Konvertieren meiner Videos mit HandBrake für die PS3
Ok, ich würde auf jeden Fall auch noch den Haken bei "Keep individual encode logs" machen. Daran wird es wohl auch liegen. :)
LG
LG
Es hat prima funktioniert. :)
### CLI Query: -i "F:\***" -t 1 -c 1 -o "F:\***" -f mp4 -p -e x264 -q 0.62 -a 1 -E faac -B 128 -R 48 -6 dpl2 -D 1 -x ref=3:mixed-refs=1:analyse=all:me=umh:no-fast-pskip=1:bframes=3:b-pyramid=1:subq=7 -v
[13:31:22] hb_init: checking cpu count
[13:31:22] hb_init: starting libhb thread
HandBrake 0.9.3 (2008112300) - http://handbrake.fr/
4 CPUs detected
Opening F:\***...
[13:31:22] hb_scan: path=F:\***, title_index=1
[13:31:22] scan: trying to open with libdvdread
[13:31:22] dvd: not a dvd - trying as a stream/file instead
Input #0, mpeg, from 'F:\***':
Duration: 02:16:36.86, start: 28.557000, bitrate: 4708 kb/s
Stream #0.0[0x1c0]: Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.1[0x1c1]: Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.2[0x80]: Audio: ac3, 48000 Hz, 5:1, s16, 384 kb/s
Stream #0.3[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], 15000 kb/s, 25.00 tb(r)
[13:31:22] scan: decoding previews for title 1
[13:31:22] scan: audio 0x2: AC-3, rate=48000Hz, bitrate=384000 Unknown (AC3) (5.1 ch)
Scanning title 1...
Scanning title 1...
Scanning title 1...
Scanning title 1...
Scanning title 1...
[13:31:25] scan: 10 previews, 720x576, 25.000 fps, autocrop = 74/74/2/2, aspect 16:9, PAR 64:45
[13:31:25] scan: title (0) job->width:720, job->height:304
[13:31:25] libhb: scan thread found 1 valid title(s)
+ title 1:
+ vts 0, ttn 0, cells 0->0 (0 blocks)
+ duration: 02:16:36
+ size: 720x576, aspect: 1.78, 25.000 fps
+ autocrop: 74/74/2/2
+ chapters:
+ 1: cells 0->0, 0 blocks, duration 02:16:36
+ audio tracks:
+ 1, Unknown (MP2)
+ 2, Unknown (MP2)
+ 3, Unknown (AC3) (5.1 ch), 48000Hz, 384000bps
+ subtitle tracks:
[13:31:25] 1 job(s) to process
[13:31:25] starting job
[13:31:25] work: sanitizing track 0 mixdown Dolby Pro Logic II to Stereo
[13:31:25] job configuration:
[13:31:25] * source
[13:31:25] + F:\***
[13:31:25] + title 1, chapter(s) 1 to 1
[13:31:25] + container: mpeg
[13:31:25] + data rate: 4708 kbps
[13:31:25] * destination
[13:31:25] + F:\***
[13:31:25] + container: MPEG-4 (.mp4 and .m4v)
[13:31:25] * video track
[13:31:25] + decoder: mpeg2video
[13:31:25] + bitrate 15000 kbps
[13:31:25] + frame rate: same as source (around 25.000 fps)
[13:31:25] + strict anamorphic
[13:31:25] + storage dimensions: 720 * 576 -> 716 * 428, crop 74/74/2/2
[13:31:25] + pixel aspect ratio: 64 / 45
[13:31:25] + display dimensions: 1018 * 428
[13:31:25] + encoder: x264
[13:31:25] + options: ref=3:mixed-refs=1:analyse=all:me=umh:no-fast-pskip=1:bframes=3:b-pyramid=1:subq=7
[13:31:25] + quality: 0.62
[13:31:25] * audio track 0
[13:31:25] + decoder: Unknown (MP2) (track 1, id 0)
[13:31:25] + mixdown: Stereo
[13:31:25] + encoder: faac
[13:31:25] + bitrate: 128 kbps, samplerate: 48000 Hz
[13:31:25] encx264: encoding with stored aspect 64/45
[13:31:25] dvd: not a dvd - trying as a stream/file instead
[13:31:25] encx264: Encoding at constant RF 19.380000
x264 [warning]: width or height not divisible by 16 (716x428), compression will suffer.
x264 [info]: using SAR=64/45
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 PHADD SSE4.1 Cache64
x264 [info]: profile Main, level 3.0
[13:31:25] sync: expecting 204946 video frames
[13:31:25] reader: first SCR 2570130
[13:31:25] sync: first pts is 32400
[13:31:25] sync: adding 165 ms of silence to audio 0 start 14860, next 0
[mpeg2video @ 0x1b07030]ac-tex damaged at 21 17
[mpeg2video @ 0x1b07030]ac-tex damaged at 5 18
[mpeg2video @ 0x1b07030]ac-tex damaged at 18 19
[mpeg2video @ 0x1b07030]Warning MVs not available
MP4ERROR: MP4WriteBytes: error writing bytes via virtual I/O
ERROR: Failed to write to output file, disk full?
[14:14:04] sync: got 116966 frames, 204946 expected
[14:14:04] work: average encoding speed for job is 0.000000 fps
[14:14:04] mpeg2video-decoder done: 117007 frames, 0 decoder errors, 0 drops
[14:14:04] render: lost time: 0 (0 frames)
[14:14:04] render: gained time: 0 (0 frames) (0 not accounted for)
[14:14:04] reader: done. 1 scr changes
x264 [info]: slice I:1630 Avg QP:18.56 size: 42900 PSNR Mean Y:44.19 U:47.49 V:47.60 Avg:45.03 Global:44.16
x264 [info]: slice P:65201 Avg QP:20.93 size: 16538 PSNR Mean Y:41.61 U:44.85 V:45.07 Avg:42.44 Global:41.47
x264 [info]: slice B:50072 Avg QP:23.40 size: 5123 PSNR Mean Y:40.48 U:44.30 V:44.60 Avg:41.42 Global:40.44
x264 [info]: consecutive B-frames: 20.9% 59.4% 12.8% 7.0%
x264 [info]: mb I I16..4: 19.3% 0.0% 80.7%
x264 [info]: mb P I16..4: 4.3% 0.0% 13.1% P16..4: 40.3% 23.9% 12.6% 0.8% 0.8% skip: 4.1%
x264 [info]: mb B I16..4: 0.2% 0.0% 0.9% B16..8: 52.5% 3.1% 4.9% direct: 8.0% skip:30.4% L0:32.1% L1:56.4% BI:11.6%
x264 [info]: ref P L0 78.6% 13.5% 7.9%
x264 [info]: ref B L0 88.2% 11.8%
x264 [info]: ref B L1 96.3% 3.7%
x264 [info]: SSIM Mean Y:0.9757102
x264 [info]: PSNR Mean Y:41.165 U:44.648 V:44.904 Avg:42.038 Global:41.027 kb/s:2403.21
[14:14:04] mp2-decoder done: 0 frames, 0 decoder errors, 0 drops
[14:14:04] libhb: work result = 0
Rip done!
HandBrake has exited.
Warum ist dieser Rip defekt/unvollständig?
Außerdem habe ich bemerkt, dass die Filme nachdem konvertieren im Bildformat beschnitten wurden. Ärgerlich ist es, wenn wichtiges Bildmaterial weg ist.
Das kann Dir leider auch nicht so direkt sagen.
EDIT:
Diese Zeile:
Anscheinend hast Du versucht eine "Nicht-DVD" als DVD zu öffnen. Probiere es mal mit "Source" - "Video File".
Das wird das automatische Cropping sein... unter "Picture Settings" - "Automatic". Es funktioniert grob im Durchschnitt schon ganz gut, aber ich vertraue auch nie drauf und mache das Cropping (Beschneiden) manuell.
hmmm... das mache ich jedesmal.
Kann man das Automatische beschneiden nicht auslassen, sodass es das Seitenverhältnis der Originaldatei beibehält?
Ok, merkwürdig. Das trat jetzt aber nur bei der einen Datei auf oder ist das etwas immer so bei Dir?
Kann man schon indem man die Cropping-Werte auf 0 setzt. Aber das wäre ja eigentlich ziemlich schwachsinnig. Die schwarzen Balken blasen die Datei ja unnötig in der Größe auf... und das dann nicht gerade wenig. Somit hat man eine Menge überflüssigen Müll in der Datei. Also die Auto-Cropping-Funktion beschneidet das Bild eigentlich sogar auch eher zu wenig - sodass das eigentlich das Bild in keinem Fall beschnitten wird. So jedenfalls meine Erfahrung.
Also beim Video-Encoding überhaupt nicht zu croppen... davon würde ich ganz stark abraten. :)
ich nehme für meine PS3 immer Nero Recorde und das MP4 Format unter Recode.
Da gibt es ein extra profil für PS3, da kannste auflösung, ton und endgröße einstellen und klappt wunderbar, sogar mit 8treads beim I7 ;)
ich habe bloß noch ein anderes Problem:
kennt jemand mediacoder?der ist auch genial, leider geht der nur mit einem kern under mencoder für mpeg4.was muss ich da einstellen?jemand nen TIP?
Nein, das war das erste Mal.
Ich habe soeben einen Versuch ohne Beschneidung gestartet. Ich bin gespannt wie groß die Datei wird und wie lange das Konvertieren dauern wird.
Fazit:
Die Datengröße der Ursprungsdatei beträgt 1,89GB wie gehabt. Die Konvertierzeit mit Beschneidung betru.g 1:17:40 jedoch ohne nur 1:26:14. Die Dateigröße mit Beschneidung beträgt 2,06GB und ohne 2,14GB. Ich bin nicht zu 100% zufrieden, weil ich unter der Bildeinstellung "Vollbild" bei der PS3 rechts und links schwarze Streifen habe jedoch schalte ich den "Overscan" beim Fernseher an sind diese weg, aber dafür fehlt mir etwas Bildmaterial an den Seiten. Ich kann leider auch nicht nachvollziehen, ob die schwarzen Balken oben und unten der Standardgröße entsprechen.
Wie sind denn jetzt Deine Einstellungen unter "Picture Settings" genau?
LG
Ok, das sind bis auf Cropping-Einstellung die normalen Werte aus dem PS3-Preset.
Das Problem ist, dass ich es nicht wirklich nachvollziehen kann, weil ich noch nie eine PS3 besessen habe und wohl auch nicht werde.
Vielleicht kann man da noch irgendwie Einstellungen im PS3-Menü zur Darstellung machen?
Das Preset wird ja schon richtig durchdacht sein... die Einstellungen sind ja auch nicht irgendwie "falsch" oder so.
Sorry, viel kann ich Dir da jetzt wohl nicht weiterhelfen. Aber ich würde trotzdem das Bild croppen... automatisch oder besser noch manuell.
LG
LG
Ich wähle immer das PS3 Preset aus und stelle dann die von uns besprochen Einstellungen ein. Im PS3 Menü habe ich meines Erachtens alles ausprobiert gehabt. Woher weiß ich beim manuellen Croppen, dass ich nicht zu viel abschneide?
sorry für die verspätete Antwort. Das manuelle Croppen ist in der Windows-Version von Handbrake leider etwas "unkomfortabel", da es kein Preview-Fenster gibt wie in der Mac-Version. Oder Staxrip hat dies z.b. auch.
Daher lasse ich erst das Autocropping an und encode nur ein ganz kurzes Kapitel einer DVD mit den schnellsten Einstellungen, um zu sehen ob oder wieviel Pixel ich noch schneiden muss. Meistens sind das dann nur 1-2 Test-Durchläufe, weil die Auto-Cropping-Funktion schon einigermaßen gut arbeitet.
Das ist natürlich nicht optimal ohne Live-Cropping-Preview, aber es soll in der nächsten Version von Handbrake dann auch in der Windows-Version enthalten sein.
Für mich wäre es sehr ideal, weil meine Dateien keine einzelnen Kapitel haben. Ein genaueres Datum gibt es sicherlich noch nicht? ;)
Bisher leider noch nicht.
LG
Falls du etwas Neues vor mir weißt magst mir dann berichten?
Ja, klar... kein Problem. :)
Gibt es Neuigkeiten bezgl. einer neuen Version von HandBrake mit dem Preview-Fenster?
in dem aktuellen Snapshot gibt es schonmal das Preview-Feature zu testen: HandBrake svn2592
Es setzt allerdings den VLC voraus. Er kann auch portable sein, denn die VLC.exe kann man in den Optionen zuordnen.
LG
Wie muss ich bei dem Preview-Feature vorgehen bzw. welche Einstellungen muss ich noch vornehmen, dass es ohne Probleme klappt?
Eigentlich solltest Du nur in den Optionen unter "Picture" - "VlC Path" den Pfad zur VLC.exe angeben. :)
Okay, habe ich getan. Danach meine Settings gewählt, aber die Vorschau ist immer dieselbe. Bevor die Preview-Funktion starte kommt eine "Warning"-Meldung kommt die Meldung bei dir auch jedes Mal zum Vorschein? Eine Meldung sagt mir ich soll die Anwendung neustarten um eine neue Vorschau zu erhalten, aber leider funktioniert es nicht. Unter Constant Quality kann ich nun nicht mehr genau 61 oder 62 % wählen ist es so gewollt? Weißt du den Grund dafür?
Deine erste Fehlermeldung lässt darauf vermuten, dass Du im Preview-Fenster statt auf "Play with VLC" auf "Play with QT" gedrückt hast. Also Quicktime... Ich habe es gerade nochmal probiert - bei mir klappt es mit dem VLC. Sogar mit der Angabe im Pfad mit der PortableVLC.exe.
Bezgl. der Constant Quality-Angabe haben sie es jetzt wohl mehr auf den RF (Rate Factor) abgestimmt. h264 wird ja mit dem Wert RF angesprochen. Die Prozent-Angabe in Handbrake ist quasi nur eine Umrechnung. Und in den letzen Versionen waren bei z.b. 62% die RF-Werte sowas wie z.b. 19,2545 (jetzt mal nicht umgerechnet - nur als Beispiel).
Die Meldung kommt sobald ich auf den Button Preview drücke, d.h. ich konnte noch nicht einmal auf "Play with VLC" auf "Play with QT" drücken.
Achso ok... hmm, komisch. Dann braucht man anscheinend auch Quicktime auf dem System... was für ne Schweinerei. :(
Ich habe nicht das Original-Quicktime auf dem system, sondern QuickTime Lite for VCP. Also im Prinzip so wie die QuickTime Alternative.
Irgendwie ist diese Preview-Sache auch (noch?) nicht so wirklich das, was ich mir erhofft hatte. :(
Was ist mit dem Apple QuickTime Player? Ich Frage nur deshalb, weil du diesen nicht in deinem Post aufgeführt hast. Zur Not würde ich den Player installieren, ABER warum ist die "Preview-Sache" noch nicht, dass was du dir erhofft hattest?
Naja, das ist ja der aufgeblähte Original-Kram von Apple. Das kommt mir schon lange nicht mehr auf das System. Dewegen benutze ich die schlankeren Alternativen. :)
Ich würde mir eher so eine Live-Vorschau zum Schneiden (Croppen) des Bildes wie bei StaxRip wünschen. Handbrake erstellt (encodiert) mit der Preview-Funktion ja ein Test-Sample, welches dann mit einem externen Player (VLC) abgespielt wird. Natürlich auch schon nicht schlecht, weil ich das vorher mit Handbrake immer manuell gemacht habe, um meine Cropping-Einstellungen zu testen. Aber komfortabler finde ich es bei Staxrip.
Kann ich bei dir heraus lesen, dass du zurzeit lieber StaxRip nutzt?
Hehe... nee, das nicht. Ich benutze schon Handbrake. Ich finde jetzt nur diese Live-Vorschau bei Staxrip sehr praktisch. :)
Ich werde mal die Tage eine Lite vom Quick Time Player laden und die Preview-Funktion kennenlernen, aber lieber warte ich auf eine Finale Version. Eher gesagt bis es ausgereift ist. ;) Ich melde mich :) Danke dir!
Ähnliche Themen
