GTL settings ?
Spezi-rl
Banned
Frankfurt (Oder)
was hat es mit den gtl settings auf sich ?
wie kann man das verstehen, was man da zu ändern hat ?
und ab wann sollte man da etwas ändern ?
Anandtech erklärt das eigentlich ganz gut: http://www.anandtech.com/mb/showdoc.aspx?i=3283&p=18
Hier der wichtigste Part:
"Intel's GTL specification dictates that each reference voltage should be tightly controlled as 67% of the current VTT voltage (0.67 times CPU VTT Voltage). Typically, changes in VTT are automatically compensated with standard voltage divider circuits dedicated to the generation of each GTL reference voltage. Historical data has shown that dual-core CPUs (in particular 45nm dual-cores) often clock to higher FSB levels when the GTL reference values are closer to 63 ~ 64% of VTT while quad-core CPUs usually need the full strength value or even a little more voltage (67 ~ 70% of VTT).
As an exercise in the application of basic math, consider the following. With VTT at 1.10V, the GTL reference voltages at 67% would be 0.737V (0.67 times 1.10V). If VTT increased to 1.26V, the new GTL reference voltage would be 0.844V, calculated the same as before. If we wanted to adjust this down to 63%, we would simply multiply the current VTT voltage by the difference between the actual and desired percentages of full scale VTT (67% minus 63% equals 4% or 0.04) and then convert this to mV by multiplying by 1000. At 1.26V, the result would be 50mV and since we want to reduce the GTL reference voltage we would pick the value closest to -50mV. Sometimes tweaking VTT slightly up or down can help if none of the available values is close enough the desired offset. Of course, you will need to repeat the calculation using the new VTT."
und ich wollte halt das mir das jemand in deutsch erklärt ^^
da oben bei dem link stets ja auch in deutsch
danke schön
@Fresh_Thing
Der Link ist echt gut.:pObwohl ich kein DFI-Board habe,ist es sehr informativ.
Früher oder später werden auch die anderen hersteller nachziehen und nicht Festgebundene GTL's im Bios anbieten !!!
Daher sollte man sich schnell mit dem Thema ausseinander setzten ;)
Gruß :wink:
