help me finding good i7 batch ?
kayawish24
Germany
hello my german friends....
i want to know that if i order i7 cpu online so how i shall make sure that i get a good BATCH i7 cpu?can anyone tell me a shop in german who sells good i7 cpu i mean like HOH.de etc.i really have to buy i7 cpu with good batch number so that it can be OC on low Vcore...please advice me
yes it means used / gebraucht, but the shop guarantees a certain clock speed (overclock)
but i´m not quite sure how they handle the warranty in general
the shop overclocks its CPU's and sells it such as Intel Core i7 920 4x 2.67GHz@4,2GHz Boxed.
i think buying gebrach cpu will be bad idea.why dont i do just this that i order i7 cpu online and then test it how good it can OC with in 2 weeks.because i think in german law i can send things back to company with in 2 weeks of time even if i used them.is this true?
yes, but you only can test the CPU like you see it in the store, so if you put it into you PC, the shop can say "the CPU cost 250€, we give you only 200€ back, because you used it".
therefore bawde told you of a shop that guarantees a certain overclockability. If you don´t want to pay for this guarantee you have to have luck, just as any other guy
ya i think you are right....i am stuck now.i thing germany need to change it law and for this i decided that my vote for chancelor will go to SPD
If you send back an open boxed cpu u can be asured you wont get back all of your money
