LG W2600HP ,some questions
pool
Excuse me for the english, i'm from Holland,
I have been reading all the threads about the W2600HP ,and i'd like to have one ,if i can get one , all dutch shops are sold out at the moment.
I will be using it for surfing ,Photoshop and movies , no gaming ; my question is : i have read that watching a movie at night is a disaster,i don't really understand this , why would it be so different watching a movie day or night ? what exactly happens ?
Thank you
Lin
where exactly did you find this information?
here
Berni_ATI writes in post no. 287 :
" Bezüglich des Surrens muss ich micht korrigieren, wenn der PC abgeschaltet ist und nur der Monitor an höre ich sehr leises Summen, Surren und am besten wahrnehmbar mit dem Ohr bei den beiden USB Adapteranschlüssen an der Hinterseite des Monitors. Ist aber bei laufendem SEHR leisen GesamtPC nicht hörbar (Bei mir zumindest!)
Nun habe ich mal einige Filme angeguckt, (düstere, dunkle Szenen am späten Abend) und begab mich dann genau in einer Linie zum Monitor (links und rechts)... und siehe da der Blickwinkel ist hierbei am Abend komplett daneben!!!! Mann kann dabei so gut wie gar nix mehr erkennen, alles KOMPETT AUFGEHELLT und extremste Ausleuchtung des KOMPLETTEN Bildschirms."
I can't understand it all perfectly but my impression is that the viewing angle is somehow changed at night ?
Lin
Then viewing angle ist not the real problem.This Display has no polarizer !
This means if you look from the side you will see not real black but a kind of grey.If you are view is fixed in the middle of the screens you dont have a problem.
The bigger problem is to buy one today cause threre is no LG 2600 on the market to get.
I think you have to wait one or two month till we get a new modell from LG.
As an alternative take a look at the HP 2475.It is also IPS based and in your pricerange the best deal.
Several shops have lowered their expected waiting time from about a week and more to 2-4 days. There was also a discussion whether LG was going to release a newer revision of the W2600HP.
I will check that and get back to you later.
Thank you for your reply ,but i thought that a ips based monitor would be better towatch movies on , if you are not exactly in in front of it ,i sometimes wathch a movie with my wife sitting about 1 meter distance from the panel ,therefore the question, i guess i just have to try it out ,IF i can get this monitor !
Thanks ,i will look at this one
Beiträge zusammengeführt, da Antwort auf eigenen Beitrag innerhalb von 4 Stunden:
Thanks i'll wait for any news.
Cheers ,Lin
The LG 2600 is not that good for photoshop, maybe you should take a look at the NEC 24WMGX³, its a new model and was tested very good at prad.de. At the moment it costs about 600€, but only at 2 shops. The rest delivers beginning at 850€. Maybe one of the two cheap shops delivers to holand ..
or does it have to be 26"?
Indeed i reread the prad test , and the 2600 seems not optimal for fotowork ,perhaps i should look further ,i do like the idea of a 26 inch ,nice and big and bigger letters than a 24 .
i guess it has to be a compromise ,i'd like to stay around the 500 euro's,
I just got LG holland on the phone, the 2600 is not being delivered anymore in nl.
So you have to wait till LG will deliver a new 26er screen.Perhaps some problems of the "old" version will be fixed in the futureversion.
Yes i might wait for the new LG/
Thanks for the advice
EDIT
For now i bought the Acer AL2623W at Mediamarkt for 265 euro ,with PVA panel.I think a good price, i bought 2 ,one goes back to MM ,one had a slight red haze , one is ok , no " humming " noise , just a known problem with the resolution going down 1 step sometimes, but since i had the xp power settings altered to : switch monitor off after 1 minute if not used i have not seen this problem.
Colors seem fine for photohsop work.
Just a slight problew with a " halo or haze " around fonts , i will make a post about this.
I might later look at the new LG when it comes out.
