Janchu88
Kapitän zur See , HWLUXX Vize-Superstar
lol scheinbar verkackt ein X² im Prime test gegen nen Athlon XP... xD
werde mich nochmal mit den threadprioritäten auseinandersetzen müssen
import java.awt.*;
import java.awt.event.*;
import java.applet.*;
import java.util.*;
public class AppletBench extends Applet implements ActionListener,ItemListener
Iteration panel;
Prime panel2;
Ram panel3;
Font schrift1,schrift2;
Label titel;
Choice choice1;
Button select,select2,select3;
public void init()
setLayout(null);
schrift1 = new Font("Serif", Font.ITALIC, 35);
schrift2 = new Font("Serif", Font.ITALIC, 25);
titel = new Label("Janchu88´s Java Benchmark v0.021");
titel.setBounds(20,25,375,25);
titel.setFont(schrift2);
add(titel);
choice1 = new Choice();
choice1.setBounds(50,75,150,25);
choice1.add("Iteration-Bench");
choice1.add("Prime-Bench");
choice1.add("Ram-Bench");
choice1.addItemListener(this);
add(choice1);
select = new Button("Select");
select.setBounds(250,75,100,25);
select.addActionListener(this);
select.setVisible(true);
add(select);
select2 = new Button("Select");
select2.setBounds(250,75,100,25);
select2.addActionListener(this);
select2.setVisible(true);
select3 = new Button("Select");
select3.setBounds(250,75,100,25);
select3.addActionListener(this);
select3.setVisible(true);
panel = new Iteration();
panel.setBounds(100,125,200,300);
panel2 = new Prime();
panel2.setBounds(100,125,200,300);
panel3 = new Ram();
panel3.setBounds(100,125,200,300);
add(panel);
public void actionPerformed(ActionEvent e)
Object quelle;
quelle = e.getSource();
if(quelle.equals(select))
remove(panel3);
remove(panel2);
add(panel);
if(quelle.equals(select2))
remove(panel3);
remove(panel);
add(panel2);
if(quelle.equals(select3))
remove(panel);
remove(panel2);
add(panel3);
public void itemStateChanged(ItemEvent e)
String s;
s = choice1.getSelectedItem();
if (s.equals("Iteration-Bench"))
remove(select3);
remove(select2);
add(select);
if (s.equals("Prime-Bench"))
remove(select3);
remove(select);
add(select2);
if (s.equals("Ram-Bench"));
remove(select);
remove(select2);
add(select3);
import java.awt.*;
import java.util.*;
class Iteration extends Panel implements ActionListener
Button iteration;
Label count;
Label zeit;
Iteration()
setLayout(null);
iteration = new Button("Start Iteration-Bench");
iteration.setBounds(25,25,150,25);
iteration.addActionListener(this);
add(iteration);
count = new Label("");
count.setBounds(50,75,125,25);
count.setFont(schrift1);
add(count);
zeit = new Label("");
zeit.setBounds(50,125,125,25);
zeit.setFont(schrift2);
add(zeit);
setVisible(true);
public void iteration()
double t0,t1,t2;
double min = 1.0;
double max = 2.0;
double halb = 1.0,halbpow;
double a = 0.0, iterationint = 5000000.0;
String t2str,prozentstr;
double prozent;
t0 = System.currentTimeMillis();
while(a < iterationint)
halb = (min + max) / 2.0;
halbpow = Math.pow(halb,2);
if(halbpow > 2.0)
max = halb;
else
min = halb;
a++;
prozent = (a/iterationint)*100.0;
prozentstr = Cio.format(prozent,1,1);
count.setText(prozentstr + "%");
t1 = System.currentTimeMillis();
t2 = (t1-t0)/1000.0;
t2str = Double.toString(t2);
zeit.setText(t2str + "s");
Object quelle;
if ( quelle.equals(iteration)) iteration();
import java.awt.*;
import java.util.*;
class Prime extends Panel implements ActionListener
Button prime;
Label zeit;
Label count;
public Prime()
setLayout(null);
prime = new Button("Start Prime-Bench");
prime.setBounds(25,25,150,25);
prime.addActionListener(this);
add(prime);
add(count);
add(zeit);
setVisible(true);
public void prime()
//Variablen
int rest;
int teiler;
int zahl = 2;
double prozent;
double t0,t1,t2;
String t2str;
String prozentstr;
//Beginn
for(int zaehler = 0; zaehler < 300000; zaehler++)
rest = zahl % 2;
if(rest == 1)
teiler = 3;
do
rest = zahl % teiler;
teiler++;
while(rest>0);
prozent = (zaehler / 300000.0 )*100.0;
zahl++;
Object quelle;
if(quelle.equals(prime));
prime();
import java.awt.*;
import java.util.*;
class Ram extends Panel implements ActionListener
Label count,count2;
long freeBytes;
long totalBytes;
String free,total;
public Ram()
int[] zahl;
zahl = new int[10000];
count.setBounds(50,75,300,25);
add(count);
count.setBounds(50,125,300,25);
add(count);
setVisible(true);
Runtime rt = java.lang.Runtime.getRuntime();
freeBytes = rt.freeMemory();
totalBytes = rt.totalMemory();
free = Long.toString(freeBytes);
total = Long.toString(totalBytes);
count.setText("freie Bytes: " + free + " | gesamt: " + total );
for(int i = 0 ; i < 10000; i++)
zahl[i] = i ;
Runtime rx = java.lang.Runtime.getRuntime();
freeBytes = rx.freeMemory();
totalBytes = rx.totalMemory();
count2.setText("freie Bytes: " + free + " | gesamt: " + total );
Object quelle;
import java.io.*;
import java.text.*;
public class Cio
private static int i=0;
private static double d=0.0;
private static String s="";
private static char c = ' ';
private static String version = "26.01.2007";
// Eine beliebige Eingabe wird ausgewertet
private static String read()
BufferedReader eingabe = new BufferedReader(
new InputStreamReader(System.in));
try
s = eingabe.readLine();
catch (Exception e)
s = "";
try
i = Integer.parseInt(s);
catch (Exception e) {
i = 0;
try
d = Double.parseDouble(s);
d = 0.0;
try
char[] ca = s.toCharArray();
c = ca[0];
catch (Exception e)
c = ' ';
return(s);
* Eingabe eines Strings von der Tastatur
public static String readString()
read(); return(s);
* Ausgabe eines Strings und anschliessende
public static String readString(String meldung)
print(meldung); read(); return(s);
* Eingabe eines int-Wertes von der Tastatur
public static int readInt()
read(); return(i);
public static int readInt(String meldung)
print(meldung); read(); return(i);
* Eingabe eines double-Wertes von der Tastatur
public static double readDouble()
read(); return(d);
public static double readDouble(String meldung)
print(meldung); read(); return(d);
* Eingabe eines char-Wertes von der Tastatur
public static char readChar()
read(); return(c);
public static char readChar(String meldung)
print(meldung); read(); return(c);
* Ausgabe eines Strings auf dem Monitor
public static void print( String x )
System.out.print(x);
* Ausgabe eines int-Wertes auf dem Monitor
public static void print( int x )
* Ausgabe eines double-Wertes auf dem Monitor
public static void print( double x )
* Ausgabe einer Leerzeile auf dem Monitor
public static void println()
System.out.println();
* Ausgabe eines Strings auf dem Monitor mit Zeilenwechsel
public static void println( String x )
System.out.println(x);
* Ausgabe eines int-Wertes auf dem Monitor mit Zeilenwechsel
public static void println( int x )
* Ausgabe eines double-Wertes auf dem Monitor mit Zeilenwechsel
public static void println( double x )
* Formatierung eines int-Wertes <br>
* laenge = Gesamtlänge des Ausgabestrings <br>
* Die Anzahl der Stellen wird in jedem Fall vollstaendig
* dargestellt, auch wenn eine zu geringe Gesamtlaenge angegeben
* wurde <br>
* Bei einem Wert laenge = 0 werden alle Stellen angezeigt
public static String format(int i, int laenge)
String s = String.valueOf(i);
int len = s.length();
while(len<laenge)
s = " " + s;
len = s.length();
return s;
* Formatierung eines long-Wertes <br>
* wurde <br>
public static String format(long i, int laenge)
while(len<laenge)
s = " " + s;
len = s.length();
return s;
* Formatierung eines double-Wertes<br>
* laenge = Gesamtlänge des Ausgabestrings<br>
* dezi = Anzahl der Nachkommastellen<br>
* Die Anzahl der Vorkommastellen wird in jedem Fall vollständig
* dargestellt, auch wenn eine zu geringe Gesamtlänge angegeben
* wurde; d.h. bei einem Wert laenge = 0 werden alle
* Vorkommastellen angezeigt.
public static String format(double x, int laenge, int dezi)
String s; // Ausgabestring
int len; // Laenge von Strings
String formatString; // beschreibt die Formatierung
DecimalFormatSymbols dfs; // Dezimalpunkt etc.
DecimalFormat df; // Objekt zur Formatierung
final String NULLEN = "000000000000000000000000000000";
final String LEER = " ";
dfs = new DecimalFormatSymbols();
dfs.setDecimalSeparator('.');
dfs.setGroupingSeparator(','); // hier nicht erforderlich
// Formatstring und Formatobjekt bilden mit
// der richtigen Anzahl der Nachkommastellen
formatString = "0." + NULLEN.substring(0,dezi);
df = new DecimalFormat(formatString,dfs);
// Formatierte Zahl als String
s = df.format(x);
// Gesamtlaenge bilden
len = s.length();
if (len>laenge) laenge=len;
s = LEER + s;
len = s.length();
s = s.substring(len-laenge,len);
// Rückgabe der formatierten Zahl als String
return(s);
* Ausgabe eines formatierten double-Wertes auf dem Monitor<br>
public static void printf(double x, int laenge, int dezi)
String s = format(x,laenge,dezi);
System.out.print(s);
* mit Zeilenwechsel.<br>
public static void printlnf(double x, int laenge, int dezi)
System.out.println(s);
* Zufallswert im Bereich zwischen zwei Werten
public static int zufall(int von, int bis)
return( von + (int)((bis-von+1)*Math.random() ));
* Zeitverzoegerung in Millisekunden
public static void delay(int millisec)
try { Thread.sleep(millisec);}
catch (InterruptedException e) {}
* Rückgabe der Versionsbezeichnung (Datum / Autor)
public static String getVersion()
return "Version : " + version + " / W.Gerdes";
* Ausgabe der Versionsbezeichnung (Datum / Autor)
public static void printVersion()
System.out.println("-------------------------------------------------");
System.out.println(" Klasse : CIO ");
System.out.println(" Version : " + version);
System.out.println(" Autor : W.Gerdes ");
System.out.println(" Beschreibung : Hilfsklasse fuer Textkonsole ");
