Code:
SMART Error Log Version: 1
ATA Error Count: 30 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 30 occurred at disk power-on lifetime: 363 hours (15 days + 3 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
84 43 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
61 b0 88 98 49 c4 40 08 00:03:26.806 WRITE FPDMA QUEUED
61 40 80 58 44 c4 40 08 00:03:26.796 WRITE FPDMA QUEUED
61 58 78 a0 9a c0 40 08 00:03:26.796 WRITE FPDMA QUEUED
61 08 70 00 99 c0 40 08 00:03:26.796 WRITE FPDMA QUEUED
61 68 68 58 1e c0 40 08 00:03:26.796 WRITE FPDMA QUEUED
Error 29 occurred at disk power-on lifetime: 363 hours (15 days + 3 hours)
61 40 08 58 44 c4 40 08 00:03:26.434 WRITE FPDMA QUEUED
61 78 30 08 18 80 40 08 00:03:26.429 WRITE FPDMA QUEUED
61 08 28 48 1e c0 40 08 00:03:26.429 WRITE FPDMA QUEUED
61 68 20 58 1e c0 40 08 00:03:26.429 WRITE FPDMA QUEUED
61 08 18 00 99 c0 40 08 00:03:26.429 WRITE FPDMA QUEUED
Error 28 occurred at disk power-on lifetime: 363 hours (15 days + 3 hours)
61 78 c8 08 18 c0 40 08 00:03:26.043 WRITE FPDMA QUEUED
61 b0 78 98 49 c4 40 08 00:03:26.039 WRITE FPDMA QUEUED
61 40 70 58 44 c4 40 08 00:03:26.039 WRITE FPDMA QUEUED
61 58 68 a0 9a c0 40 08 00:03:26.039 WRITE FPDMA QUEUED
61 08 60 00 99 c0 40 08 00:03:26.039 WRITE FPDMA QUEUED
Error 27 occurred at disk power-on lifetime: 363 hours (15 days + 3 hours)
61 80 d8 00 18 00 40 08 00:03:25.678 WRITE FPDMA QUEUED
61 08 98 d8 1a c0 40 08 00:03:25.674 WRITE FPDMA QUEUED
61 78 90 08 18 40 40 08 00:03:25.674 WRITE FPDMA QUEUED
61 20 88 00 19 c0 40 08 00:03:25.674 WRITE FPDMA QUEUED
61 78 80 08 18 c0 40 08 00:03:25.674 WRITE FPDMA QUEUED
Error 26 occurred at disk power-on lifetime: 363 hours (15 days + 3 hours)
61 80 a0 00 18 40 40 08 00:03:25.298 WRITE FPDMA QUEUED
61 40 90 58 44 c4 40 08 00:03:25.298 WRITE FPDMA QUEUED
61 58 88 a0 9a c0 40 08 00:03:25.297 WRITE FPDMA QUEUED
61 08 80 00 99 c0 40 08 00:03:25.297 WRITE FPDMA QUEUED
61 68 78 58 1e c0 40 08 00:03:25.297 WRITE FPDMA QUEUED
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Was bedeuten diese Meldungen?!
