Moin... Leider bei gleichem Link immer noch Problem... SQL-Statement...
Konnte Abfrage nicht ausführen! SELECT name, kat_id, sub_kat FROM cms_kategorien WHERE kat_id =
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /var/www/sites/hardware/cms/include/database.class.php on line 104
Artikel nicht vorhanden
