Monitor and halogen bulb tripped two times circuit breakers. Questions.
sew333
Banned
Hello.
I had a good monitor AORUS AD27QD. 2 months ago when i was sleeping monitor was on. When i woke up all electricity went down. After switching 2 small breakers power back . Pc works fine. But monitor was not turned back. I sended to rma.
Here is shop RMA message:
Shop:"We repaired PSU and sending back good monitor to client". So it was psu of monitor tripped breakers,right? Ok solved. New monitor after rma.
But. 1 month ago something tripped 2 small breakers again. All electricity went down again. Then.......i go to bathroom and saw that one of 3 halogen bulbs no lightning. So one bulb get burned. Not again ( my luck ) psu of monitor.
My question is. That i have something with wiring? Or just had bad luck with psu monitor and halogen bulb?
Building is from 2005 ,electricity,breakers,wiring are for 99% fine. Because now working like it should.
you should contact the landlord or an electrician, if its your own house.
