[0.021] Log: Log file open, 07/06/08 11:05:24
[0.021] Init: BioWare Final Build Version: 1.0.14184.0
[0.021] Init: Command line:
[0.021] Init: Base directory: E:\Games\Mass Effect\Binaries\
[0.059] Init: CPU Page size=4096, Processors=2
[0.059] Init: High frequency timer resolution =3.579545 MHz
[0.059] Init: Memory total: Phys=4192656K Pagef=4194303K Virt=2097024K
[5.343] Log: Failed to load 'Material None.': Failed to find object 'Material None.'
[5.344] Log: Failed to load 'Material None.': Failed to find object 'Material None.'
[5.359] Log: Failed to load 'Material None.': Failed to find object 'Material None.'
[14.591] Init: Audio Driver: Realtek Digital Output (Realtek High Definition Audio) ({0.0.0.00000000}.{7ddf8775-db13-4aee-b200-c3b49cfdbe27})
[14.616] Init: Audio Device: Generic Software
[14.803] Init: 64 Free Sources, 2 Reserved
[16.591] Log: >>>>>>>>>>>>>> Initial startup: 16.59s <<<<<<<<<<<<<<<
[16.950] Log: Bio2DA.cpp::CheckedGetIntEntry(): Failed to read row(1902, isNum=0), column(4) in Bio2DA(Talent_TalentEffectLevels)
[16.950] Log: Bio2DA.cpp::CheckedGetFloatEntry(): Failed to read row(1918, isNum=0), column(4) in Bio2DA(Talent_TalentEffectLevels)
[54.761] Log: Loading John00_QuickSave on device Id 0...
[55.640] Warning: Warning, Missing BioSoundNodeWaveStreamingData BIOG_StreamingAudioData.PC.x06_player_final referenced by package 'x06_player_final_ss'
[55.839] BioChallengeScaling: UBioPawnBehavior::ScaleSecondaryAttributes: Warning! Attribute table could not be found! No scaling done for pawn 'BioPawn_7' with type 'human_male'.
[55.844] Log: Bio2DA.cpp::CheckedGetIntEntry(): Failed to read row(1902, isNum=0), column(4) in Bio2DA(Talent_TalentEffectLevels)
[55.844] Log: Bio2DA.cpp::CheckedGetFloatEntry(): Failed to read row(1918, isNum=0), column(4) in Bio2DA(Talent_TalentEffectLevels)
[61.194] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_AcceptedAttack
[61.195] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_AcceptedAttack
[61.195] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_AcceptedLockTarget
[61.196] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_AcceptedLockTarget
[61.196] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_IncomingGrenade
[61.197] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_IncomingGrenade
[61.197] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_CompletedMove
[61.198] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_CompletedMove
[61.198] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_AcceptedMove
[61.199] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_AcceptedMove
[61.199] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_LostCover
[61.200] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_LostCover
[61.200] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_PainGrunt
[61.201] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_PainGrunt
[61.201] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_PerceptionSeeEnemy
[61.202] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_PerceptionSeeEnemy
[61.202] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_ShieldsDown
[61.203] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_ShieldsDown
[61.203] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_TargetDown
[61.204] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_TargetDown
[61.204] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_PerceptionAttackedByEnemy
[61.205] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_PerceptionAttackedByEnemy
[61.205] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_PerceptionHearEnemy
[61.206] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_PerceptionHearEnemy
[61.206] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave x06_player_final_ss.x06_player_final:VO_TechAIHacking
[61.207] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave x06_player_final_ss.x06_player_final:VO_TechAIHacking
[217.971] BioChallengeScaling: UBioPawnBehavior::LoadEquipment - Warning! The pawn 'BioPawn_2' has no equipment table!
[217.972] BioChallengeScaling: UBioPawnBehavior::LoadEquipment - Warning! The pawn 'BioPawn_5' has no equipment table!
[217.972] BioChallengeScaling: UBioPawnBehavior::LoadEquipment - Warning! The pawn 'BioPawn_0' has no equipment table!
[363.807] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_00
[363.812] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_00
[363.813] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_01
[363.813] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_01
[363.814] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_02
[363.815] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_02
[363.816] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_03
[363.817] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_03
[363.818] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_04
[363.819] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_04
[363.820] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_05
[363.822] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_05
[363.823] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_06
[363.824] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_06
[363.825] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_07
[363.826] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_07
[363.827] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_08
[363.828] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_08
[363.829] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_09
[363.830] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_09
[363.831] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_10
[363.832] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_10
[363.832] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_11
[363.834] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_11
[363.835] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_12
[363.836] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Alert_12
[363.836] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_00
[363.837] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_00
[363.838] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_01
[363.839] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_01
[363.840] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_02
[363.841] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_02
[363.842] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_03
[363.843] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_03
[363.844] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_04
[363.845] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_04
[363.846] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_05
[363.847] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_05
[363.848] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_06
[363.849] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_06
[363.850] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_07
[363.850] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_07
[363.851] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_08
[363.852] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_08
[363.853] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_09
[363.854] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_Allclear_09
[363.855] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_BuffActivated_00
[363.856] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_BuffActivated_00
[363.857] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_BuffActivated_01
[363.858] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_BuffActivated_01
[363.859] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_BuffActivated_02
[363.860] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_BuffActivated_02
[363.861] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_BuffActivated_03
[363.863] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_BuffActivated_03
[363.864] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_BuffActivated_04
[363.865] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_BuffActivated_04
[363.866] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_DeathCry_00
[363.867] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_DeathCry_00
[363.868] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_DeathCry_01
[363.869] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_DeathCry_01
[363.870] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_DeathCry_02
[363.871] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_DeathCry_02
[363.872] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_HealingSquad_00
[363.873] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_HealingSquad_00
[363.873] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_HealingSquad_01
[363.875] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_HealingSquad_01
[363.875] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_HealingSquad_02
[363.877] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_HealingSquad_02
[363.877] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_HealingSquad_03
[363.879] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_HealingSquad_03
[363.879] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_HealingSquad_04
[363.881] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_HealingSquad_04
[363.882] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_HoldingPosition_00
[363.882] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_HoldingPosition_00
[363.883] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_HoldingPosition_01
[363.884] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_HoldingPosition_01
[363.885] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_HoldingPosition_02
[363.886] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_HoldingPosition_02
[363.887] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_00
[363.888] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_00
[363.889] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_01
[363.890] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_01
[363.891] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_02
[363.892] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_02
[363.893] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_03
[363.894] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_03
[363.895] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_04
[363.896] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_04
[363.897] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_05
[363.898] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_05
[363.899] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_06
[363.900] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_06
[363.901] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_07
[363.902] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_07
[363.903] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_08
[363.905] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_08
[363.906] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_09
[363.907] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_09
[363.908] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_10
[363.909] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSestablished_10
[363.910] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_00
[363.911] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_00
[363.912] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_01
[363.913] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_01
[363.914] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_02
[363.915] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_02
[363.916] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_03
[363.917] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_03
[363.917] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_04
[363.919] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_04
[363.919] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_05
[363.920] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_05
[363.921] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_06
[363.922] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_06
[363.923] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_07
[363.924] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_07
[363.925] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_08
[363.926] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LOSunavailable_08
[363.927] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_LowHealth_00
[363.928] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_LowHealth_00
[363.929] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_00
[363.930] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_00
[363.931] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_01
[363.932] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_01
[363.933] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_02
[363.934] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_02
[363.935] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_03
[363.936] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_03
[363.937] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_04
[363.938] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_04
[363.939] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_05
[363.940] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_05
[363.941] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_06
[363.942] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_06
[363.943] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_07
[363.944] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToFailure_07
[363.945] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToSuccess_00
[363.947] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToSuccess_00
[363.948] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToSuccess_01
[363.949] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToSuccess_01
[363.950] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToSuccess_02
[363.951] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToSuccess_02
[363.968] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToSuccess_03
[363.968] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_MoveToSuccess_03
[363.969] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_00
[363.970] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_00
[363.971] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_01
[363.972] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_01
[363.973] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_02
[363.974] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_02
[363.975] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_03
[363.976] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_03
[363.977] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_04
[363.978] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_04
[363.979] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_05
[363.980] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_05
[363.981] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_06
[363.982] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_06
[363.983] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_07
[363.984] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_07
[363.985] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_08
[363.986] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_08
[363.987] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_09
[363.988] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_09
[363.989] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_10
[363.990] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_10
[363.991] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_11
[363.992] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_11
[363.993] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_12
[363.994] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_PainGrunt_12
[363.995] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_ShieldsDown_00
[363.996] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_ShieldsDown_00
[363.997] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_ShieldsDown_01
[363.998] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_ShieldsDown_01
[363.998] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_ShieldsDown_02
[364.000] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_ShieldsDown_02
[364.001] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_00
[364.002] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_00
[364.002] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_01
[364.004] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_01
[364.004] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_02
[364.006] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_02
[364.007] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_03
[364.007] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_03
[364.008] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_04
[364.009] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_04
[364.010] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_05
[364.011] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_05
[364.012] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_06
[364.013] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_06
[364.014] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_07
[364.015] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_07
[364.016] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_08
[364.017] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_08
[364.018] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_09
[364.019] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_StartMoveToConfirmation_09
[364.020] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_00
[364.021] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_00
[364.022] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_01
[364.023] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_01
[364.024] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_02
[364.025] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_02
[364.026] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_03
[364.027] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_03
[364.028] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_04
[364.030] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_04
[364.031] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_05
[364.032] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_05
[364.033] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_06
[364.034] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_06
[364.035] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_07
[364.036] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_07
[364.037] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_08
[364.038] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_08
[364.039] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_09
[364.040] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TacticalDeathRecovery_09
[364.040] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_00
[364.042] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_00
[364.043] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_01
[364.044] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_01
[364.044] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_02
[364.046] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_02
[364.046] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_03
[364.047] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_03
[364.048] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_04
[364.049] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_04
[364.050] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_05
[364.051] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_05
[364.052] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_06
[364.053] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TargetDown_06
[364.054] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_00
[364.055] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_00
[364.058] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_01
[364.058] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_01
[364.059] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_03
[364.060] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_03
[364.061] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_04
[364.062] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_04
[364.063] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_05
[364.064] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_05
[364.065] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_06
[364.082] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_06
[364.083] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleDamaged_00
[364.084] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleDamaged_00
[364.084] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleDamaged_01
[364.086] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleDamaged_01
[364.086] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_02
[364.087] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_TechBeaconDeployed_02
[364.088] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleDamaged_03
[364.089] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleDamaged_03
[364.090] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleDamaged_04
[364.091] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleDamaged_04
[364.092] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleShieldsDown_00
[364.093] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleShieldsDown_00
[364.094] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleShieldsDown_01
[364.095] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleShieldsDown_01
[364.096] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleShieldsDown_02
[364.097] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleShieldsDown_02
[364.098] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleDamaged_02
[364.099] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleDamaged_02
[364.100] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleShieldsDown_03
[364.101] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleShieldsDown_03
[364.102] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleShieldsDown_04
[364.103] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave kaidan_ss.kaidan_DE:VO_VehicleShieldsDown_04
[364.212] BioChallengeScaling: UBioPawnBehavior::ScaleSecondaryAttributes: Warning! Attribute table could not be found! No scaling done for pawn 'BioPawn_8' with type 'hench_humanmale'.
[364.215] Log: Bio2DA.cpp::CheckedGetIntEntry(): Failed to read row(168, isNum=0), column(6) in Bio2DA(Talent_TalentEffectLevels)
[464.647] BioChallengeScaling: UBioPawnBehavior::LoadEquipment - Warning! The pawn 'BioPawn_7' has no equipment table!
[464.647] BioChallengeScaling: UBioPawnBehavior::LoadEquipment - Warning! The pawn 'BioPawn_0' has no equipment table!
[464.648] BioChallengeScaling: UBioPawnBehavior::LoadEquipment - Warning! The pawn 'BioPawn_6' has no equipment table!
[470.443] BioChallengeScaling: UBioPawnBehavior::LoadEquipment - Warning! The pawn 'BioPawn_1' has no equipment table!
[537.269] Warning: Warning, Entering a zone with no BioTriggerStream defined
[630.878] BioChallengeScaling: UBioPawnBehavior::ScaleSecondaryAttributes: Warning! Attribute table could not be found! No scaling done for pawn 'BioPawn_10' with type 'hench_humanmale'.
[630.879] Log: Bio2DA.cpp::CheckedGetIntEntry(): Failed to read row(168, isNum=0), column(6) in Bio2DA(Talent_TalentEffectLevels)
[631.154] BioChallengeScaling: UBioPawnBehavior::ScaleSecondaryAttributes: Warning! Attribute table could not be found! No scaling done for pawn 'BioPawn_11' with type 'hench_humanfemale'.
[631.271] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_00
[631.271] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_00
[631.271] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_01
[631.272] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_01
[631.272] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_02
[631.273] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_02
[631.273] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_03
[631.274] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_03
[631.274] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_04
[631.275] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_04
[631.275] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_05
[631.276] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_05
[631.276] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_06
[631.277] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_06
[631.277] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_07
[631.279] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_07
[631.279] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_08
[631.279] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_08
[631.279] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_09
[631.280] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_09
[631.280] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_10
[631.281] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_10
[631.281] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_11
[631.282] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_11
[631.282] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Alert_12
[631.283] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Alert_12
[631.283] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_00
[631.284] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_00
[631.284] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_01
[631.285] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_01
[631.285] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_02
[631.286] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_02
[631.286] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_03
[631.287] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_03
[631.287] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_04
[631.288] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_04
[631.288] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_05
[631.289] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_05
[631.289] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_06
[631.290] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_06
[631.290] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_07
[631.291] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_07
[631.291] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_08
[631.292] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_08
[631.292] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_09
[631.293] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_Allclear_09
[631.293] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_BuffActivated_00
[631.294] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_BuffActivated_00
[631.294] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_BuffActivated_01
[631.295] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_BuffActivated_01
[631.295] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_BuffActivated_02
[631.296] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_BuffActivated_02
[631.296] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_BuffActivated_03
[631.297] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_BuffActivated_03
[631.297] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_BuffActivated_04
[631.298] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_BuffActivated_04
[631.298] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_DeathCry_00
[631.299] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_DeathCry_00
[631.299] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_DeathCry_01
[631.300] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_DeathCry_01
[631.300] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_DeathCry_02
[631.301] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_DeathCry_02
[631.301] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_HealingSquad_00
[631.302] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_HealingSquad_00
[631.302] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_HealingSquad_01
[631.303] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_HealingSquad_01
[631.303] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_HealingSquad_02
[631.304] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_HealingSquad_02
[631.304] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_HealingSquad_03
[631.306] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_HealingSquad_03
[631.306] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_HealingSquad_04
[631.307] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_HealingSquad_04
[631.307] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_HoldingPosition_00
[631.308] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_HoldingPosition_00
[631.308] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_HoldingPosition_01
[631.309] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_HoldingPosition_01
[631.309] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_HoldingPosition_02
[631.310] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_HoldingPosition_02
[631.310] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_00
[631.310] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_00
[631.311] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_01
[631.311] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_01
[631.311] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_02
[631.312] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_02
[631.312] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_03
[631.313] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_03
[631.313] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_04
[631.314] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_04
[631.314] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_05
[631.315] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_05
[631.315] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_06
[631.316] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_06
[631.316] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_07
[631.317] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_07
[631.317] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_08
[631.318] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_08
[631.318] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_09
[631.319] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_09
[631.319] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_10
[631.320] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSestablished_10
[631.320] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_00
[631.321] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_00
[631.321] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_01
[631.322] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_01
[631.322] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_02
[631.323] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_02
[631.323] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_03
[631.325] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_03
[631.325] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_04
[631.325] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_04
[631.325] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_05
[631.326] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_05
[631.326] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_06
[631.327] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_06
[631.327] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_07
[631.328] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_07
[631.328] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_08
[631.329] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LOSunavailable_08
[631.329] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LowHealth_00
[631.330] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LowHealth_00
[631.330] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_LowHealth_01
[631.331] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_LowHealth_01
[631.331] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_00
[631.332] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_00
[631.332] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_01
[631.333] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_01
[631.333] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_02
[631.334] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_02
[631.334] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_03
[631.335] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_03
[631.335] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_04
[631.336] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_04
[631.336] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_05
[631.337] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_05
[631.337] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_06
[631.338] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_06
[631.338] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_07
[631.339] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToFailure_07
[631.339] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToSuccess_00
[631.340] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToSuccess_00
[631.340] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToSuccess_01
[631.341] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToSuccess_01
[631.341] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToSuccess_02
[631.342] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToSuccess_02
[631.342] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_MoveToSuccess_03
[631.343] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_MoveToSuccess_03
[631.343] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_00
[631.344] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_00
[631.344] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_01
[631.345] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_01
[631.345] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_02
[631.346] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_02
[631.346] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_03
[631.348] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_03
[631.348] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_04
[631.349] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_04
[631.349] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_05
[631.350] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_05
[631.350] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_06
[631.351] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_06
[631.351] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_07
[631.352] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_07
[631.352] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_08
[631.352] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_08
[631.353] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_09
[631.353] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_09
[631.354] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_10
[631.354] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_10
[631.354] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_11
[631.355] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_11
[631.356] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_12
[631.356] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_PainGrunt_12
[631.356] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_ShieldsDown_00
[631.357] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_ShieldsDown_00
[631.357] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_ShieldsDown_01
[631.358] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_ShieldsDown_01
[631.358] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_ShieldsDown_02
[631.359] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_ShieldsDown_02
[631.359] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_00
[631.360] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_00
[631.360] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_01
[631.361] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_01
[631.361] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_02
[631.362] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_02
[631.362] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_03
[631.363] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_03
[631.363] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_04
[631.364] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_04
[631.364] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_05
[631.365] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_05
[631.365] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_06
[631.366] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_06
[631.366] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_07
[631.367] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_07
[631.367] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_08
[631.368] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_08
[631.368] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_09
[631.369] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_StartMoveToConfirmation_09
[631.369] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_00
[631.370] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_00
[631.370] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_01
[631.371] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_01
[631.371] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_02
[631.372] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_02
[631.372] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_03
[631.373] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_03
[631.373] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_04
[631.374] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_04
[631.374] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_05
[631.375] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_05
[631.375] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_06
[631.376] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_06
[631.376] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_07
[631.377] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_07
[631.377] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_08
[631.378] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_08
[631.378] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_09
[631.379] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TacticalDeathRecovery_09
[631.379] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_00
[631.380] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_00
[631.380] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_01
[631.381] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_01
[631.381] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_02
[631.382] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_02
[631.382] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_03
[631.383] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_03
[631.383] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_04
[631.384] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_04
[631.384] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_05
[631.385] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_05
[631.385] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_06
[631.386] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TargetDown_06
[631.386] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_00
[631.387] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_00
[631.387] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_01
[631.388] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_01
[631.388] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_02
[631.390] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_02
[631.390] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_03
[631.391] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_03
[631.391] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_04
[631.392] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_04
[631.392] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_05
[631.393] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_05
[631.393] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_06
[631.393] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_TechBeaconDeployed_06
[631.394] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_VehicleDamaged_00
[631.394] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_VehicleDamaged_00
[631.395] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_VehicleDamaged_01
[631.395] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_VehicleDamaged_01
[631.395] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_VehicleDamaged_02
[631.396] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_VehicleDamaged_02
[631.396] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_VehicleDamaged_03
[631.397] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_VehicleDamaged_03
[631.397] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_VehicleDamaged_04
[631.398] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_VehicleDamaged_04
[631.398] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_VehicleShieldsDown_01
[631.399] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_VehicleShieldsDown_01
[631.399] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_VehicleShieldsDown_02
[631.400] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_VehicleShieldsDown_02
[631.400] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_VehicleShieldsDown_03
[631.401] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_VehicleShieldsDown_03
[631.401] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_VehicleShieldsDown_04
[631.402] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_VehicleShieldsDown_04
[631.402] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave ashley_ss.ashley_DE:VO_VehicleShieldsDown_00
[631.403] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave ashley_ss.ashley_DE:VO_VehicleShieldsDown_00
[633.046] Warning: Warning, ISACTAudio: Using legacy audio path for SoundNodeWave snd_sta_20_xeltan.snd_sta_20_xeltan:c_sta_20_xeltan
[633.047] Warning: Warning, ISACTAudio: Failure to load disk based content bank for cue: SoundNodeWave snd_sta_20_xeltan.snd_sta_20_xeltan:c_sta_20_xeltan
[761.668] Log: Save took 0.87s to complete.
[947.434] Critical: appError called:
[947.434] Critical: Rendering thread exception:
General protection fault!
History: Address = 0x11569901 (filename not found) [in E:\Games\Mass Effect\Binaries\MassEffect.exe]
Address = 0x250b9380 (filename not found)
Address = 0xffccffff (filename not found)
Address = 0x455e5a00 (filename not found)
Address = 0x43a28000 (filename not found)
Address = 0xca4fd037 (filename not found)
Address = 0x65746e65 (filename not found)
Address = 0x6e495564 (filename not found)
[947.434] Critical: Windows GetLastError: Der Vorgang wurde erfolgreich beendet. (0)
