35712
Semiprofi
Hallo!
Nachdem ich einen guten und ausführlichen Test zum HX520 auf silentpcreview.com gelesen habe, ist für mich vor allem ein Punkt offen geblieben:
Wie also wird der Lüfter im Netzteil nun gesteuert und wie sieht dabei die Staffelung aus?
silentpcreview.com schrieb:Big changes in power load seemed to trigger a very quick response in the fan speed, almost as if the fan controller was sensing current instead of just temperature. A current-based fans controller seems unlikely though. The other explanation is that the thermistor is embedded inside a semiconductor, rather than being crudely glued onto a hot spot, which allows the fan controller to be much more responsive. The quick fan slowdown was pleasant when the load was reduced from maximum to modest.
