Lacie 5big meldet Fehler - wie überprüfen
devil77
ich habe ein 5big Netzwerkspeicher und hatte heute folgende Fehler bemerkt.
Scheinbar gibt es Probleme beim lesen bestimmter Bereiche auf sda2.
Kann ich den Speicher auch irgendwie manuell scanen?
Wenn ja welche Tools wären da zu empfehlen oder korrigiert der 5big solche Fehler alleine?
Code:
Jun 20 08:05:23 (none) user.info kernel: sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
Jun 20 08:05:23 (none) user.info kernel: sd 0:0:0:0: [sda] Sense Key : 0x3 [current] [descriptor]
Jun 20 08:05:23 (none) user.warn kernel: Descriptor sense data with sense descriptors (in hex):
Jun 20 08:05:23 (none) user.info kernel:         72 03 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
Jun 20 08:05:23 (none) user.info kernel:         09 72 d6 ef
Jun 20 08:05:23 (none) user.info kernel: sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
Jun 20 08:05:23 (none) user.warn kernel: end_request: I/O error, dev sda, sector 158521071
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512896 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512904 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512912 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512920 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512928 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512936 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512944 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512952 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512960 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512968 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512976 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512984 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156512992 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156513000 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156513008 on sda2)
Jun 20 08:05:23 (none) user.info kernel: raid5:md4: read error corrected (8 sectors at 156513016 on sda2)
Was willst du da testen?
Da das RAID noch intakt ist, wird da nichts sein, was defekt sein kann.
sda2 wechseln und fertig, und das ziemlich schnell.
(die produziert offensichtlich Fehler, welche durch das RAID korrigiert werden konnten, kann es das RAID nicht mehr, weil eine andere HDD auch Fehler bringt, sind deine Daten im Eimer)
Danke für den Hinweis.
Eingerichtet ist der 5big als Raid6+Spare. Damit könnten max. 2 Platten ausfallen wenn ich mich nicht verlesen habe.
Mich würde nur interessieren wann der der 5big die Spareplatte mit einbindet.
Nur bei einem Totalausfall oder auch wenn Schreib/Leseprobleme auftreten?
