Mixer sliders; restarting foobar2000 no longer resets Windows Mixer slider to 100%.
Changelog v1.6.1:
  • Fixed "fade on manual track change" setting not being used since version 1.6. (beta 6)
  • Changing volume no longer affects Windows Mixer sliders; restarting foobar2000 no longer resets Windows Mixer slider to 100%. (beta 7)
Download foobar2000 1.6.1 beta 7
foobar2000 1.6.1 beta 8 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
  • Mitigated crash when initiating drag&drop of a very large number of songs (such as Album List "all music").
  • Enabled support for 7-zip archives using PPMd compression.
Changelog v1.6.1:
  • Mitigated crash when initiating drag&drop of a very large number of songs (such as Album List "all music"). (beta 8)
  • Enabled support for 7-zip archives using PPMd compression. (beta 8)
Download foobar2000 1.6.1 beta 8
foobar2000 v1.6.1 Final
1.6.1
foobar2000 1.6.2 beta 1 wurde veröffentlicht.
Changelog v1.6.2:
  • HLS radio bug fixes.
  • Double clicking album covers in Default User Interface shows full-size picture.
  • Archive reader optimizations; much more efficient handling of uncompressed (store-mode) archives.
  • Drag-and-drop or copy-to-clipboard of large number of tracks no longer copies their plaintext titles.
Download foobar2000 1.6.2 beta 1
foobar2000 for Mac 2.2.10 wurde veröffentlicht.
Changelog v2.2.10:
  • Added support for HLS internet radio.
Download foobar2000 for Mac 2.2.10
foobar2000 1.6.2 beta 2 wurde veröffentlicht.
Changelog v1.6.2:
  • Fixed unresponsive Album List when selecting lots of items. (beta 2).
Download foobar2000 1.6.2 beta 2
foobar2000 1.6.2 beta 4 wurde veröffentlicht.
Changelog v1.6.2:
  • Added workarounds for wrong audio mix format reported by certain buggy soundcard drivers. (beta 3, beta 4)
  • Added workaround for too quiet playback since removal of Windows Mixer volume slider synchronization in previous versions. (beta 4)
Download foobar2000 1.6.2 beta 4
foobar2000 1.6.2 beta 5 wurde veröffentlicht.
Changelog v1.6.2:
  • Fixed crashing when attempting to read from 7-ziup archive that does not exist. (beta 5)
  • Increased playback queue length limit to 256 tracks. (beta 5)
Download foobar2000 1.6.2 beta 5
foobar2000 1.6.2 beta 6 wurde veröffentlicht.
Version 1.6.2 beta change log (Thread im offiziellen Forum):
Beta 2:
  • Fixed missing .webp in stub image picker.
  • Fixed bugs in new image viewer window.
  • Improved Album List performance when selecting lots of item.s
Beta 3:
  • Attempted fixes for new default output not working on some machines.
  • Additional output status logging to console.
Beta 4:
  • More fixes for new default output not working on some machines,
  • Correct too quiet Windows Mixer volume on first run.
Beta 5:
  • Fixed crash when trying to open a non-existent 7-zip archive.
  • Playback queue item limit increased to 256.
Beta 6:
  • Fixed wrong error message/status when trying to open a non-existent RAR archive.
  • More default output error logging.
  • Crash if stuck trying to update tags of now playing file for more than one minute, in order to generate crash reports of an apparent rare bug. This change will be reverted for the final version.
Changelog v1.6.2:
Download foobar2000 1.6.2 beta 6
foobar2000 1.6.2 beta 7 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
  • Fixed incompatibilities with certain bluetooth headsets introduced in 1.6.1.
  • Fixed incorrect handling of embedded pictures in Speex tags.
  • Fixed incorrect info shown for IMA ADPCM in Matroska.
  • Fixed no error message on failure to update embedded pictures if embedding of pictures is not supported for this file type. (beta 7)
Changelog v1.6.2:
  • Fixed incompatibilities with certain bluetooth headsets introduced in 1.6.1. (beta 7)
  • Fixed incorrect handling of embedded pictures in Speex tags. (beta 7)
  • Fixed incorrect info shown for IMA ADPCM in Matroska. (beta 7)
Download foobar2000 1.6.2 beta 7
foobar2000 1.6.2 Stable wurde veröffentlicht.
Changelog v1.6.2:
  • Removed nonsensical bit depth info shown with some Matroska files. (final)
  • Cleaned up listed file types in various "import picture" dialogs. (final)
  • Workaround for stuck process if attempting to update foobar2000 while running foobar2000 is busy. (final)
Download foobar2000 1.6.2 Stable
foobar2000 for Mac 2.2.11 wurde veröffentlicht.
Changelog v2.2.11:
  • Latest decoder codebase fixes.
  • Fixed Properties dialog bug that would overwrite specific field on all selected files with "«multiple values» ..." even if the editbox was dismissed with no changes.
Download foobar2000 for Mac 2.2.11
foobar2000 for Mac 2.2.14 wurde veröffentlicht.
Changelog v2.2.14:
  • Made album covers visible in menu bar playback controls.
  • Added ARM Neon optimizations for reduced CPU usage / improved battery life.
  • Fixed Decoding Speed Test discarding last edit when pressing "Run" immediately after.
  • Fixed toggled playlist columns not being reliably remembered.
Download foobar2000 for Mac 2.2.14
foobar2000 1.2.14 für Android wurde veröffentlicht.
Changelog v1.2.14:
  • Fixed crashing on Android 11.
  • Fixed a bug causing reappearing notification after manual dismiss.
Download foobar2000 1.2.14 für Android
Bei Problemen mit Google Play: Standalone Android APK downloads
foobar2000 1.2.14 für iOS wurde veröffentlicht.
Changelog v1.2.14:
  • Increased smooth playback buffer length to mitigate reported glitches.
Download foobar2000 1.2.14 für iOS
