- AMD Ryzen 7 5800x3D
- ASUS ProArt B550 Creator
- Custom by Watercool
- HyperX 64GB DDR4-3466 (KHX3466C16D4/16GX)
- AMD RX6800
- GIGABYTE M34WQ 34" 21:9
- 3x 2 TB NVMe SSDs
- Soundkarte
- Creative Soundblaster Z
- Phanteks Evolv TG
- Seasonic PRIME Ultra Titanium 1000W
- Keyboard
- Keychron K3
- Mouse
- Deathadder v3 (wired)
- Windows 11 Pro x64
- Sonstiges
- Team Fuji
www.thermalright.com
TR-FDB-1000 (1000RPM)
Dimension : 120*120*25mm
Bearing Type : FDB (Fluid Dynamic Bearing)
Rated Voltage : 12.0 VDC
Operating Voltage Range: 10.8~13.2 VDC
Rated Current: 0.130 Amp +10% MAX /0.11AMP
Rated Power: 1.56 watt
Rated Speed: 1000 RPM ± 10%
Airflow: 38.9 CFM
Noise Level: 15.8 dB/A
Life Expectancy: 60000 HOURS AT 40°c / 65%
Net weight: 156 GRAMS
Connector: 3 pin
TR-FDB-1300 (1300RPM)
Rated Speed: 1300 RPM ± 10%
Airflow: 50.0 CFM
Noise Level: 24.1 dB/A
Connector: 3 pin
TR-FDB-1600 (1600RPM)
Rated Speed: 1600 RPM ± 10%
Airflow: 63.7 CFM
Noise Level: 28.0 dB/A
Connector: 3 pin
TR-FDB-2000 (2000RPM)
Rated Speed: 2000 RPM ± 10%
Airflow: 80.5 CFM
Noise Level: 38.0 dB/A
Connector: 3 pin
Airflow: 38.9 CFM
Connector: 3 pin
Airflow: 50.0 CFM
Connector: 3 pin
Airflow: 63.7 CFM
Connector: 3 pin
Airflow: 80.5 CFM
Connector: 3 pin
