Game freezed after updated drivers to 528.02. Rtx 4090
swrt45
Profi
Hi. I have 12900K stock
32 GB 2x16 GB DDR4 3600mhz
Palit Gamerock Pro OC rtx 4090
1300W Seasonic Platinum Prime
Aorus Elite DDR4 Z690
Windows 11 2H22. Updated today to 528.02 . Run few game no issues. I launched Watch Dogs Legion and after 5 seconds screen freezed. Mouse and keyboard not responding. Then i force ctrl alt delete to logout from system. Happened once. Also no driver crash in event log. Just simple freeze. Should i worry?thx. I mean its fine now but i only asked cause this happened.thx
Once is nothing at all...
I would ignore it for now. If it happens again, you can remove the drivers with DDU and reinstall them...
