Flat heat pipes
Thin planar heat pipes (heat spreaders) have the same primary components as tubular heat pipes. These components are a hermetically sealed hollow vessel, a working fluid, and a closed-loop capillary recirculation system.
Compared to a one-dimensional tubular heat pipe, the width of a two-dimensional heat pipe allows an adequate cross section for heat flow even with a very thin device. These thin planar heat pipes are finding their way into “height sensitive” applications, such as notebook computers, and surface mount circuit board cores. It is possible to produce flat heat pipes as thin as 0.5 mm (thinner than a credit card).
