neuer Intel RST 11.6.0.1030 / Probleme mit ASRock P67 extreme4 - Bios 3.1
plasmainjektor
mit dem neuem Intel RST 11.6.0.1030 Treiber gibt es bei mir Probleme mit dem ASRock P67 extreme4 - Bios 3.1.
Meine beiden Intel SSD Festplatten, X25E und G2 werden mit dem aktuellen finalem (WHQL) Treiber nicht mehr
erkannt.
Egal ob als Paket installiert oder nur den Treiber während der Windows Installation.
Alle anderen Treiber gehen: 11.2.0.1006, 11.1.0.1006, 10.8.0.1003
Intel schiebt das Problem auf ASRock:
Thank you for contacting Intel® Customer Support regarding your issue with the Intel® RST driver.
The latest version of this driver on your motherboards manufacturers website is listed as ver:10.6.0.1002.
As hardware and software are customized by OEM manufacturers and validated as an entire system, we advise you to contact ASRock in order to acquire the appropriate support or drivers.
In case your system manufacturer advised you to download the Intel® RST drivers from our website, please note that we only provide generic drivers. We cannot take any responsibility for its functionality, as we do not know if the system manufacturer has changed our original configuration.
This could be a reason as to why your SSD is not recognised with version 11.6.0.1030 of the driver.
