Lumia 930 Resetet anduaernd nach Update?
SUNMorph
Experte
Hy,
ich habe heute ein neues Update (Windows 10) von meinem Nokia 930 gemacht, jetzt rebootet es andauernd, ich komme nichtmal bis zur Pineingabe.
Habt ihr vielleicht einen Tipp wie ich aus dieser Endlosschleife rauskomme?
Hardreset habe ich schon probiert, leider hat das nicht geholfen.
Danke
Aus einem anderen Forum (OHNE GARANTIE)
1.hold power button + volume up key at the same time. Phone will reboot after vibrating. Eventually you should see a lightning bolt with a cog (i think it was a cog)
2. hold down power button + volume down key. Same thing should happen - vibrate followed by phone reboot. Keep holding down until the exclamation mark appears. let go and perform the next step immediately as the exclamation point will disappear after 15-30 seconds and the phone goes back into that annoying loop (Note: this step is a bit hazy to me. I cannot remember if I let go at some point and pressed power plus vol- combination. Either way, the key is to get the exclamation mark on your phone and you should be right to go. Experiment)
3. Press these buttons one at a time in this order:
- Volume Up, Volume Down, Power, Volume Down
4. Device should vibrate, reboot, show the Nokia flash screen, and then go to the spinning gears install screen.
5. This should eventually get you into the startup/setup prompts
