JUMBO CASE - Custom build
This time not CORSAİR case and not case mod , Custom made…
And a quite big case…
At one of my friend’s request we have planned a case so;
The case will be made for 2 Mainboards
It will have the opportunity of a large watercooling(25X120 rads)
The Evo radiator which is used will be moded. From 3 channels, the one in the middle will be connected to the compressor.
With this radiator, if it is needed, by running the compressor, extra cooling can be provided.
The frame of the case is sheet iron profile.
Used 2 mm aluminum plates.
Then , firstly it is undercoated with epoxy ground coat, later it is painted mat black with spray paint .
The necessary plexi pieces are self made .and it is delivered to my friend as a naked case.
After this, hardware will be established by him.
I completed my duty by making the case only.
The next phase is depend on my friend’s studies.
U[/FONT][/FONT][/FONT]
OTHER WORKLOGS
Worklog http://www.hardwareluxx.de/community/f143/playdoh-silverstone-tj-07-acrylic-pipe-1012476.html
Worklog http://www.hardwareluxx.de/communit...-watercooled-copper-acrylic-pipe-1028332.html
Worklog http://www.hardwareluxx.de/communit...w-edition-acrylic-tubing-upgrade-1027807.html
Worklog http://www.hardwareluxx.de/community/f143/12-angry-men-900-d-case-p1-1002736.html
Worklog http://www.hardwareluxx.de/community/f143/corsair-900-d-watercooled-mmt-case-997564.html
Worklog http://www.hardwareluxx.de/community/f143/transformer-case-996669.html
Worklog http://www.hardwareluxx.de/community/f143/how-make-bench-case-old-atx-1-a-1032451.html
Worklog http://www.hardwareluxx.de/community/f143/4-way-hdd-switcher-1033308.html
Worklog http://www.hardwareluxx.de/community/f143/self-made-cosmos-ii-clear-panel-1034027.html#post22531803
OTHER WORKLOGS
