Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
[Sammelthread]foobar2000 v2.24 Final wurde veröffentlicht
Now available as x86 32-bit (legacy), x86 64-bit. ARM 64-bit version coming soon. 64-bit versions require updated versions of add-on components.
Dark mode support on Windows 10 and 11. Add-on components need to be updated to utilize it.
Entirely new media library engine, backed by SQLite. Much faster startup and shutdown with large libraries, greatly reduced memory usage.
Greatly improved performance of media library search queries that don't use %patterns%.
Playback Statistics functionality is now built-in. Old foo_playcount data gets imported on first run. Please remove foo_playcount as instructed.
Added album art in Default User Interface playlist view.
Clickable rating stars in Default User Interface playlist view.
New Default UI element: ReFacets, reimplementing most of Facets functionality. Old Facets component doesn't work with new 64-bit foobar2000.
Improved Default UI splitter, now allows any number of panes.
Added 'remember per playlist layout' to Default User Interface playlist view.
Added 'stream selector' element to Default User Interface toolbar.
New audio output device management features - unwanted devices can be disabled, bit depth and DSP can be configured per-device.
New internal playlist format, changes instantly saved to disk, no more recent changes lost on crash.
New configuration data format, changes instantly saved to disk, no more recent changes lost on crash.
Can display file creation time (%file_created%) and attributes (%file_attributes%).
For non-portable installs, profile folder is now %appdata%\foobar2000-v2. There is no need to back up old profile before upgrading, your foobar2000 v1.x profile will be left untouched.
First run performs import of old configuration data (playlists, library).
More audio formats supported out of the box: TAK, APE, AC3, DTS.
Updated FFmpeg to version 5.1.
Improved Properties behavior if 'reload info' detects a change in number of chapters etc.
Rewritten built-in visualisations (VU/peak meters, spectrum, oscilloscope), now using hardware accelerated rendering.
Some Default UI Elements (ReFacets, Equalizer, visualisations) now also accessible as Columns UI panels.
Internet Radio dialog (File menu), remembers previously played Internet radio streams.
Modernized Explorer integration, no longer needs separate 32bit/64bit shell extension DLLs.
Properties dialog now follows theme colors of the active UI.
Utilized Windows Imaging Component for image parsing, removed libwebp dependency. Album covers in HEIF, AVIF, etc can now be viewed if system codecs are present.
Added %year% mapping, takes year part of %date%, discarding content past first four digits.
Changed default Album List patterns to use %year%.
Added sample rate exclusions to SSRC resampler.
Added crossfeed DSP from foobar2000 mobile.
New console logging system, writes per-instance log files to the specified folder.
New full config reset semantics - now clears profile folder (optionally leaving user-components intact) instead of asking all components to reset themselves.
These add-on components are now obsolete as their functionality is available out of the box: foo_benchmark, foo_bitcompare, foo_verifier, foo_input_monkey, foo_ac3, foo_sanitizer, foo_input_dts.
These components previously included with the installer are no longer optional (features always enabled): foo_rgscan, foo_cdda, foo_albumlist
Component loader no longer probes menu command GUIDs, which was crashing some components. Was meant to prevent specific known incompatible components from loading.
Now shows CPU architecture (x86 or x64) in about box.
Fixed Media Library performing unnecessary tag reloads in some scenarios.
Crash bugs fixed.
Made Preferences / Output / Devices usable without a mouse.
Crash bugs fixed.
Beta 4:
MP4 tagging: do not set Various Artists if itunescompilation is present but set to 0.
Crash bugs fixed.
Made installer refuse to upgrade old non-portable installs containing profile data in application folder, which is no longer supported.
Fixed metadb lock up with large queryInfoMulti() batches.
Fixed library search by rating not working.
Added ReFacets to library viewers list.
Fixed missing double click to fullscreen in Default UI visualisations.
Fixed disappearing live playback info on playback statistics update.
Fixed longer-than-necessary gap when reopening exclusive-mode output on format change.
Fixed seekbar & visualisation glitches when playing very short audio tracks with exclusive-mode output.
Crash bugs fixed.
Beta 4:
Crash bugs fixed.
Beta 5:
Fixed various crash bugs.
Improved rendering performance of very large playlists with grouping & album art enabled.
Made ReFacets sorting remembered.
Fixed inverted titles of "Add Files" vs "Open" dialogs.
Reduced output reopen delay when input format (channel count etc) changes.
Crash bugs fixed.
Beta 4:
Crash bugs fixed.
Beta 5:
Crash bugs fixed.
Beta 4:
Crash bugs fixed.
Beta 5:
libFLAC 1.4, made possible to decode 32 bits per sample FLAC files.
Crash bugs fixed.
Beta 4:
Crash bugs fixed.
Beta 5:
Crash bugs fixed.
Beta 4:
Crash bugs fixed.
Beta 5:
Crash bugs fixed.
Beta 4:
Crash bugs fixed.
Beta 5:
Crash bugs fixed.
Beta 4:
Crash bugs fixed.
Beta 5:
Crash bugs fixed.
Beta 4:
Crash bugs fixed.
Beta 5:
Crash bugs fixed.
Beta 4:
Crash bugs fixed.
Beta 5:
Fixed playlist layout glitch regression from beta 5.
Beta 7:
Upgrading from v1.x retains file timestamps of profile folder contents.
Fixed bad handling of user-components folder in upgraded legacy portable installs without a "profile" folder.
Playlist rendering and manipulation performance fixes.
DTS decode_postprocessor now works, for decoding DTS in WAV, FLAC, etc.
Fixed incorrect behavior after a watched media library folder disappears then reappears.
Allowed blank meta values in metadb.
Made possible to enable album art columns in Default UI playlist even without grouping enabled - the old behavior was confusing.
Added dark mode to Default UI toolbar buttons configuration dialog.
Made settings of old foo_albumlist & foo_sanitizer imported on startup, if present.
Beta 8:
Fixed beta 7 regression with wrong handling of blank meta values.
Fixed some visual glitches in Converter.
Rare crash bug workarounds.
Improved crash log writer in 64-bit version.
Beta 9:
Updated WavPack library to 5.5.0.
Updated Monkey's Audio library to 8.70.
Changed replacement for slash character in file naming.
Fixed a regression that made it impossible to play certain M4A HE-AAC files from remote (HTTP etc) sources.
Various ReFacets glitches fixed.
Made new library search implementation more robust.
Cleaned up Ogg reader, made possible to seek in remote (HTTP etc) Ogg files.
Crash bugs fixed.
Beta 10:
Fixed Ogg seeking regressions from the previous beta.
Made column order correctly remembered per-playlist.
libFLAC 1.4.1.
Rewritten asymmetric library search feature.
Library search speed optimizations, made more queries utilize search index.
Restored multi-folder-selection for "add folder".
Beta 11:
Fixed incorrect MD5 verification of 32-bit FLAC files.
Fixed non-decoding of DTSHD files.
Added option to override DRC behavior on AC-3 audio.
Various crash bugs fixed.
Beta 12:
Improved behavior when watched library folders are on temporarily unavailable network shares.
Fixed audio glitching on screen resolution change in certain configurations.
Improved exclusive output behavior with uncommon channel layouts, 4.1/5.0 would not play on a device expecting 5.1-side.
Fixed failure to read specific odd FPL files.
Beta 13:
Fixed poor search performance with asymmetric search enabled.
Fixed dark mode in Converter overwrite prompt.
Reverted visualisations to GDI rendering by default. Use advanced preferences toggle to enable D2D. Too many systems fail at D2D rendering.
Mitigated media indexing crash on Wine by cutting down use of std::current_exception() / std::rethrow_exception().
libFLAC & zlib update.
Channel mask display fixes.
Fixed wrong length reporting in Binary Comparator.
No longer reports FLAC files with ID3 tags as corrupted.
Workarounds for poor performance of metadb_index operations compared to v1.x series (affects third party components only).
Programming interface extensions for components:
- Made possible to apply DSP config changes without reinitializing affected DSPs.
- Allowed DSPs to manipulate their shown name depending on preset data.
- Addded non-blocking DSP configuration popups.
- Added library_manager_v5 with extra status info methods (new SDK needed to utilize).
libFLAC 1.4.2, made possible to decode 32 bits per sample FLAC file.
Worked around FLAC files with ID3 tags being reported as corrupted by new libFLAC.
zlib 1.2.13.
Fixed incorrect handling of M4A itunescompilation=0.
WavPack 5.5.0.
Compiled with Visual Studio 2022.
Added mitigations for apparent random crash on Wine (less C++ exceptions thrown when dealing with media indexing errors).
habe jetzt gerade auf die neueste Beta upgegraded, leider wurde ein Problem nicht behoben, welches ch in der 12er Version auch hatte.
Was seit 1000 jahren immer funktioniert hat war einen globalen key zu setzen um Musik zu pausieren, in meinem Fall Numpad 0. Noch den Haken bei Global setzen und ich konnte immer Musik pausieren. Das funktioniert jetzt nicht mehr wirklich, ich muss den player immer im Vordergrund haben, sonst geht es nicht, auch mit der globalen Variable. Ist das bei euch auch so?
€_ ich merke gerade, der Hotkey funktioniert, nur unter Chrome nicht
ich habe das gerade mal unter der Beta 13 nachgestellt. Bei mir funktioniert es auch global mit dem Numpad 0. Hast Du mal versucht die Key-Einstellung in den Einstellungen zu löschen und neu anzulegen. Evtl. auch mal mit einem anderen Hotkey testen.
eben mal probiert, bleibt dabei. An sich funktioniert es global, nur nicht wenn ich mit Chrome surfe. Dann geht es zwar auch, aber ich muss 0 5 oder 6 mal schnell hintereinander drücken, wassn da los OO
€: auch mit anderen Hotkeys ist das Problem das selbe, Chrome ist das Problem
Crash bugs fixed.
Beta 4:
Crash bugs fixed.
Beta 5:
Beta 7:
Beta 8:
Beta 9:
Crash bugs fixed.
Beta 10:
libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Enabled search indexing of file paths by default.
- Because this somewhat affects performance and some people just don't care, an advanced option to turn it off has been added.
WavPack library update.
More compatible reading of exotic AIFF files.
Fixed a very old bug in 8-bit AU writer.
Added sanitization of internet radio metadata as certain station was serving nonsensical sample rate info.
Improved compatibility with MP4 files made with yt-dlp.
Improved compatibility with stripped down Windows 10 distributions.
zlib 1.2.13.
WavPack 5.5.0.
Playlist manipulation performance fixes.
Beta 6:
Shutdown crash regression fix.
Beta 7:
Fixed playlist sorting not respecting ascending/descending state.
Beta 8:
libFLAC 1.4.1.
Beta 9:
Fixed internet radio playlist parsing bug.
Beta 10:
Fixed race condition crash in module decoder.
Fixed failure to read specific XM modules (nothing added to playlist).
Beta 11:
Fixed window position remembering bugs.
Closing main window now exits foobar2000.
Added Audio Unit DSP support.
Verifier: do not report ID3 tags in FLAC as corrupted file errors.
Fixed lockup bug with stale/dead net shares in Media Library.
Required Mac OS version is now 10.13.
Beta 12:
Fixed a beta 11 regression causing "open...", "add folder..." etc to fail.
Beta 13:
Audio Unit support improvements.
Crash bugs fixed.
Beta 4:
Crash bugs fixed.
Beta 5:
Beta 7:
Beta 8:
Beta 9:
Crash bugs fixed.
Beta 10:
libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Fixed various library search expression handling bugs.
Made FLAC tag updater remove ID3v2 garbage prefixing FLAC stream.
Made ERROR_BAD_LENGTH condition crash to debug specific network share compatibility issue.
Made MP3 reader report MP3 frame count not matching Xing/LAME header info when verifying integrity.
zlib 1.2.13.
WavPack 5.5.0.
Beta 6:
Beta 7:
Beta 8:
libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Made FLAC tag updater kill ID3v2 garbage prefixing FLAC stream.
